05-29-2015, 09:42 PM | #1 |
Pebble Pounder Join Date: May 2014 Location: Floriduh
| Project "Wrender" 8th Scale Ford F100
Here's a little something I have been working on for a bit now. I ordered an Ascender kit to use the axles for a GCM/New Bright JK scaler build to mimic my 1:1. I had a Wraith sitting on the bench untouched for months. I found this body at a LHS and a light bulb went off! This is where it sits as of right now. Vaterra Ascender frame/trans Wraith axles/links RPM 2.2 Revolvers wrapped with 1.9 Ascender TSL SX TODBLDZ Wroncho plates Tekin RS Gen2 with Holmes Hobbies BL Stubby 540 on 3s Hitec 7950TH GPM Traxxas Stampede shocks with Integy springs Still some sorting to do, but it works as expected right now. Can't say the same for the Trakpower TK950 I opened today to work on it |
05-29-2015, 09:42 PM | #2 |
| Re: Project "Wrender" 8th Scale Ford F100 |
05-29-2015, 09:47 PM | #3 |
05-29-2015, 10:24 PM | #4 |
I wanna be Dave Join Date: Sep 2009 Location: n. palm beach
Nice looking rig. I noticed you put a spacer on the servo horn to the steering arm. Can you explain? |
05-29-2015, 10:28 PM | #5 |
Looks cool! the color combo really makes it stand out! I'd like to see a pic from the underside, how you did your links.
05-29-2015, 10:51 PM | #6 |
RCC Addict Join Date: Apr 2015 Location: New Brunswick,Canada
seem like he need a longer link to avoid putting that spacer..or it there so it won't bind the link It's interesting to see cause i want to make one for my rig same concept scx10 chassis rails to wraith axles... Nice work.. |
05-29-2015, 10:59 PM | #7 |
That spacer is above the drag link for a couple reasons, but mainly to keep the angle of the panhard and the drag link as parallel as possible. I made an effort to use a hodgepodge of existing links and rod ends I had on hand to complete the build.
05-29-2015, 11:11 PM | #8 |
05-30-2015, 12:55 PM | #9 |
You may find that will reduce the torque of the servo.
05-30-2015, 01:53 PM | #10 |
I think it may add more stress to the horn more than anything. I essentially needed a drop pitman arm like you would on the 1:1. The Hitec 7950th has no problem with plastic wheels and 1.9 tires either way. Its a short metal link with a stainless screw running through into the captive nut on the horn it is rather stout all things considered. Gonna get ready for a shakedown run here in a bit.
05-30-2015, 07:08 PM | #11 |
The Ascender chassis looks narrower than an scx10 chassis. I did a wroncho a couple years ago with a traxxas SC Dodge body on an scx10 frame, 4-linked front and rear, and no driveshaft interference. I just like to see how other builders set up their links.
05-30-2015, 07:15 PM | #12 |
Definitely narrow, the wroncho plates would not clear a standard 540 motor
05-30-2015, 07:39 PM | #13 |
Hmmm, I looked them plates up, interesting. I just clocked my axles a bit, lengthened the wheelbase to 13.5", used 104mm links up front, and 106mm links out back, and bolted everything to the frame rails and skid.
05-31-2015, 07:38 PM | #14 |
05-31-2015, 08:52 PM | #15 |
In the "1.9 Scale Rig" section there's another " '66 Ford F100 Wroncho Build" by joe122
06-01-2015, 04:55 AM | #16 |
Rock Crawler Join Date: Jan 2013 Location: Australia
Really diggin' the paint scheme and color combo |
06-01-2015, 08:33 AM | #17 |
06-01-2015, 08:45 PM | #18 |
He just added a bit more detail. You've got the skills to do that too. I was working on tube bumpers for mine when I had the inkling to build a 1/6 Jeep, and robbed the chassis for it.
06-03-2015, 08:18 PM | #19 | |
Pebble Pounder Join Date: Apr 2013 Location: Bonney Lake
| Re: Project "Wrender" 8th Scale Ford F100 Quote:
Could you move the spacer from the servo horn to the knuckle to gain the same effect for the panhard angle while helping alleviate any adverse strain on the servo arm or servo itself caused by said spacer? Sent from the clouds | |
06-04-2015, 01:22 AM | #20 |
| Re: Project "Wrender" 8th Scale Ford F100 I don't see why not. I will change it up when I go to work on that project some more. Thanks for the insight! |
Tags |
1/8 scale, ascender, ford, wrender, wroncho |
