04-27-2012, 06:51 PM | #1 |
Rock Crawler Join Date: Dec 2008 Location: Marengo, Ohio
| 1:6 H2 Full Independent Suspension
Here we go guys, its been a while since ive posted a build thread, well over a year. Acquired a 1:6 New Bright Hummer and just sealed a trade deal for a nice emaxx, so i have to put the 2 together... Plans are, stretched emaxx, probably have to narrow the arms like a previous emaxx build i did a couple years ago. Lockers front and rear 2.8 wheels with my custom 2.8 Ridgelines, one shown in pic, i have to order more to make. Will be wiring up as many lights as possible, and seeing about adding some music as well, theres a speaker in the rear, and i have an old cheapy china MP3 player laying around too.... hmmmm.... Donor maxx. Last edited by ScalerLover; 07-02-2012 at 06:37 PM. |
05-06-2012, 08:41 PM | #2 |
| Re: Maxx Based H2
Picked up a few goodies while working at the LHS today. Losi Ten T wheels, might black out the centers to give them the Mall Crawler look Body is way too high as of now, need to pull the trans and ill be moving it to run a t-case. You can kinda see here how much i removed from the front arms, so far ive taken 1.5" from the inside of them, may remove some from the outer end still. I like how these Ten T wheels come with a nice center cap, look like lock outs. |
05-18-2012, 05:28 PM | #3 |
| Re: Maxx Based H2
Couple better mock up pics, have more tires on the way. Chassis stretched, could have turned out better, but this is a budget build after all. |
05-23-2012, 05:23 PM | #4 |
| Re: Maxx Based H2
Modified the upper arms more and threw the shocks on it so i dont have to prop it up for pics anymore Front toe links still need adjusted, had to make new ones since the track is narrower. Notice the shiny spot on the front left (right - from inside vehicle terms) thats how much i added to make the 2.2s into 2.8's. |
06-29-2012, 12:40 PM | #5 |
| Re: Maxx Based H2
Been a bit since i worked on the H2, picked up some more aluminum angle last weekend and my WK trans for the t-case came yesterday. I reworked my chassis extension as i wasnt happy with my first hack job. This is close to how i extended a previous emaxx build. Body mounts next ! Made these at work today out of .090 Aluminum, front and rear plate with uprights that will bolt to the stock bumper locations of the emaxx bulkheads. |
07-02-2012, 06:36 PM | #6 |
| Re: Maxx Based H2
Got the body mounts done fellas, we're getting there..... Front Rear Hole where the trans will sit once mounted to the chassis Stance ! |
07-05-2012, 07:09 PM | #7 |
Rock Crawler Join Date: Apr 2012 Location: Chattanooga
| Re: Maxx Based H2
That looks really good bro! I like your body mounts, chassis extension, and the narrowing of the suspension. Can't wait for a video! |
07-05-2012, 07:38 PM | #8 |
| Re: Maxx Based H2
Thanks bro, i had to take my body mounts back to work and weld another piece of 1/8" on top of the angles just to raise the body that much to clear the 2 speed, it still touches but it fits. Drew up a CAD template tonight, gonna cut and bend it tomorrow at work and get the 2 speed and t-case mounted tomorrow. |
07-06-2012, 06:53 PM | #9 |
Pebble Pounder Join Date: Nov 2010 Location: hillsborough nc
| Re: Maxx Based H2
Looks great josh
07-07-2012, 02:38 PM | #10 |
| Re: Maxx Based H2
^^ Bryan ? lol. Thanks man. 2 Speed, T-Case, Shafts installed. |
07-09-2012, 12:34 PM | #11 |
| Re: Maxx Based H2
nice job on the narrowing. could you drop the body a bit with a little bit of trimming?
07-09-2012, 01:29 PM | #12 |
RCC Addict Join Date: Jan 2009 Location: Jacksonville Illinois
I have that same body color and all, just no side mirrors. I need to sell it or put it to use. Good job here man!
07-09-2012, 05:38 PM | #13 |
| Re: Maxx Based H2
Thanks guys. Cory, the interior sits right on the emaxx chassis, and the wiper cowl on the body sits right on the motors lol. If i lower it any it'll be with shock adjustment and losing ground clearance. |
07-09-2012, 10:00 PM | #14 |
Pebble Pounder Join Date: Feb 2011 Location: lost
| Re: Maxx Based H2
that looks sick i did the same thing only with a 1.9 2 door jeep rubicon it sits a little high cause the 3d interior is sitting right up against the trans and chassis looks sick though!
07-10-2012, 09:24 AM | #15 |
| Re: Maxx Based H2
ah ok. those motors are definatly way up there
07-10-2012, 04:25 PM | #16 |
| Re: Maxx Based H2
Everything is as low as it will go, the 2 speed is sitting right down on the chassis, and cant be trimmed and dropped due to the emaxx steering components. Gonna throw some stiffer springs on it tonight, may end up moving the shocks around for a little drop. |
08-03-2012, 10:41 PM | #17 |
| Re: Maxx Based H2
Have a couple small updates. Decided to trim more of the chassis away, ill be making some aluminum trays, or possibly boat sides to hold lipos for here instead. Also kind of hard to tell, but the wheel centers are black. Still working on a shift servo mount, right now ive got it zip tied to the front of the shock tower, may just leave it if it works good |
Maxx Based H2 - Similar Threads | ||||
1:6 F150 - Maxx Based | ScalerLover | Large Scale Rigs | 29 | 06-29-2010 10:18 PM |
Overall specs for a Maxx-based crawler needed | dreadshawn | Newbie General | 0 | 10-30-2006 03:59 PM |
Here's my newly completed maxx-based thing. | Froshmasta | Traxxas Crawlers | 17 | 09-24-2005 08:42 PM |
Started my Maxx based crawler | sled | Traxxas Crawlers | 2 | 07-06-2005 03:41 PM |
