09-29-2006, 05:14 PM | #101 |
Rock Crawler Join Date: Jan 2006 Location: In the basement
Big, burly, angry, sharp lines, and maybe some teeth painted on it like the front of airplanes? or not. Something that is just huge and gnarly will be perfect. |
09-29-2006, 06:22 PM | #102 | |
I wanna be Dave Join Date: Dec 2005 Location: between heaven and hell.
09-30-2006, 11:07 AM | #103 |
Well I don't have pics till monday. but I mounted the front servo on the frame and made it look kinda like a 1:1 steering set up *KINDA* but I had to put it on the right side :( I may do it with the rear steering but well see. I hope to have it running today and see how it drives. |
10-02-2006, 09:18 AM | #104 |
Well I was under the weather this weekend and didn't get a whole lot done. But here is the pics of the front steering set up. I need to make the arm for it to turn the wheels. I just didn't feel like getting out of bed to much.:-( |
10-02-2006, 01:54 PM | #105 |
Pebble Pounder Join Date: Jan 2006 Location: Calgary Alberta Canada
That thing is insane I like it. I would want it if it wasn't a clod LOL.
10-02-2006, 02:08 PM | #106 | |
10-02-2006, 02:36 PM | #107 | |
Rock Crawler Join Date: Feb 2006 Location: glastonbury
10-02-2006, 05:32 PM | #108 |
I'll try to mount the second servo and install the motors (still not feeling well). I just received the motor mounts so I'm wanting to run this thing... Oh and my neighbor just received a load of rocks just sitting in their front yard waiting for something to go over them I'll be driving before powder coating and painting this thing. I also need to fix the ESC my son decided to cut the wires. I shouldn't of let it out. glad you like it so far. |
10-05-2006, 03:57 PM | #109 |
Well I haven't had much time to anymore to BFR and I RRRRRRREEEEEEEEEEAAAAAALLLLLLLYYYYYYYY want to drive it.. Sorry customers but a MAN has to do what a MAN has to do. I'll work on it all night so I don't take much time away from customers. |
10-05-2006, 06:25 PM | #110 | |
Rock Crawler Join Date: Feb 2004 Location: Michigan
10-05-2006, 06:28 PM | #111 | |
10-05-2006, 07:05 PM | #112 | |
I came in at 7 - 7.5 lbs. I think I'm doing good for a 19" WB SCALE clod. I think when I'm done and a body on it will be around 9 - 10 lbs. | |
10-05-2006, 07:12 PM | #113 |
RCC Addict Join Date: May 2006 Location: Roseville
Um, wow is about all that comes to mind when I look at this monster. Looks awesome man!
10-06-2006, 09:48 AM | #114 |
RCC Addict Join Date: Jul 2006 Location: Johnston SC
you better make a kick*** trailer using matching wheels and stuff to haul your other masterpiecs around
10-06-2006, 09:53 AM | #115 |
I will for sure.
10-06-2006, 07:57 PM | #116 |
Quarry Creeper Join Date: May 2006 Location: Georgetown, Texas
This is bad ***, for the bumper, do, mean as hell!!!
10-09-2006, 05:31 PM | #117 |
The steering is a nifty setup. Will you have problems under flex, or is the shaft telescoping?
10-09-2006, 06:39 PM | #118 | |
It moves through a hole on a plate that is attached to the axles. Keeps it in place. I'll try to get more done soon. I didn't get a chance to work on it like I had wanted to . :-( | |
10-09-2006, 07:00 PM | #119 |
Well, my thought is with a solid shaft when the axle moves up and down the distance between the servo and the axle will change. Does the shaft have a slider that I am missing?
10-09-2006, 07:07 PM | #120 |
Rock Crawler Join Date: Aug 2005 Location: White Lake
Great looking cxt!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
