05-03-2013, 03:10 AM | #1 |
Rock Stacker Join Date: May 2013 Location: Germany
| Dragon 1/6 SAS 4x4 Desert Raider
Hi My name ist Tom and I'm from Germany. Having built several Rigs from 1/16 to 1/6 before, I was able to get a good deal on a Dragon Desert Raider Willys Jeep kit. The basic idea was to make a civilian version out of it, but during the build I decided otherwise and stick to the desert type. Actually, I hadn't expected such a huge box... At the same time I was able to get a chassis from ebay UK that had been built to suit a similar project. But after it arrived, I was totally shocked about the terrible way it had been made. Also, it broke during transport. The frame was made from some undefinable material the had the characteristics of wood..., the leaf springs were made from circuit board material, the rest - see for yourself... Fortunately I was able to negotiate a reduction due to the damage, so the money was well spent for the Bruiser axles, motor, etc. which I could all use for my project. So I did. Since this would become a scaler which wouldn't be used in rough terrain I wanted to stick to the kit frame which would later be strenghened a little. I replaced the leaf springs with some from the original bruiser - which are a little too short, but I think it's barely noticable - and also used the wheels that came with the chassis and werde already modified to fit to the axles. Also, they werent as "wobbly" as those from the Dragon kit. The rest was easy play and a first testrun was very satisfying... to be continued... Tom |
05-03-2013, 03:33 AM | #2 |
| Re: Dragon 1/6 SAS 4x4 Desert Raider
I wanted to realize a few technical gadgets... First was the ilumination of the dashboard. Since the old willy's gauges are not iluminated from the back but from top, I simple shaped out the dummy lights of the kit. Next came the steering wheel. I wanted it move together with the steering (the driver's head will later also move in the direction of the steering... ). so I placed a micro servo directly behind the place where the steering column is located. I glued a hort piece of brass tube into the steering wheel an in that a 3mm threaded rod of the correct length. I also used the original steering column and shaped it out so the 3mm rod could go through it. I then drilled a hole in the center of the servo so I could simply screw the 3mm rod tightly into it. First tests have proven it ro be secure and moving just the way I wanted it. To be continued... Tom |
05-03-2013, 03:39 AM | #3 |
Next was to beuild the Jeep itself which was e real joy. I was particularly fond of the great detail it has. Here are some pix of it with only its base color. Also, the crew is not the final one yet, they are just "test sitting" To be continued... Tom |
05-03-2013, 03:45 AM | #4 |
Having had so much fun building the kit I decided to wait with the rest of the technical details and continue with some details on the vehicle. I enjoy aging my vehicles, so I started with some parts. Her are shovel and ax: One of the seats: The dashboard: The dashoard iluminated (I used yellow colored LEDs to give it a warmer look): That's about all for now. Check back in a couple of days, I'll post new pix as soon as there's progress... Tom Last edited by Tom22; 05-03-2013 at 03:57 AM. |
05-03-2013, 07:00 AM | #5 |
Pebble Pounder Join Date: Jun 2012 Location: las cruces
Awesome build so far man keep it up you going to do a scale vid when your done
05-04-2013, 03:48 AM | #6 |
Thanks for your nice words... (I hope there are more of you interested and this doesn't remain a "one man show"...) I'm not so much of the technical guy but prefer the more creative work. Anyway, I had to get going with the steering and other technical aspects, which I've done yesterday. Since the knuckles of the old Bruiser axles don't withstand much force, I made new ones from brass profiles. Now it's sturdy enough. Placed the steering servo directly behind the radiator without having to cut too much away. Having done this, I'm pretty much done with the technical side. There's enough room under the hood for all the other electronics. This means I can now focus on what I like to do most: painting, aging, adding detail. More to come... Tom Last edited by Tom22; 05-04-2013 at 03:50 AM. |
05-04-2013, 08:30 AM | #7 |
Rock Crawler Join Date: Jul 2010 Location: youngstown , Hillbilly heaven
Looking clean man. I like it. Im thinking about getting a dragon also. Have the 21st body and like it a lot.
