09-07-2012, 12:30 AM | #1 |
Gold Star Baby! Join Date: Jul 2011 Location: Warren, MI
| 1/6 scale monster
Build sheet Widened kyosho mad force axles(with kyosho truggy gears) Tvp chassis made out of 1/8" 6061 aluminum Junfac 10mm rod ends with 5mm all thread sleeved with 1/2" white delrin for links Emaxx 3906 trans with metal gears and kershaw designs dual 970's Traxxas summit drive shafts modded to fit mad force pinion Savage flux battery mounts, evx 2 Front and rear steer with hitec 7955 servos Uses aluminum rod ends intended for losi aftershock shock ends Home brew front sway bar with 4130 chro moly rod (might do rear) New bright escalade body Imex jumbo kongs on modified ofna pirate wheels with jumbo Kong lip. Ofna Titan cva's Top shaft of trans has bean replaced with the newer model emaxx to use Robinson racing slipper. Off brand HPI baja shocks. Don't know if I like them yet. I still need the bec and radio before I can test it. I plan to make a roll cage for it. Will add weight so the springs might work better. It's a little stiff rite now.[IMG]WWW.crawler.com/forum/members/vwmopar-51866-albums2455-37230[/IMG] Last edited by vwmopar; 09-07-2012 at 12:32 AM. |
1/6 scale monster - Similar Threads | ||||
1/4 scale monster servo | MaxxZilla | Electronics | 0 | 11-14-2010 08:44 PM |
RC4WD 1/4 scale Monster Servo | monkeyracer | Electronics | 6 | 12-04-2009 05:07 PM |
scale monster truck | evilwheeler | General Scale Talk | 12 | 03-03-2009 07:44 PM |
Monster Build/ Scale Chassis | pureadrenalin | General Crawlers | 12 | 12-17-2006 07:39 PM |
Scale Monster Tach | canucksrc | Scale Accessories | 7 | 10-17-2006 02:19 PM |
