09-02-2013, 01:13 PM | #81 |
Rock Crawler Join Date: Feb 2012 Location: Wisconsin
| Re: Behind Enemy Lines
Hmmmm, how do I put holes into this? And do it easily... I got it! Grab my trusty suppressed bolt gun and shoot some holes into it !!! POP!!! Nice work !!! Now I've got to make a bunch more. There... finally done. I think I made enough of them for the project. Last edited by Fumbles; 09-02-2013 at 01:17 PM. |
09-02-2013, 03:18 PM | #82 |
RCC Addict Join Date: Nov 2009 Location: Tulsa
I need to get me one of them bowie knifes they can do anything! Awesome build.
09-03-2013, 09:20 PM | #83 |
| Re: Behind Enemy Lines |
09-03-2013, 09:24 PM | #84 |
Fits front to back but looks like I've got to do something to work around the rear wheel wells though... Hmmmmm..... I like the idea of a rear bumper at this location but I've gotta come up with a way to follow the body with the chassis so that I can get travel on the rear suspension... Last edited by Fumbles; 09-03-2013 at 09:38 PM. |
09-03-2013, 10:44 PM | #85 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
Does this GI have a name ??? He's pretty handy...
09-03-2013, 10:46 PM | #86 |
RCC Addict Join Date: Jan 2011 Location: Wheat Ridge
Sister up another piece of square tube to dip into the chassis/body.
09-03-2013, 11:57 PM | #87 | |
| Re: Behind Enemy Lines I was thinking of "Sarge" but I guess a naming contest is in order? Quote:
One thought was to cut it off short where it separates from the body pan at the rear area and attach it flush to the floor of the body, then I can attach my links to the end of the metal frame rails and the shocks to the inner wheel wells thereby eliminating anything in the rear area... downside is that there is not a solid mount for the bumper. I ordered some 1/2" steel square tubing (as no one makes 1/2" x 3/8") but it was too large for scale and damn heavy! I'd like to do a C channel type of frame but can't really manufacturer it myself. Steel would be optimal as I can Mig stuff onto it like trans & engine mounts. I can't really work with aluminum other than cutting it to length & drill/tap it... Last edited by Fumbles; 09-04-2013 at 12:10 AM. | |
09-04-2013, 12:21 AM | #88 |
Rock Crawler Join Date: May 2012 Location: Upland
this is awesome
09-05-2013, 12:27 AM | #89 |
Time to give myself a haircut. Just swipe the 'ol Bowie knife over my scalp and get rid of some of that stubble. Then shave off some of the 3 day growth going on... CAUSE THAT'S WHAT REAL MEN DO....... THEY SHAVE WITH A BOWIE KNIFE !!! Last edited by Fumbles; 09-05-2013 at 12:29 AM. |
09-05-2013, 08:30 AM | #90 |
Depending on whats available, if you can get 1/2" x 3/4" square tube steel or aluminum you can rip it in have and get c channel stock which you could bend and hammer at least a small "whoop" in it kind of like the SCX10 chassis rails. I used 1/4" x 1/4" solid aluminum square stock on the Rustbusket, bent easily and braced with aluminum tube tapped to take M3 hardware. |
09-05-2013, 08:57 AM | #91 | |
| Re: Behind Enemy Lines Quote:
I've put some feelers out there with some of the boards chassis builders but no one's responded so I'll just solve it myself. I've got some rectangular shaped steel tube that I could rip in half to make C channels, chop saw it in places & Mig the frame up. I'd like to use the aluminum but don't have a Tig... Maybe go find one on Craigslist. (My wife isn't reading this... right?) | |
09-05-2013, 09:06 AM | #92 | |
Come on cupcake you're a big guy, put it in a vise and crank on it! If you use the 1/4" x 1/4" aluminum square stock you don't need a Tig. I've bent pu a couple chassis' with it all by hand with just a vise, cross braced and you're good to go Last edited by The Crawl Space; 09-05-2013 at 09:08 AM. | |
09-05-2013, 09:19 AM | #93 | |
LOL! Dude - I already tried that. The workbench tipped up off it's legs and it's a heavy table. I had nearly 6 feet of breaker bar on it. I'll figure something out soon. I'll be home on Friday so I'll get back on it this weekend. There's a muscle car fabricator nearby so I'm going to drop by his house and see what he might have in his shop that I can use to whack the frame into submission... (edit: better word choice... not whack but work) Last edited by Fumbles; 09-05-2013 at 01:02 PM. | |
09-05-2013, 11:13 AM | #94 |
Will hear ruin the integrity of the metal? Sent from my PG86100 using Tapatalk 4 |
09-05-2013, 01:23 PM | #95 |
How about 'ole Sarge man-handles that cut off tool and makes recesses in the floor board for the frame to sit flush with the rest of the body?? |
09-05-2013, 01:47 PM | #96 | |
Sarge told me that he could do it with his fingers if I gave him the green light... says he's pissed at it. I told him to save his anger for the Jerries... | |
09-05-2013, 07:32 PM | #97 |
I see what you mean, I looked closer at the pics and realized that your body is structured differently from the Hasbro bodies. I actually like the way your body has the front section of the "chassis" molded into the main body, it will be Uber sturdy once you get those frames rails in there. Any way to get a piece of flat bar stock and use it as a filler between the body and frame rails? That would give Sarge a sturdy chunk of real-estate to bolt things to if he needs it. Can I offer a suggestion to you in regards to chassis construction? Last edited by BigSki; 09-05-2013 at 07:34 PM. |
09-06-2013, 04:41 PM | #98 | |
ABSOLUTELY! I'm always open to suggestions and critique. Never done one of these before and I'm definately not a fabricator so it's a steep learning curve. I was away from a computer for a while...sorry. I used to have a GI Joe body (wish I'd have kept it) but the 21st Century body is a bit different and longer/wider overall. I'll probably do a GI Joe jeep after this one so I'm always looking for input! | |
09-06-2013, 06:04 PM | #99 |
Pebble Pounder Join Date: Nov 2008 Location: Glen Allen-VARCOR
I'v read through the posts about the frame problem and I think I understand what your trying to do. My metal working experience leads me to think you could either cut the rails a little bit past the drop off and have a second piece cut to fit down in the recessed area the bolt them together with support plates on either side as illustrated below. Or drill a clearance hole through the top of one and tap the other and bolt them together to eliminate the need and sight of a support plate on the side. Last edited by Metal Militia; 09-06-2013 at 06:07 PM. |
09-06-2013, 08:13 PM | #100 | |
I'm really wanting to cut the rail at an angle, run it at a 45 degree angle or so then follow the body line again to the rear and drop it down to allow a bumper attachment point. Since there is no bumper now that is kind of what I'm leaning towards. Sistering up a piece like this is what I'll have to do if I can't get some Tig welding done here locally. | |
Behind Enemy Lines - Similar Threads | ||||
Operation Black Ops: "Behind Enemy Lines" Part 2 Axial Jeep Unlimited Rubicon JK | LetsGoMuddin | Scale Videos! | 0 | 06-02-2012 11:28 AM |
Operation Black Ops: "Behind Enemy Lines" Part 1 Axial Jeep Unlimited Rubicon JK | LetsGoMuddin | Scale Videos! | 2 | 06-02-2012 11:27 AM |
door lines and panel lines (sharpie alternative) | heinie_21 | Paint and Body | 10 | 12-23-2011 08:32 AM |
Wolfenstein Enemy Territory (free download)anyone get into it? | TheHeadHunter | Chit Chat | 12 | 06-15-2008 07:41 AM |
