08-29-2014, 09:27 PM | #81 |
RCC Addict Join Date: Aug 2005 Location: New Oxford PA
| Re: Derstine's HotRod willys
it was cool seeing this run last weekend. Here are pics of the willys from the PA jeep show i was telling you about. it might give you some ideas. There is even a video of it. https://www.youtube.com/watch?v=_qU1ALliaWE Keep up the good work! |
08-30-2014, 08:18 PM | #82 |
SuperShafty.com Join Date: Jan 2008 Location: Visalia CA
Thanks man. That looks incredible. It certainly gives me some ideas for the grill area.
08-31-2014, 06:37 PM | #83 |
I joined the Band! Join Date: May 2006 Location: Between a rock and a hard spot!
| Re: Derstine's HotRod willys If you would have taken your time you could have popped the valve covers off and took the motor apart and installed the motor on the in side. Then mount the motor to the back of the block with the HPI gear reduction on the out side. Then run a drive shaft to the rear end. I have done a few of these 1:6 and 1/12 scale blocks. there a lot of fun and people can't believe how real they look. This jeep is going to be real eye candy when it's done! The last picture shows the parts that I left off so that heat wasn't trapped. I thought of using a fan if heat was a issue. Last edited by twissted; 08-31-2014 at 06:49 PM. |
09-24-2014, 12:27 AM | #84 |
Newbie Join Date: Dec 2013 Location: No Ca
Glad to see this is getting closer. Very cool build! I've got an idea for the front clip that came off it... Thought I'd tempt you |
01-24-2016, 01:24 AM | #85 |
yeah, actually lots of updates coming tomorrow.
01-24-2016, 08:19 PM | #86 |
I will be holding my breath!
01-30-2016, 05:35 PM | #87 |
promised updates are coming henceforthrightwidthednessish... have finally been able to spend some time on this. its really going to be built to be a show piece that i can take out and run when i want too. I was able to get my hands on some better scale looking parts for this thing. I have since installed. scale wraith knuckles and C-hubs. rear AR60 SSD steelies. guess we can start at the front and go backwards. I rebuilt the front axle assembly using nothing but the best ingenuity. albeit from VP which is always the best. The "axle" as it were is also rebuilt using 1/4" steel. the 3/8 was just too thick. Getting all the angles just right for the wraith scale knuckles was difficult but not impossible. just had to draw some pictures. starting the install of that aforementioned axle. i brazed on the link mounts as well. this was done so that i can easily make a 4 link setup in the front. also got some rear Bomber trailing arms. i have some nice UCFab ones on the way. its gonna look great. nothing too fancy in the rear. i got the AR60 in the back, and 4 linked. notice the crossbar between the lower links. this also acts a sway bar. i needed because of how the shocks were mounted. either way a solid rear axle isnt a bad thing here. should help keep the power down. flex! ok, onto the body, put some styrene on the front. tight fit around the motor had to trim the grill to get this on here, but i did, and it should look awesome when done. now all i gotta do is get the steering back on it. and complete the body. got some scale diamond plating that should help accent lots of parts. |
01-30-2016, 05:37 PM | #88 |
Quarry Creeper Join Date: Feb 2009 Location: Rocky Mountains
Holy smokes, that is incredible! Wow.
01-30-2016, 06:20 PM | #89 |
That's some engineering there mj |
01-30-2016, 09:07 PM | #90 |
Glad to see more progress! Keep it up!
01-31-2016, 09:48 AM | #91 |
head ovet to ebay, and search "1/6 engine" and start deciding. |
02-09-2016, 11:26 PM | #92 |
got a little more done. got some of the stoppy things for the front wheels. they just needed some extra detail. i had to make a tiny little bracket, but before that i had to hack saw into a brand new bracket for the VP brake kit. not an easy thing to cut into fresh outta the package. had some tiny 2mm scale bolts to make it all look good too. also got the UC Fab Bomber control arms on there too! and some wheel speed! |
02-10-2016, 08:03 AM | #93 |
RCC Addict Join Date: Jun 2006 Location: Maryland
Coolest use of trailing arms EVER!
02-10-2016, 08:14 AM | #94 |
Rock Crawler Join Date: Jul 2008 Location: Pearland, TX
This thing is super cool. interested to continue to see updates. Wes |
02-10-2016, 06:50 PM | #95 |
Quarry Creeper Join Date: Apr 2009 Location: San Diego,CA
Nice! I've been waiting for some updates on this. Cool front axle setup and the brake rotors are a nice touch.
02-10-2016, 07:01 PM | #96 |
Ya, I like them brake rotors too! |
02-10-2016, 08:20 PM | #97 |
Can't wait to see this make a run down Bob's ravine in the spring! |
02-10-2016, 08:52 PM | #98 |
I like it!
02-11-2016, 09:41 AM | #99 | ||
| Re: Derstine's HotRod willys Quote:
you done being burnt out yet man? | ||
02-11-2016, 06:51 PM | #100 |
almost
Derstine's HotRod willys - Similar Threads | ||||
derstine's willys | mjderstine | Large Scale Rigs | 137 | 05-28-2014 08:52 PM |
Hotrod | STANG KILLA SS | Chit Chat | 3 | 06-14-2013 04:25 PM |
hotrod chassied yota | hotrodsonoma | 1.5 Scale Rigs | 23 | 04-01-2011 09:39 AM |
Hotrod C-10 | hellbentrodder | Paint and Body | 4 | 05-10-2008 09:15 PM |
Icelandic Hotrod | Mechanicalbob | Chit Chat | 6 | 05-21-2007 02:56 PM |
