08-30-2013, 11:47 AM | #1 |
Quarry Creeper Join Date: Apr 2008 Location: PNW
| motor suggestion 1/6 willys
Just a quick survey of what motors you willys guys are running. I have seen some people run 35t, 55t, 80t, brushless, pullers etc but what seems to be the most successful setup?
08-30-2013, 12:56 PM | #2 |
RCC Addict Join Date: Jul 2006 Location: barstow
| Re: motor suggestion 1/6 willys
Great question as I was curious also especially with these being in the 10+ lb range
08-30-2013, 01:33 PM | #3 |
Quarry Creeper Join Date: Jan 2012 Location: Home
I had an 80t but it just didn't have enough wheel spin. Even my 55t may need to be swapped out for a 35t, as it has very little wheel speed with the 2:1 disruptor transfer case.
08-30-2013, 02:09 PM | #4 |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
10t Cobalt Puller works for me. A good combination of controllable low-end grunt and good wheel-speed on 3s...
08-30-2013, 03:14 PM | #5 |
Quarry Creeper Join Date: Sep 2010 Location: where ever I layed my hat.
| Re: motor suggestion 1/6 willys |
08-30-2013, 05:25 PM | #6 |
I was thinking about a 35 turn holmes torquemaster but I am worried about having enough torque. I am going to use a built axial tranny hooked to the 2 to 1 rc4wd transfer case with a 3s.
08-30-2013, 05:42 PM | #7 |
Find a 550 size motor. Added torque for those big things.
08-30-2013, 06:56 PM | #8 |
| Re: motor suggestion 1/6 willys I run a HH Torque Master on 3s, there's PLENTY of torque on tap. If I get the wheels bound up badly, I can easily snap axle shafts. My pig weighs in at 14 lbs.
08-30-2013, 08:48 PM | #9 |
cool, thanks for the info.
motor suggestion 1/6 willys - Similar Threads | ||||
Motor Suggestion needed | Mysterious | Axial XR10 | 31 | 05-10-2012 06:35 PM |
suggestion on motor! | MayhemZZ | Team Losi Comp Crawler | 12 | 11-21-2011 07:20 PM |
motor suggestion with Mamba Max? | bassguitar | Electronics | 1 | 07-08-2009 08:19 AM |
need a suggestion on motor timing | spike | Electronics | 6 | 11-15-2007 09:11 PM |
