Go Back   RCCrawler Forums > Scale Rigs General Tech > Large Scale Rigs
Thread: Real Steel 1/6th F250 Project working class reborn
Old 12-15-2012, 09:28 AM   #1
Default 1/6th F250 Project working class aka " The Flying Brick"
i've been wanting to do a large scale build for a long time, recently got my hands on this body. The detail is amazing but....the utards at fastlane put the lift on upside down I feel it's my civic duty to corect it.
size comaparison to a tamiya 1:10 tamiya f350 body.
Diesel-tech is offline   Reply With Quote
Old 12-15-2012, 09:40 AM   #2
Default Re: Real Steel 1/6th F250 Project working class reborn
This build could take all winter, downed quite a few beers just staring at it leting the ideas flow.
And placed a huge order from rpp, rc4wd, VP and Ebay
Parts:
Rc4wd
2.2 Mickey T Baja mtz's
Wraith centered diff rear axle
king shocks
jugg/bruiser leafs
Megatruck universal shaft
VP:
wraith front axle case
chubs, knuckels and lockouts
wraith panhard kit
ackerman arms
akerman steering tie rod
misc:
Emaxx trans
Revo drive shafts
Revo pushrods
Dual holmes hobbies 7t pullers
Castle Mamba monster
G-Made XD 103mm diaphram shocks
savox SA-1230 servo 500 oz/in @ 6v
Highlift steering bellcranks
racers edge servo arm
Dual CC BEC's
Gearhead rc fabrication tabs
And I know thers more.
Old 12-15-2012, 03:01 PM   #3
Looks like one hell of a build, very interested to see how it all goes together.
richo119 is offline   Reply With Quote
Old 12-16-2012, 03:17 PM   #4
Got a little work done on it today, Mocked up a frame still waiting on a pile of parts before i set the width in stone or add the crossmembers and body mounts but I know where I'm going with it.
Frame is 1" square steel, split down the middle and seam welded I also filled in the c on both sides to more resemble a stamped chassis. The welds and joints will get cleaned up and filled in after final assembly then it will get sent out for powdercoating.
this is close to where the final ride hight will be. a little on the high side I think
Old 12-18-2012, 02:38 PM   #5
Well It's my birthday..just another day anymore.
Got a shitload of parts in and started puting some stuff together. Drank more beer than anything.
Got the axles assembled and started fabbing up the front link/shock mounts.
Also got my g-made shocks assembled and set the frame width at 4 1/8th"
thats all for now..back to my beer
Old 12-18-2012, 06:39 PM   #6
Nice body and nice start too. Ill be watching this I have a 1/6 chevy I have been wanting to to .
paleblue46 is offline   Reply With Quote
Old 12-24-2012, 12:13 PM   #7
Got a little more done tinkered with some link and shock mounts and fabbed the body mounts.
This set up worked out really well.
the interior sits between the lower black rails and the actual body. So the lower rails are mounted directly to the frame with a nice little o-ring for a bushing and the interior can stay chassis mounted or be removed with four screws from the bottom side.
I will be mounting the electronics in the unused space under the back seat and will still be able to remove the body without unpluging everything
Old 12-24-2012, 12:20 PM   #8
Also fabbed up the front shock mounts and panhard brace got those welded into place so now the front end is self supporting.
Thats all for now..
Old 12-24-2012, 12:40 PM   #9
keeping an eye on this. looking foward to some dual motor video!
ah_5500 is offline   Reply With Quote
Old 12-24-2012, 05:10 PM   #10
So this is what that trans is going into. Sweet rig I like it.
I'll pm you the tracking number, you should see the trans friday according to fed ex.
WHITE-TRASH is offline   Reply With Quote
Old 12-26-2012, 01:56 PM   #11
Well dinked around with it a little bit more today while i've got the time gotta go back to work tomorrow. I at least wanted to get to a roller
Fabbed the rear spring hangers. This was my first attempt at brazing and I quickly figured out that i'm a much better welder than a brazer but I was getting the hang of it. I'll probably redo the spring hangers to clean them up a little bit but these will work for now.
