12-24-2012, 03:54 PM | #41 |
Rock Crawler Join Date: Jan 2008 Location: Essex, UK
| Re: Parts to power 8.5 inch tires.
I'm using a big 1800kv Hobbywing system in my 1:6 Ford F250. The motors 42 x 74mm so pretty beefy. Can't wait to fire it up. |
12-24-2012, 05:32 PM | #42 |
Rock Crawler Join Date: Mar 2009 Location: East TN
Don't forget the video camera
01-27-2013, 01:58 PM | #43 |
Another update. It is far from done but thought I'd post an update. I've got the trans mount temporarily tacked in and the trans servo tacked in. I have a Novak brushless motor and a Tekin Ra in it that I had laying around. I'm going to see what temps do with this set up. It's pretty fast in first and hasn't drove second gear. But I do know that the tires swell out alittle when it's in the air and I pin 2nd gear. Stock ax3 servo till new one arrives. I still need to finish a lot such as strengthening the links and such. But here's some teasers. Also running all mip shafts through a gcm case going to my own super wide wraith axles. Ill try to et a video later. |
02-12-2013, 01:42 PM | #44 |
Rock Stacker Join Date: Dec 2012 Location: canada
THAT WHAT I USE FOR powered my 1/8 dodge!!! it's a cordless drill 2 speed transmition so i can change from the controller, stock is 4 planetary but i keep just 2 i made an aluminium plate for enclose all!!! and after simply put a wheely king shaft who's fit pecfectly on the gear after that is connect in a axial tansmition to i use for t case, i run a 55 t on 3 s but i will buy a 35 t or 40 on 4s !!! but this settup is very low end tork!!! too much now i mod for have very fast 2 nd speed and the fist have no problem it's a drill take a look rc drill powered plow more 10 inch of snow - YouTube |
