Go Back   RCCrawler Forums > Scale Rigs General Tech > Large Scale Rigs
Thread: warriorsimi's willies jeep "the general"
Old 01-28-2015, 04:04 PM   #1
Default warriorsimi's willies jeep "the general"
Finally got started on my jeep,I have owned about 8 different bodies but never had the right parts or just no motivation .finally yesterday I decided I was not going to stop till I had something built at least for mock up.i tried the stock chassis and also the 1/2 inch square finally decided to use the scx10 chassis rc4wd transfer case and the gelante 2 tranny.[IMG][/IMG]
[IMG][/IMG]
warriorsimi is offline   Reply With Quote
Old 01-28-2015, 04:31 PM   #2
Default Re: warriorsimi's willies jeep "the general"
Hey, it's a start! Not bad!
Die-Laughing is offline   Reply With Quote
Old 01-28-2015, 06:53 PM   #3
WooHoo! another Jeep build to follow, I'm always looking for new ideas!
Mike Flea is offline   Reply With Quote
Old 01-28-2015, 10:56 PM   #4
Got some more work done today,I had to install a Panhard because the upper right link was hitting the tranny also worked on the general he now can drive the jeep and look around .I need some super glue so his head stays on and figure out how to keep his hand on the wheel.pics soon.
Old 01-28-2015, 11:14 PM   #5
Here's pic of the drivetrain ,I don't think I have seen it done this way before.[IMG][/IMG]
Old 01-28-2015, 11:19 PM   #6
Here's the steering box ,I am going to make a bracket where the steering column attaches to the chassis right now it flexes a bit.
[IMG][/IMG]
[IMG][/IMG]
Old 01-29-2015, 04:56 AM   #7
Stay motivated please.Great startIt would be cool to hog out a plastic v8 to fit over the 540.?
truckbob is offline   Reply With Quote
Old 01-29-2015, 05:54 AM   #8
Thanks I will actually today is the second night that turned morning.got the driver and steering done now hopefully the easy part.planning on army green with flat black floors and red jerry cans,then tube work what you all think should I do a full tube roll cage? Or leave it as is except for bumpers?
Old 01-29-2015, 09:53 AM   #9
Full roll cage !!!
Jeepin-Paul is offline   Reply With Quote
Old 01-29-2015, 04:27 PM   #10
Depends on how much you think the Jerp will spend with the tires facing towards the sky! Mine is top heavy, so the cage is always being used.
BigSki is offline   Reply With Quote
Old 01-29-2015, 06:40 PM   #11
Mine is pretty well balanced, but I put a cage on anyways. Also, depends on what you're looking to build, more of a stock military jeep, or is the General retired, heading out to the remote fishing hole.
Old 01-29-2015, 11:20 PM   #12
Would be the general finally going to moab.
Old 01-29-2015, 11:23 PM   #13
If I could of used the stock wheels and tires I would leave it alone I drove it in my shop and it does really good so far I just hope that with the cage it don't hinder it too much.
Old 01-30-2015, 01:14 PM   #14
Just my opinion, but if you make a full cage, do it out of tubing to save on weight. My cage is made from 5/16" diameter tubing, the next one will be 3/8" just for a bit more strength.
Old 01-30-2015, 01:47 PM   #15
Liking the way you built the drivetrain. Jeep looks good on it.
Yep, I use Stockcarsteel.com's DOM for all my work. The softer/cheaper 1020 DOM steel has been holding up well.
Szczerba is offline   Reply With Quote
Old 01-30-2015, 05:24 PM   #16
I am going to build it out of 1/4 inch brake line anything bigger I think is too big.
How can I upload a video? Tried photobucket and it just says it's loading but won't.i got it running last night and wanted to show the driver steering and turning his head.
Old 01-30-2015, 06:51 PM   #17
I used 1/4" brakeline, and by the time I finished, if it weighs a pound, I'd be surprised. It's very strong once I put the crossbraces on it, not top heavy at all. Unfortunately, I used the coated brake line, and now that I know better, my recommendation to you would be find un-coated brakeline, it'll save on a lot of grinding that you need for a clean braze. Also remember to grind a fishmouth in perpendicular joints, makes them stronger.
Old 01-30-2015, 07:46 PM   #18
Make a rollgage. You can always unbolt & remove it for stripped-down look.
Yes, try to make it from tubing. My first 1/6 cage was 1/4" solid rod and heavy. Version 2 was 1/4" stainless tubing and half the weight.
Old 01-30-2015, 08:19 PM   #19
I always upload to youtube and then paste the embedded link into a post. If the section allows it. See bottom left of page.
Old 01-30-2015, 08:33 PM   #20
I have made a couple of roll cages already and a lot of southern buggies ,I use the galvanized brake line and sand the galvanizing off .thanks for the suggestions guys really appreciate it .this rig is getting heavy really quick.
warriorsimi's willies jeep "the general" - Similar Threads
Wild Willies trailing "going arround" magic2002 Videos! 1 01-16-2015 01:53 PM
Wild Willies trailing "brothers in arms" magic2002 Videos! 0 01-07-2015 05:31 AM
warriorsimi's 1.1 project" toy" warriorsimi 1:1 Full Size Vehicles 9 10-25-2013 10:46 AM
warriorsimi's "90 proof" southern build warriorsimi Axial Wraith 132 02-25-2012 10:04 PM
