Go Back   RCCrawler Forums > Scale Rigs General Tech > Large Scale Rigs
Thread: stock jeep tires?
Old 08-28-2012, 02:07 PM   #1
Default stock jeep tires?
anyone use the stock tires that come with the hasbro jeeps? headquake has a video and he used them on his build ,i am looking for the size on the rim itself i am away from home and can't measure it myself.my plan is to make a mold of the tire and cast them out of eurathane rubber .they will be solid rubber tires .hopefully they will work,i have about 8 jeeps at home and want them to look as real as possible.thanks for any help given .
warriorsimi is offline   Reply With Quote
Old 08-28-2012, 03:07 PM   #2
~THE SCALE SHOP~
Default Re: stock jeep tires?
i wanted the same, i ended up narrowing some proline hammers, they came out really good and looked fairly close. i was really impressed with performance.
came out the same diameter as the stock plastic tires.
clicky
1/6 m-38
STANG KILLA SS is offline   Reply With Quote
Old 08-28-2012, 04:36 PM   #3
that was a sweet build are you making those chassis? also was that leaf sprung?
Old 08-29-2012, 09:26 AM   #4
Big Mike's Avatar
I pulled out the stock wheels from my Jeep, I was surprised how soft the tires are. Soft enough to be turned inside-out. If you could thin the carcass from the inside somehow, and cut off the rib on the outer circumference of the wheel that fills the tire, they might be half-decent (provided of course you could adapt the hexes from another wheelset)
Here's how a 2002 Hasbro wheel measures out:
Overall: 3 7/8" (across outside of rib)
Rim size: 3 7/16" (if you cut the rib off)
Bead: 2 15/16" to outside, 1/16" wide
These tires do have a bead of sorts, and a nice slot for the bead on the front side of the wheel. Not so much slot on the backside, the slot is in the ribs. Seems to me you could adapt the stock wheels pretty easily if you've got a little skill and imagination...
Big Mike is offline   Reply With Quote
Old 08-29-2012, 09:46 AM   #5
i have a mini lathe mill combo and when i get home from fire season i am going to sit down figure something out ,thanks for taking the time to measure the wheel i really like the look of the stock wheel and tire combo with leaf springs .i know it won't crawl as good ,but trying to keep it as real as possible .
Old 08-29-2012, 10:36 AM   #6
Don't the guys at rc4wd have something close to the wheels and tires?
HillbillyCrawler is offline   Reply With Quote
Old 08-29-2012, 12:27 PM   #7
Here you go.
These tires and wheels are pretty close.
https://store.rc4wd.com/Out-Croppers...res_p_727.html
https://store.rc4wd.com/22-Militants...ir_p_1728.html
Hope this helps.
Old 08-29-2012, 03:24 PM   #8
Originally Posted by HillbillyCrawler View Post
Here you go.
Hope this helps.
Those are close, but there not quite the same. They have some landies wheels that are even closer, but they are too small for a 1/6 willy. I wish they made them in a 2.2
OllllO Fanatic is offline   Reply With Quote
Old 08-29-2012, 06:15 PM   #9
Yeah that's all I could find in 2.2 that you could get away with. Have the right tires in 1.9
Old 08-29-2012, 08:13 PM   #10
i wish i was home to work on my rig,the plan is to make a mold of the original tire and modify an original rim so i can also mold it .hopefully if all goes well i'll have a rig with a hex and rubbery solid tires .wish me luck.
Old 08-30-2012, 08:34 AM   #11
~THE SCALE SHOP~
in my link i used RC4wd 2.2 Landy wheels.
yes i made the chassis. it was 4 linked.
Old 08-30-2012, 03:57 PM   #12
58_Willys's Avatar
FYI...Clod rims are the right dia. I am actually in the process of converting the clods to narrow rims and hex adapters. I'll be posting a how to soon. I used the sidewalls of the clod tires, and 2.2 Mil Spec tire treads.
58_Willys is offline   Reply With Quote
Old 08-31-2012, 12:00 PM   #13
i found the tires.they will have to be cut and shut.
Old 08-31-2012, 12:02 PM   #14
another set.
Old 08-31-2012, 05:30 PM   #15
I would think that the first set would have the most realistic look, but since they appear to be a 1.9 tire, I would think that you would need to separate the tread from the sidewall, add another section to it, then find an appropriate carcass to glue the tread to.
BigSki is offline   Reply With Quote
stock jeep tires? - Similar Threads
What all does it take to get stock high lift tires and rims to a stock tlt axle? bi_eep Newbie General 5 01-18-2007 10:54 PM
