Aussie 1/6 Willy's new pics I've been looking at all the willy's builds on here, and have been putting mine together for a while now and thought it was time to share. The plan is a modded weakend wheeler with around 33's. I started with a 21st century willy's.http://thecrawlpit.com/forum/downloa...p?id=16947&t=1 Got the body mounted and made some seats out of alloy http://thecrawlpit.com/forum/downloa...p?id=16948&t=1 I made a chassis out of steel and sliced it down the middle, wanted WK diffs as thats what seems to be popular, but had a lot of trouble finding a set over here, I ended up buying an unbuilt AX10 kit from the classifieds on RCC. I was not happy with the axles at this point as I had to use 13mm wideners on them just to get them to fit. So I was on the lookout for a solution. http://thecrawlpit.com/forum/downloa...p?id=16946&t=1 Fitting the rear diff http://thecrawlpit.com/forum/downloa...p?id=16945&t=1 I got some sticky ripsaws from RCC removed green anodizing from bead locks before fitting and modified the axial gear box to use as transfer case got the skid plate welded in place to mount the transfer case & fitted 3 junfac steel shafts http://dc479.4shared.com/img/v40chXH...s_2011_025.JPG http://dc230.4shared.com/img/FqBqxkL...p_2012_009.JPG http://dc355.4shared.com/img/A5joAMu...s_2011_027.JPG Made some D shackle points for front bar also made rear bar with tow point http://dc428.4shared.com/img/icB9GAW...p_2012_024.JPG http://dc379.4shared.com/img/RxC_Z6G...p_2012_021.JPG More to come soon. |
Re: Aussie 1/6 Willy's Got engine and gear box mount welded in under bonnet and cms as well just need a decent servo for steering. http://dc304.4shared.com/img/Wk4JMbA...p_2012_011.JPG http://dc315.4shared.com/img/c4ynYzu...p_2012_010.JPG Almost there just need a esc and steering servo to get it running also make full cage from brake line then test run before stripping down and finish welding the chassis then full paint on body & chassis. I'm thinking Green for the colour with black bar work. I got some Gmade R1 diffs in a trade and sized them up under the willy's. It looked good so it was time for a strip down and diff swap more soon. |
Re: Aussie 1/6 Willy's So as it sits atm it has 2.2 r35 ripsaws Axial black rims with raw alloy rings Gmade R1 diffs Unknown coilovers 45t motor with a 20 tooth pinion Axial gearbox with steal outdrive 2nd Axialbox converted to transfer case with steel internals and alloy case 3x Junfac shafts custom chassis by me brake line cage alloy seats by me Axial AE-3 HH BRXL Jonesn light kit Heres some more pics of how it sits now. Front view http://dc397.4shared.com/img/u-k2lcS...h_2012_035.JPG Rear view http://dc432.4shared.com/img/52z1c2B...h_2012_038.JPG Close up of rear http://dc522.4shared.com/img/NRyIYfx...h_2012_039.JPG Flex shot http://dc97.4shared.com/img/JS8zo_uG/March_2012_043.JPG Started on the cage http://dc526.4shared.com/img/T1ARzxj...h_2012_051.JPG This is as it sit's now http://dc525.4shared.com/img/NywPmkt...l_2012_017.JPG http://dc529.4shared.com/img/0noPded...l_2012_015.JPG I wanted to be able to use the roof that came with it as I haven't seen anyone do this, so made the cage to suit. I've been doing some testing and I love the way this thing drives, very realistic and very capable. Anyone that's thinking about building one should do it. Still have to sort out an esc for this as the BRXL is from my JK, also need a winch and I think a servo winch will be needed as it's a pig. |
Re: Aussie 1/6 Willy's Congrats on getting it together and running so quickly! I need to light a fire under my arse and finish the one I'm working on. |
Re: Aussie 1/6 Willy's Quote:
Re: Aussie 1/6 Willy's I made a four link plate for the rear diff to get the link's closer together for better triangulation, It seems to be better. http://dc232.4shared.com/img/IxzgOGG...l_2012_006.JPG Also got the cage finnished and painted as well as a bit of colour on the body. http://dc525.4shared.com/img/kyrIyJN...l_2012_019.JPG http://dc535.4shared.com/img/q4C-xIE...l_2012_020.JPG http://dc533.4shared.com/img/IoGGrh3...l_2012_021.JPG Under bonnet shot. http://dc535.4shared.com/img/V3rTWtQ...l_2012_022.JPG http://dc535.4shared.com/img/ntqB5Y1...l_2012_017.JPG http://dc525.4shared.com/img/pziXool...l_2012_028.JPG Not much left to do now, I,ve got some stickers on the way from Bowtie to break up the green a bit, I got the light's working but may get a led light bar for up top, and thinking a servo winch might be needed. I think it needs some better foams to (what does everyone else run) as it weighs 12 pounds and they fold on turns. But other than those few thing's I'm pretty happy with how it turned out.:ror: |
Re: Aussie 1/6 Willy's NOW WITH PAINT im a sucker for green! |
Re: Aussie 1/6 Willy's ANOTHER DIFF SWAP Another change of diff's is happening on this as I needed the axial diff's in my JK to build my son a RV rig, so the R1 diffs will go to the JK and I'm building a set of wheely king diff's to go under the willy's, does anyone know where I can pic up some STRC lockouts and straight axles to suit WK diff's. |
Re: Aussie 1/6 Willy's ANOTHER DIFF SWAP Here are some HPI ? Wheely King Rear Axle Lock | eBay |
Re: Aussie 1/6 Willy's ANOTHER DIFF SWAP Quote:
Re: Aussie 1/6 Willy's ANOTHER DIFF SWAP Send ZoSo ( from RCP Crawlers) a PM, he was stocking the WK lock outs for the Willys Jeep builds. |
Re: Aussie 1/6 Willy's ANOTHER DIFF SWAP I checked on RCP and they show out of stock, he may have just the same though. |
Re: Aussie 1/6 Willy's ANOTHER DIFF SWAP Been busy on this again, has anyone used the RC4WD WK straight axles and lockouts, I've just ordered a set and hope there OK as soon as they get here I can finish bulding the diffs and get this thing running again. |
Re: Aussie 1/6 Willy's ANOTHER DIFF SWAP the RC4WD axles will work great....I've never had an issue with them but you may want these: http://rcpcrawlers.com/product.php?p...&cat=23&page=1 |
Re: Aussie 1/6 Willy's ANOTHER DIFF SWAP 9 Attachment(s) Finally got a set of wheelie king diffs fitted and added some more stickers to break up the green, I also found an old large scale ferrari rc and cut out the seats to fit in, also toying with fitting the console, what do you think? I'll probably paint the seats black and grey so the console would be painted to match, it just needs a motor/esc now and will be finnished:lmao:, i have a trailer on the way from a great RCC member and will be doing a build up of that when it arrives as well as a LED light bar so it's not really finished at all,I must say building this is allmost as much fun as running it so I guess it will allways get some changes. |
Re: Aussie 1/6 Willy's ANOTHER DIFF SWAP 6 Attachment(s) Picked this up from one of the forum members. Don't know about the spare yet, and I still need to make an off road hitch, I would have liked it to sit a bit lower, but that would of meant cutting the gaurds off, and I don't know if I want to do that. Let me know what you think. |
Re: Aussie 1/6 Willy's ANOTHER DIFF SWAP I would trim the wheel guards just a little bit. Make it look off road worthy, but keep some of the original intact. |
