Boggers slow 1/6 jeep build...... Found this one on ebay at a decent price, so here we go. Plans are wraith axles, cage, bumpers and sliders. http://i260.photobucket.com/albums/i...ps8aa0affd.jpg |
Re: Boggers slow 1/6 jeep build...... Where did you get the body. That is a slat grill jeep, one of the first types made for World War II. |
Re: Boggers slow 1/6 jeep build...... According to his first line, I would guess eBay...:lmao: |
Re: Boggers slow 1/6 jeep build...... Quote:
Re: Boggers slow 1/6 jeep build...... nice. these things seem to be getting quite the revival in the last 3-4 months. i have two of my own already... |
Re: Boggers slow 1/6 jeep build...... Thanks for looking, this one is a 2002 hasbro. I finally had some time to work on this beast, transfer case came in and a good friend helped with the frame. Heres a pic, http://i260.photobucket.com/albums/i...ps3a8fc96c.jpg |
Re: Boggers slow 1/6 jeep build...... thats a BIG frame. dont see anything wrong with that. |
Re: Boggers slow 1/6 jeep build...... Thanks, i believe in over kill. I hope having extra weight will help the suspension work better. |
Re: Boggers slow 1/6 jeep build...... |
Re: Boggers slow 1/6 jeep build...... Got more done. I plan to redo the upper links at a later time. Next up is shock placement. Thanks for looking. http://i260.photobucket.com/albums/i...psde968436.jpg http://i260.photobucket.com/albums/i...ps72f1e231.jpg |
Re: Boggers slow 1/6 jeep build...... :mrgreen: WHOOO HOO! Got a roller tonite. http://i260.photobucket.com/albums/i...psbf7ef5d5.jpg http://i260.photobucket.com/albums/i...psb3d389ba.jpg http://i260.photobucket.com/albums/i...ps47d75198.jpg http://i260.photobucket.com/albums/i...psd680917b.jpg http://i260.photobucket.com/albums/i...ps19a5b94f.jpg:twisted::twisted: |
Re: Boggers slow 1/6 jeep build...... how do you find the articulation with equal link lengths........does axle cycle straight up and down, or does it want to swing up and away.........i ask cause i had a similar setup, then changed to shorter bottom links, and then it cycled properly...... by the way wicked build.....definitely going to pick one of these up for my next build..... |
Re: Boggers slow 1/6 jeep build...... This setup has a little bit of a arc, dosent rub except for the front at full lock. Other then that im happy with it. Thanks for lookin. |
Re: Boggers slow 1/6 jeep build...... Mocked up and ready to measure for drive shafts. I'm hoping to have this monster driveable in a month or two. http://i260.photobucket.com/albums/i...ps1c668c34.jpg |
Re: Boggers slow 1/6 jeep build...... Sweet jeep! what type of gear reductin are you going to use? http://i628.photobucket.com/albums/u...ted001-4-1.jpg |
Re: Boggers slow 1/6 jeep build...... The HPI gear box is the most compact! |
Re: Boggers slow 1/6 jeep build...... I'm using a scx10 transmission with upgrades to feed a rc4wd disruptor transfer case with 2.18:1 gearing. I'm pretty sure with a 87 tooth spur gear and 17 pinion gear it should work fine. Thanks for looking. Also drive shafts should be here in a few days, cant wait :twisted: |
Looking good my friend. Subscribed. N8's SG3 using Tapatalk Pro |
Re: Boggers slow 1/6 jeep build...... Finally got the roll cage done with help from a buddy. http://i260.photobucket.com/albums/i...ps9105c0be.jpg http://i260.photobucket.com/albums/i...ps7fab5b3a.jpg http://i260.photobucket.com/albums/i...pse0b424c5.jpg |
