12-28-2014, 01:58 PM | #1 |
Pebble Pounder Join Date: Nov 2009 Location: Jacksonville
| Nylint jeep body / mad torque
1/6 Jeep body on 1/8 Mad Torque crawler. Simply attached the jeep body onto the Mad Torque chassis.Made it as low as I could.I trimmed out a small channel in the rear of the body tub and notched out some very small grooves in front of the body tub , then used zip ties to secure.I also limited up travel with some bump-stops on the shocks so it would not rub the body.I did shorten the wheel base with the optional adjustments on the chassis and removed the rear spring spacers.I did use a small spring spacer up front. |
12-28-2014, 04:20 PM | #2 |
I joined the Band! Join Date: May 2006 Location: Between a rock and a hard spot!
| Re: Nylint jeep body / mad torque
Looks like a great fit. Is it top heavy? Parking it next to the larger jeep is a good way to make it look small.
12-28-2014, 04:44 PM | #3 |
The Barbie jeep is my next project *NOT* I should have put my Honcho next to it instead. It is top heavy but I've only rolled it once. I wanted another SCX-10 for Christmas but it was not in our budget this year,so I remembered the Exceed crawler was half the price , plus I could re-use (what was my first crawler) the Nylint Jeep body I was holding on to for so long. I probably won't run this thing that much but I'm glad I found a chassis to use for it. Thanks! |
02-04-2015, 06:28 PM | #4 |
Rock Stacker Join Date: Apr 2006 Location: KC
Fantastic! Been trying to find a chassis for my old Nylint body. Sent you a PM for some details.
03-10-2015, 09:17 AM | #5 |
| Re: Nylint jeep body / mad torque |
03-10-2015, 09:41 AM | #6 |
03-11-2015, 05:09 AM | #7 |
I would look at Traxxas Summit it would have the wheel base close to what you need.
04-15-2015, 05:59 PM | #8 |
Glad to help. Jeeps look-in good. The lower the better. |
04-15-2015, 08:42 PM | #9 |
I wanna be Dave Join Date: Sep 2009 Location: n. palm beach
Agreed. /\
04-16-2015, 10:16 AM | #10 |
The body... You should buy some epoxy appliance paint. Thee are some things that you need to know about using it as a base coat. 1) it takes a long time to dry. 2 spyed) it has to be dry before adding another coat if you do spray before it dries it will pull the previous coat up and wrinkle.
04-19-2015, 11:54 PM | #11 |
Quarry Creeper Join Date: Jun 2004 Location: 462-Da Fock
Can I get some info on those wheels and tires? Size? What are they from? I have a 1:6th build waiting for me to give it attention and I have some old RC4WD 3.2 beadlock wheels but cant really find any tires that I like to fit the body I have. I have a few older 3.2 HPI tires that I have cut up and awaiting glue to narrow them but they still dont fit the bill or likes. NEVER MIND I SEE THEY ARE FROM THE MAD TORQUE. loL! If anyone can chime in with some help would be much appreciated. Last edited by spiderxx; 04-20-2015 at 12:16 AM. |
Nylint jeep body / mad torque - Similar Threads | ||||
Budget Mad Torque Build / Custom body | srosamechanic | Superclass Crawlers | 10 | 12-17-2015 12:16 PM |
Wanted: Nylint 1/6 Stock Jeep Body/ I Have Scorpion Body | yellowpasta2000 | General Crawlers | 4 | 08-10-2006 04:42 AM |
