08-15-2012, 07:57 PM | #21 |
I wanna be Dave Join Date: Sep 2005 Location: Dirty South
| Re: Badd's Southern Willys
I got some work done today . I cut and mounted a piece of speaker grill for the Willys grill . I wanted the grill open to let the heat out from under the hood . I also got my crusher panels finished and mounted . I gave them the brushed look . I will work on the brushed look more later . I have been kicking around names for this build . But tonite I settled on a name . So I went off and made the tag plate for it . I wanted a vintage looking plate . So here is what I came up wih . Last edited by Badd; 08-15-2012 at 09:10 PM. |
08-16-2012, 04:43 PM | #22 |
RCC Addict Join Date: Nov 2006 Location: southaven
| Re: Badd's Swilly
I like your plate Bob I need to find me some mesh to put behind my grill also. |
08-16-2012, 09:58 PM | #23 |
I got alittle more work done this morning . I worked on the grill and bumper . I ended up just cutting up the stock bumper for now . I made a flat alum. plate to cover the gap . I also found some off road lights I had saved from another build . I got the 4 links worked out and mounted the shocks to the axles . I got to space them out some . I also got to mount them to the body . I also got my light kit in . I got 8 white, 2 red & 2 orange . It will get 4 rock lights . Sent from my SCH-S720C using Tapatalk 2 |
08-17-2012, 11:04 PM | #24 |
| Re: Badd's Swilly
Few pics of the 4 link setup . |
08-18-2012, 01:03 PM | #25 |
well I got alittle more work done this morning . I put my comp wheels and tires on for now . But the wheels / tires I have coming are real close to this size . Sent from my SCH-S720C using Tapatalk 2 |
08-18-2012, 03:39 PM | #26 |
| Re: Badd's Swilly
Hell yeah, more AXR-10 axles! You're making great progress. |
08-18-2012, 04:00 PM | #27 |
little more to show today Sent from my SCH-S720C using Tapatalk 2 |
08-18-2012, 05:17 PM | #28 |
started thinking about lights . I got the head lights and front marker lights in. I also got the tail lights in . Sent from my SCH-S720C using Tapatalk 2 Last edited by Badd; 08-18-2012 at 09:55 PM. |
08-18-2012, 09:54 PM | #29 |
The tail light housings I bought at rat shack today . Part number for the housings is 272-0001 . I removed the lights that came in them and used my LEDs . I also painted a black ring on them .The last pic shows the light after I sprayed some black paint on the LEDs to tone them down abit . Sent from my SCH-S720C using Tapatalk 2 Last edited by Badd; 08-20-2012 at 09:28 AM. |
08-19-2012, 10:03 AM | #30 |
| Re: Badd's Swilly
If you need side reflectors, I make real reflectors that RCP Crawlers sells.
08-19-2012, 10:21 AM | #31 |
| Re: Badd's Swilly |
08-19-2012, 10:50 AM | #32 |
Rock Crawler Join Date: Nov 2010 Location: roanoke
| Re: Badd's Swilly
Killer rig!
08-19-2012, 01:25 PM | #33 |
Thanks still got along way to go and a short time ........ to get it done in . I want to have it running in about 2 weeks . I building it to take to Nationals . Sent from my SCH-S720C using Tapatalk 2 |
08-19-2012, 01:26 PM | #34 |
| Re: Badd's Swilly As much as I'd love to meet up w/ everyone at the NATS for a Willys trail ride, it's just too much on the finances right now. I figured around $500 round trip, that's just too much for a trail ride.
08-20-2012, 08:10 AM | #35 | |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
| Re: Badd's Swilly
Nice! The headlights are pretty bright, is that an LED shining through the stock headlight that comes with the Jeep? Or did you use different buckets? I have to put some lighting in Ol' Blue. Wintertime will be here before I know it, and that means gettin dark at 5pm. Quote:
I've had a lot of real car problems to pay for lately... Last edited by Big Mike; 08-20-2012 at 08:14 AM. | |
08-20-2012, 09:27 AM | #36 |
| Re: Badd's Swilly Yes that is the stock headlights . All I di was remove the part that the stock screw went into . I then used Shoe Goo to hold the headlights in . I drill the back of the grill to fit the LEDs and I was one . |
08-20-2012, 11:02 AM | #37 |
I got my whip mounted this morning . I will shorten the whip after the cage is done . I also remove the flat iron and put on a TSL . I don't have a spare 2.2 so the 1.9 will work . I also remove the grey from the rings and added buttonhead screws . I think it looks much better . Sent from my SCH-S720C using Tapatalk 2 |
08-20-2012, 11:14 AM | #38 |
| Re: Badd's Swilly
I like the antenna mount, it looks sturdy.
08-20-2012, 01:59 PM | #39 |
I got my trans case in today . I built it using Hot Racing hardend gears, Avid bearings , Axial hardend outdrives and Lithium grease . I just used a stock motor plate because I didn't have a heavy duty one . I ended up using my short JunFac shaft for the jackshaft . So I have got to find another JunFac for the front . Sent from my SCH-S720C using Tapatalk 2 |
08-21-2012, 12:39 PM | #40 |
I got the shocks mounted today . I also got my rock lights mounted front and back . Seats are painted and steering wheel . Still a lot to do but I think I might get it do for Nationals now . Sent from my SCH-S720C using Tapatalk 2 |
Badd's Swilly - Similar Threads | ||||
Badd's 2.2s say what ? | Badd | Axial AX-10 Scorpion | 100 | 09-17-2012 11:05 PM |
BADD's XR reborn | baddman | Axial XR10 | 26 | 09-06-2011 09:26 AM |
Badd's K-5 Blazer | Badd | 1.9 Scale Rigs | 399 | 06-17-2011 09:18 PM |
