Go Back   RCCrawler Forums > Scale Rigs General Tech > Large Scale Rigs
Thread: New Project (for me)
Old 02-02-2017, 07:24 PM   #221
Mike Flea's Avatar
Default Re: New Project (for me)
Thanks, I've seen this one before, and it really is amazing, the link worked to get me to the page, but the video on the page wouldn't work, but it's not a problem because I did see it before.
There's another one in Germany, built by 2 brothers, that's equally beautiful, that a co-worker sent to me a couple years ago.
The vision, skill, electrical and computer knowledge, as well as the expense it take to put one of these layouts together is overwhelming. Truly beautiful!
Mike Flea is offline   Reply With Quote
Old 02-02-2017, 07:59 PM   #222
kgb424's Avatar
The video was on my Facebook page a couple of days ago
So it might be dead now, I did watch vidoe
I like the 40 foot expansion bridge and the coal train with like 30 cars on it
One of my Uncles has scale trains and a bunch of them are the Pennsylvania Rail Road trains
And the landscape matches the real places in PA
The Detail level is crazy, I used to have some pictures of his trains and his layout
kgb424 is offline   Reply With Quote
Old 02-04-2017, 11:37 PM   #223
those massive train layouts are insane.
And I thought the set up at my LHS was cool
meh... it still is actually
just not that big 'cuz it has to fit inside a tiny store. Lol
https://youtu.be/TMXfeAzxchY
https://youtu.be/IMuMTC7YLr4
Was purdy cool to watch it being built.
crazy how much coin was spent on building this one
I can't even imagine what's invested in those massive layouts
TacoCrawler is offline   Reply With Quote
Old 04-19-2017, 07:19 PM   #224
Mike Flea's Avatar
Well Accucraft is taking their damn sweet time producing live steam engines, and I got tired of waiting. So I contacted Jason, from The Train Department, in New Jersey, and purchased a Roundhouse Sammie. It arrived today. I have a few detail items I want to install, as well as still needing to purchase the distilled water and butane needed to fire it up,(which I will do this weekend).
Old 04-19-2017, 08:45 PM   #225
Sweet... but I most like that #24 w tender
Old 04-22-2017, 07:33 PM   #226
Mike Flea's Avatar
I'll get a video up once I find my dad's tripod, as last time I did a video, it was suggested I use one.
I steamed it up for the first time this evening, made a couple mistakes, only had a 10-12 min runtime. 2nd steam up, went much better, got a 23 minute run. Every steamup will be a different experience, but it will also be breaking in the steam chests and valves for a smoother, and longer run each time. Max run time for this boiler and the fuel tank is 25-35 minutes.
At some point in time, I'll be adding a servo to the throttle. Chasing after the engine to adjust it got old quick, although maybe it'll settle down once it gets past the break-in period.
Old 04-22-2017, 08:32 PM   #227
Look forward to seeing your chase video
Exercise is probably good for ya
Old 11-05-2017, 08:49 PM   #228
Mike Flea's Avatar
Try this:
Old 11-27-2017, 05:31 PM   #229
B2E
Good stuff!
B2E is offline   Reply With Quote
Old 12-27-2017, 08:25 PM   #230
Mike Flea's Avatar
Playing in the snow at +2 F
When I cleaned the tracks, I wasn't aware of ice buildup in certain spots, so the video ends where the ice stopped the engine. By the time I chipped the ice off the tracks and started to record again, the battery in my iphone died.
Old 12-27-2017, 09:44 PM   #231
That's awesome Mike even at that temp. Thing cooks along the track and the steam trail is killer.
cmbscx10 is offline   Reply With Quote
Old 09-23-2018, 12:54 PM   #232
Mike Flea's Avatar
Finally got some cooler weather here in Chicagoland, so got the steamer out for a run, first time since 12/26/17. This is only a clip, it ran for 17 minutes: https://vimeo.com/291316186?utm_sour...campaign=29220
Old 10-10-2018, 05:09 PM   #233
Big Mike's Avatar
Man that thing is cool!
It's kinda mesmerizing. I'd just sit there with a cup of coffee and vape and watch it run around and around...
Big Mike is offline   Reply With Quote
Old 10-10-2018, 05:26 PM   #234
Mike Flea's Avatar
One of these days I got to put out some of the scenery. My wife built a very nice, detailed Farm scene and a Blacksmith shop. I told her maybe we can do it this weekend if the weather is nice, I'd like to see the farm covered in snow this year.
Old 10-10-2018, 09:02 PM   #235
Trail Hound
2mtech's Avatar
Yes, please That looked like a very cool setup, obviously a lot of effort went into the layout. Was that a covered bridge that didn't seem to be in use?
Sent from my SM-G930R4 using Tapatalk
2mtech is offline   Reply With Quote
Old 10-11-2018, 07:43 PM   #236
Mike Flea's Avatar
No sir, That red building you see in the distance is a car barn. To keep from dragging different cars in and out of the garage when I want to run the trains, I built a shed that houses the most used rolling stock. The engine is actually running on a track behind the car barn. If you go back to page 9, post 162, you'll see the modified layout. On the second, third, and fourth photos, you can see a siding area. That area is where the car barn is.
Old 10-11-2018, 08:50 PM   #237
KMS
KMS's Avatar
Is the rail wearing on the curves ,, a small amount of lube on inside rail will help,, I worked for the UPRR for 30+ years and seen flange oilers that did the same job using grease.
KMS is offline   Reply With Quote
Old 10-11-2018, 09:29 PM   #238
Mike Flea's Avatar
I've never really noticed. This track has been in use since around 1993, and was originally DC powered rail. I've only had the steamer since May 2017. I check the gauge annually, to avoid derailments, because it stays outside in the elements, and the more common problem with that is that the rails will separate at the joiners.
For those that don't know, "checking the gauge" is making sure the width or gap between the parallel rails is equal all the way around the layout. If it's too wide or too narrow, the engine will drive itself off the rails. The LGB track that I use has plastic ties that are UV resistant, but I have occasionally found broken ties, which if there are enough in a row, will warrant replacement of a track section. Since I've elevated the layout off the ground, it's been maybe 5-6 years since I've had to replace a section of track.
Old 01-02-2019, 07:05 PM   #239
Love that outdoor train set up Mike. I would love to do one of those in the lamdscape of my yard!
mewalsh100 is offline   Reply With Quote
Old 01-02-2019, 07:28 PM   #240
Mike Flea's Avatar
Thanks, it was originally on the ground. Where the greenhouse use to be, was a 5'x7' pond and there were 2 ovals. One that went around the entire pond, and one that crossed a bridge across the pond. Then it got extended to run the length of the garden area. In 2008, I broke my foot, and had knee surgery, and it became harder for me to get down to work on the track, and even harder to get back up again, so the wife suggested I make a bench, and raise the layout up. Then at a later date, the greenhouse eventually deteriorated, and couldn't find a replacement clear top as the company that originally made it merged with another company, and the parts became obsolete. So the greenhouse came down, and the layout expanded again, to where it is now.
It's a lot of fun, and the wife is very creative when it comes to modeling the scenery, one of these days we'll get the finished structures out, hopefully this year.
New Project (for me) - Similar Threads
Tire project for pede project Mdlopez1 Non Crawler RC's 2 04-21-2013 06:30 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