Also made the u-bolts lift blocks and plates, I know i'll end up redoing these I kinda rushed a bit...oil burner in the shop crapped out on me so that will be my next project
And a couple flex shots the articulation is awesome may have to stiffen up the rear a bit if it's gonna pull a trailer
All for now
Old 12-30-2012, 05:36 PM   #12
Im in love!!!!!!
2manyprojects is offline   Reply With Quote
Old 12-30-2012, 08:23 PM   #13
That is such a sick body to start with! Nice fab work as well! Why not a summit trans? I would think the 2 speed would be handy. Also any plans for a 2wd/4wd setup?
dealwithit is offline   Reply With Quote
Old 12-31-2012, 05:51 AM   #14
I thought about the summit trans but I really like how centered the 3906 emaxx trans is and after mocking it up it just lokks kick a** in the engine compartment and those twin pullers will have plenty of range.
And for the 2wd/4wd...I've been racking my brain on that one thought about taking the rc4wd R2 1:1 ratio trans and the r2 disco trans and combining a few parts to make a selectable transfer case out of them but still debating on whether or not it would hold up? this rig will probably weigh 25+ pounds I need something tough.
Old 01-04-2013, 04:00 PM   #15
Got a little more done to it today, starting to come along nicely.
I raised the front chassis link mounts. With no weight on it they didnt look to bad but after adding close to 5 lbs with body motor etc.. they ended up parallel. I also dug through the workshop and found some 7/16 rubber bump stops that look alot more like body bushing and give it an overall higher stance.
also got the motor/main gearbox mounts fabbed up and fabbed the steering set up.
Bellcrank is from hot racing its a hop up for a tamiya highlift. I brazed a gearhead rc fabrication tab to the VP ti tie rod and used an old bent revo turnbuckle for the draglink, also fabbed some servo brackets to mount along the frame behind the motor. ran all the linkage and i'm impressed at how well it looks and functions..I figured i'd at least have to redo it twice to get it right
it'l be a snug fit in the engine compartment once i get the fenderwells in place and start adding the scale accesories but im sure I can fit it all in there somewhere.
thats all for now feel free to weigh in on this one Im second guessing myself so much I'm starting to not like working with me..lol
Old 01-04-2013, 08:34 PM   #16
To me the tires look too small, everything else is looking great though!!
badBKO is offline   Reply With Quote
Old 01-04-2013, 09:49 PM   #17
you have a good eye, looks very cool, what is the weight you think you will end up with.
squatch71 is offline   Reply With Quote
Old 01-04-2013, 09:54 PM   #18
That's a very nice start. You going to make all those subs into real speakers?!?
ky_ace is offline   Reply With Quote
Old 01-04-2013, 10:10 PM   #19
The MTZ's are perfect size to tuck up into the wheel well, If I go much bigger I'd either have to trim the body ( kind of a crime IMO ) or raise the whole rig and make it very top heavy
Havnt thrown it on the scale yet but I'm guessing upwards of 25-30lbs with battery and all
It came with an fm tuner in the bed, I thought about adding a radio but the speakers in the back seat probably will just be for looks
Old 01-04-2013, 10:16 PM   #20
Wow, great looking build so far! Centered rear axle and front dual lower links set it off.
Szczerba is offline   Reply With Quote
Real Steel 1/6th F250 Project working class reborn - Similar Threads
Gavin's Class 2 SORRCA Toyota Truggy reborn - the 3rd & 4th time now Nova's Ark 1.9 Scale Rigs 96 08-14-2019 01:05 PM
Project "working class superduty" true scale Diesel-tech 1.9 Scale Rigs 10 05-21-2011 09:36 PM
reborn tlt project tltcrawlerxtrem Tamiya TLT Crawlers 20 02-17-2007 01:52 PM
New 1/6th Nylint Not Working mulchman General Crawlers 2 04-11-2006 08:07 PM
