08-29-2011, 12:44 PM | #61 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
Fun rig to drive for sure, thanks Joey |
08-29-2011, 02:44 PM | #62 |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
Best use of a Nylint Jeep I've seen in quite a while (part of it anyway!) Very nice chassis... |
08-29-2011, 09:24 PM | #63 |
RCC Addict Join Date: Nov 2006 Location: burlington
thanks guys i appreciate all your comments, sorry but i didnt get any pics of it. firt time driving it in a month or two, so once it turned on i was off and didnt stop until i broke it. after that i realized i wonted to take a few pics and video.
08-29-2011, 10:32 PM | #64 |
Can you guess which one is the Nylint |
08-29-2011, 11:20 PM | #65 |
I wanna be Dave Join Date: Dec 2009 Location: Outside DC
I need to get my reading glasses...I know it's one of them. |
09-08-2011, 09:03 PM | #66 |
Rock Crawler Join Date: May 2008 Location: in a small town
i think it may be the blue one in front i just picked up one of these big suckers and i think it's gonna be a fun one! |
02-01-2012, 10:04 AM | #67 |
I wanna be Dave Join Date: Jan 2006 Location: Iowa, the antirecreation state!
| Re: Nylint build
I like the sub woofer Everything looks great! Now I'm gonna have to do something totally different when I build mine |
02-01-2012, 03:20 PM | #68 | |
| Re: Nylint build Quote:
thanks Bart a little update on this beast since someone brought it back from the dead. after squaring away the problems with the rear axle, it just pushed them to the front. its not to bad but when i really start to thrash on it i get the problems shown in the pictures. i have the solution for it i just need to finish other rigs before i can work on it. after rereading the thread i noticed i never showed how everything is mounted under the hood. so heres a few pictures. Last edited by joeyf; 02-01-2012 at 04:16 PM. | |
02-01-2012, 07:58 PM | #69 |
Quarry Creeper Join Date: May 2005 Location: edmonton
| Re: Nylint build
well I'm hooked keep the updates coming is that the 2 speed tranny? any thoughts of a servo winch is there room in there? |
02-01-2012, 09:37 PM | #70 | |
ya its a 2 speed emax tranny. i just keep it locked in first, the 45Ts are just to low to utilize the second gear. you could easily get a servo winch in there if you wonted, just move the electronics around and there would be plenty of room. | |
02-02-2012, 05:43 AM | #71 |
| Re: Nylint build
Looks like you need some of that 3mm hardware in dual sheer |
02-02-2012, 11:05 AM | #72 |
| Re: Nylint build
what if you put a supershafty 4 link mount on both sides is that frame brakeline, brazed together, or solid rod welded? Last edited by TRAV; 02-02-2012 at 11:07 AM. |
02-02-2012, 12:08 PM | #73 | |
| Re: Nylint build either that or take out the spacer. Quote:
was thinking of doing the same as the rear just not as big and have a cut out for the servo. shown in red in the picture. the chassis is a little of both. in the first picture thats welded solid rod then the rest of the chassis was built off that with brazed brakeline. | |
02-02-2012, 02:25 PM | #74 |
Rock Crawler Join Date: Sep 2010 Location: Keego Harbor, MI.
| Re: Nylint build
Everything is looking real nice Joey It's good to see those lower links holding up to the abuse. Have you taken the trans apart to see how the gears are holding up? under the hood looks great Regards Rick |
02-02-2012, 05:08 PM | #75 |
| Re: Nylint build
I like the idea of you making a pics for the front should make it bomb proof |
02-02-2012, 07:35 PM | #76 | |
i am hoping so. | |
02-25-2012, 02:16 PM | #77 |
| Re: Nylint build
well its time to fix all the small problems on this thing. ordering the delrin for the front links today. still not to sure on the link setup but i think parallel uppers is going to be the ticket. got the new motors in the mail. never have run these before but they should be faster than the 45t in it right now. they are alot bigger than i am used to. i dont think i have the right motor mount to run them. will be using one from kershaw designs if i need a new one. Last edited by joeyf; 07-28-2012 at 06:37 PM. |
02-25-2012, 07:12 PM | #78 |
| Re: Nylint build
i have one of these in my 1/8 warthog on a summit tranny lots of power, and works great with the two speed tranny having two side by side will be crazy power what will you have to use for a ESC? Last edited by TRAV; 02-26-2012 at 03:22 PM. |
02-28-2012, 10:11 PM | #79 |
| Re: Nylint build
pulled the motors and opened the tranny to see how everything looks. dont see anything out of the ordinary so i just put it back together.. found that the holes dont line up on the motor mount. going to the LHS to so if i can find a pinion that will work how it sits. if so i will just drill new holes and run it. |
07-28-2012, 12:25 PM | #80 |
Rock Crawler Join Date: Mar 2009 Location: East TN
| Re: Nylint build
Any updates on this beast?!