05-04-2013, 12:29 PM | #8 | |
| Re: Dragon 1/6 SAS 4x4 Desert Raider Quote:
I also have one of these from 21st Century Toys and am thinking about converting it to RC as well. Only problem is, mine is in mint condition, never been played with and still in the box, so I'm a little hesitant to cut into it to make RC components fit... But with your solution there isn't much cutting and if I use MOAs I might get around cutting altiogether. I'll see... In the meantime here are some new pics. Managed to finish the chassis and have been aging it, together with the wheels. To be continued... Tom | |
05-04-2013, 05:54 PM | #9 |
Next was the driver. He should be able to move his had together with the steering. First thing was to open the torso of a Dragon figure (tough job...). Then I took a micro servo an glued it in the opening using hot glue. Looks ugly, but works... Next was to glue two servo horns on top of each other in order to place the head high enough above the body. I drilled a small hole in the lower horn and screwed a tine screw in it so that I can fix the head later to the servo. The arm that holds the steering wheel needed to be VERY flexible, so I seperated all the limbs and connected them losely with a piece of wire. The whole assembly was then fixed with another piece of wire to the torso using hot glue again. Now it moves absolutely freely. Head connected to the body... ... and dressed. Bingo! More to come... |
05-05-2013, 01:17 PM | #10 |
Ooh, I just hope, there is a little more interest for my project and I don't write all this for nothing... . In the meantime, here's a short video of the driver. Tom |
05-05-2013, 01:19 PM | #11 |
Pebble Pounder Join Date: Apr 2013 Location: Nacogdoches
I think it's pretty kick a$$ myself. Keep posting the updates dude. I think this thing is cool!!! I'm thinking of trying to pick up the European Theater model myself. I probably would have never thought this stuff up on my own...lol Last edited by TriggerMan; 05-05-2013 at 01:22 PM. Reason: add to |
05-05-2013, 04:30 PM | #12 |
Newbie Join Date: Sep 2011 Location: yankton
You have my attention! Very cool
05-05-2013, 04:40 PM | #13 |
Rock Crawler Join Date: Oct 2012 Location: Casper
Just found this thread but, so far, I'm loving the build. You seem to have a good eye for detail and I can't wait to see where this goes.
05-05-2013, 07:59 PM | #14 |
Pebble Pounder Join Date: Jun 2011 Location: AREA 51
I'm really liking this build. |
05-06-2013, 08:27 AM | #15 |
Quarry Creeper Join Date: Jan 2011 Location: Lyons, MI
Very nice attention to detail...moving head and steering wheel..why didnt i think of that. Keep up the great work masterpieces like dont go un-noticed, just have alot of jeleous people behind the scenes |
05-06-2013, 10:41 AM | #16 |
Thanks! Here are some more "teasers"... To be continued... Tom |
05-06-2013, 11:56 AM | #17 |
Looks great, nice job on all the scale details. |
05-06-2013, 08:53 PM | #18 |
Great build, I like how well the Bruiser axles look under the jeep. |
05-06-2013, 09:05 PM | #19 |
Quarry Creeper Join Date: Jun 2008 Location: Hell
Sick! how did u get the metal finish under where the paint is worn through? Is the body steel or plastic?
05-06-2013, 10:34 PM | #20 | |
The car was painted using spray paints. First a basecoat with primer, then the base color (RAL 7002). The weathering was done using powder colors of various yellow and brown shades as well as rust color, applied with brushes and sometimes bare fingers. Everything was then fixed with a VERY light dull clear coating. Finally, the metal effect was done using Valejo "Chain Mail" applied with the dry brush method, i.e. VERY slightly with a small dry brush over edges and so. Tom | |
Dragon 1/6 SAS 4x4 Desert Raider - Similar Threads | ||||
92 TOYOTA 4x4 sas | oahuzuki | Micro Scale Rigs | 24 | 04-13-2014 09:57 AM |
Bearded Dragon or Water Dragon. | Hydro-Tank | Chit Chat | 19 | 05-10-2013 02:38 PM |
will the raider fit? | freakofnature | Losi Mini-Rock Crawler | 0 | 09-17-2009 09:46 PM |
