10-01-2015, 07:46 PM | #141 |
Rock Crawler Join Date: Mar 2012 Location: bel air
| Re: New Project (for me)
Yup.. built not bought. Sent from my SAMSUNG-SM-G870A using Tapatalk |
10-01-2015, 07:59 PM | #142 |
that looks real nice Steve, how are you planning on mounting it? I've seen some with your style Jeep, make mounting plates at the feet and screw to the body. On mine, I brazed some 10-32 all-thread into the 4 corner tubes, drilled through the body, and secured with washers and nylocks, and the two middle tubes, I glued 1/8 rods into some holes in the body to use as guides. The tubes just slide over the middle studs.
10-01-2015, 08:02 PM | #143 |
I fill the bottom of the tubes on my rollbars with tin, then drill/tap for a clean looking mount. Sent from my SAMSUNG-SM-G870A using Tapatalk |
10-01-2015, 08:06 PM | #144 |
| Re: New Project (for me) Sent from my SAMSUNG-SM-G870A using Tapatalk |
10-01-2015, 08:08 PM | #145 |
So just drill the body and bolt on, clean easy and strong mount Sent from my SAMSUNG-SM-G870A using Tapatalk |
10-01-2015, 08:12 PM | #146 |
That'll work, just make sure you use washers on the underside with the screws so it doesn't pull through the plastic on a hard hit.
10-01-2015, 08:50 PM | #147 |
| Re: New Project (for me) |
10-08-2015, 09:37 PM | #148 | |
I wanna be Dave Join Date: Sep 2009 Location: n. palm beach
| Re: New Project (for me) Quote:
It's made from a broken XR uni that I repaired and it can swivel 1000*. | |
10-09-2015, 09:08 PM | #149 |
That's pretty good, considering there's only 360* in a circle, lol
10-10-2015, 08:48 PM | #150 |
I started reinforcing the bottom of the trailer by adding additional styrene between the frame rails. Still working on bending loops into the rake tines.
10-11-2015, 02:20 AM | #151 |
Pebble Pounder Join Date: Aug 2013 Location: San Jose
10-11-2015, 04:50 PM | #152 | |
Round 2: Placed in the vise vertically, so about 2" sticking up above the vise. I used my mapp gas torch for the heat. Through trial and error*, I found that if I only heat the metal so it barely has a red tinge to it, I can bend it, and when it cools, it still retains its temper. * while heating the metal to cherry red makes it bend easier, once it cools, even if you try to re-temper it by dipping immediately in water, the metal stays flimsy. I had to make another spring, that's why there are 3 tines missing from the rake head. It took about 15 minutes for each loop. I wanted to go slow, and not use too much heat at one time. I used a pair of needlenose pliers for the initial bending, A piece of 1/4 brakeline to use as a template for the size of the loop, and a pair of regular pliers to fine tune the loop after the bend and before the metal cooled. I also had a small cup of water to dip the tine in when I was satisfied with the loop. I'll use a piece of small rubber tubing, like fish tank hose, for the bushings in the loops. Still working on an axle, u-bolts & plates, and shackles, although, I may look into RC4WD shackles. | |
10-12-2015, 12:24 AM | #153 |
Thanks for all the info, my friend from my OnePlus Two |
10-12-2015, 07:37 PM | #154 |
These springs are 1/4" wide
10-12-2015, 08:10 PM | #155 | |
10-13-2015, 11:53 AM | #156 |
home brew springs look nice are you going to use some sort of eye bushing - sleeve that the bolt will go thru ? what's the ID of the spring ends ? |
10-13-2015, 06:45 PM | #157 | |
Thanks for the comments guys! | |
10-17-2015, 08:09 PM | #158 |
I took a couple extra days off of work this weekend, thurs & fri, figured I'd get this trailer moving along, but nope. Wife wanted me to do some work on the outdoor railroad, so she can continue building the town. So the part along the house had to be moved out since we took the greenhouse down earlier this year, and I added approximately 104 sq ft to the benchwork, and reinforced some of the existing benchwork, as it had been sagging a bit. Nice and cool temps, 50-60, made it easier to work without sweating. I have a couple more 2 x 4's to add to the underside of the mountain tomorrow morning, and then I can get back to work on the Jeep trailer.
10-19-2015, 08:25 PM | #159 |
I completely forgot about your outdoor railroad. Post up a few pics when you get a chance! |
10-20-2015, 07:54 PM | #160 |
I'll get some current pics up, after I get the track laid back down. The wife wants to put out some of her finished buildings to see how it's all going to fit with the extra benchwork.
New Project (for me) - Similar Threads | ||||
Tire project for pede project | Mdlopez1 | Non Crawler RC's | 2 | 04-21-2013 06:30 PM |
