Go Back   RCCrawler Forums > Scale Rigs General Tech > Large Scale Rigs
Thread: The i have a willys problem build.
Old 11-27-2017, 09:36 AM   #21
Default Re: The i have a willys problem build.
I forgot to mention the rear frame section isnt finished yet. Im thinking two tubes with a cross member or two from the frame at an angle toward the back of the body. Thanks for looking.
mud bogger is offline   Reply With Quote
Old 11-27-2017, 10:47 PM   #22
The bumper is about 95% done, and it came out way bad ass thanks to my buddy james Well enough of that its pic time.
And my favorite pic for obvious reasons
Old 11-28-2017, 05:19 AM   #23
gst
Good to see you back, Rig is looking badass.
gst is offline   Reply With Quote
Old 11-28-2017, 09:42 AM   #24
Thanks man. Tonight the rear frame should be finished. We decided to use the same 3/8 square stock.
Old 11-28-2017, 06:25 PM   #25
That's a good looking heavy duty frame
Mike Flea is offline   Reply With Quote
Old 11-28-2017, 09:40 PM   #26
Yup over kill at its finest.
Old 11-28-2017, 09:50 PM   #27
OK so the front bumper is done except for cleaning the welds up and then sand blasting the entire frame with aluminum oxide.
The rear frame section is done just gotta clean up the welds aswell. Thanks again for looking. I still have a few more things i want to do.
Old 11-29-2017, 06:05 AM   #28
I have been reading about the Willys builds from others over the last few weeks and of course watching the videos. I then spotted and read your thread when you posted up a few days ago..... that was the final factor in pressing the "Buy Now" button for my Willys jeep. looking forward to your build / what you have done so far.
northern hooligan is offline   Reply With Quote
Old 11-29-2017, 07:21 AM   #29
Thanks man. Glad to hear that i could help you take the plunge haha. Ill look forward to seeing your build aswell.
Old 11-30-2017, 05:53 AM   #30
My Buddy got the frame cleaned up and blasted. All thats left to do for now is spray the frame with anti rust primer then self etching primer for the flat military look. Depending on how things go this weekend my other friend mite be able start the 4 link setup and mock up the chassis mounted servo. Thanks for looking.
Old 11-30-2017, 09:21 PM   #31
All done.
Old 12-01-2017, 12:18 AM   #32
Couldn't resist doing some mock up.
Old 12-04-2017, 03:06 PM   #33
Loving the full steel chassis. Reminds me of the blue Jerp that I started with a full steel frame and leaf springs. It sounded sooo good when the frame dragged across the rocks.
BigSki is offline   Reply With Quote
Old 12-04-2017, 05:28 PM   #34
I agree Big Ski. For me it gives a solid feeling and performing rig. Im kinda shooting for this one to be a 14 pounder.
Old 12-04-2017, 05:57 PM   #35
I wish the pics could do better at showing the jeep.
Old 12-05-2017, 06:58 PM   #36
Not too hard to do with a plastic frame underneath !
Old 12-05-2017, 09:04 PM   #37
The last one was about 12.
Old 12-09-2017, 10:46 AM   #38
Im thinking about 3 linking the front and rear. Has anybody else had any luck with this? Ive got a good idea of how its gonna go, id just like to hear other peoples opinions.
Old 12-09-2017, 12:12 PM   #39
I 4 linked mine, so I'm of no use to you, but if you don't get a response, you'll have to check the other Jeep builds in this section.
Old 12-09-2017, 12:38 PM   #40
Thanks man. I did find a few builds that tried doing a 3 link but they either went back to a 4 link or were not using a wraith based axle. What i did learn is that it is very possible, so i have no choice but to make it work. Its a good thing i like a challege.
The i have a willys problem build. - Similar Threads
Willys build-V8 truckbob Large Scale Rigs 27 02-12-2014 04:41 PM
1/6 willys build dfox Large Scale Rigs 5 11-20-2013 07:15 AM
~53 Willys 2010 Comp Rig Build~ RC4WD MOA Worminator Build~ 53 willys General Crawlers 108 11-28-2011 12:42 AM
New Willys build...need some help/info wildwilly4x4 Large Scale Rigs 20 07-04-2010 02:29 PM
Willys Build Up!! swamped2a General Crawlers 7 11-23-2005 10:51 AM
