12-10-2017, 04:31 PM | #41 |
| Re: The i have a willys problem build.
In one iteration of my orange Jerp, I had xr modded ax-10 axles and ran a 3 link up front, mostly for servo clearance. I remember that it handled poorly and my design was weak, I constantly broke the upper link mount. I went back to a 4 link and just repositioned the steering servo. Later when I made the narrowed AR60 axles, I kept a 4 link on it.
12-10-2017, 04:51 PM | #42 |
Quarry Creeper Join Date: Jan 2009 Location: LOADING......
Thanks for your input man. I did some more mockup today and its gonna be tight. The tracbar will come very close to the drag link and the axle throughout the suspension cycle. Ill have to limit the steering a little only to keep the tires off the shocks and links, witch also helps with clearance. Until the panhard mount is made and attached i wont know how well it will go, but im not to worried.
12-10-2017, 05:54 PM | #43 |
Newbie Join Date: Nov 2016 Location: Wichita
| Re: The i have a willys problem build. Can you show or say how you mounted your panhandle bar? I got a Hasbro Willys a few days ago and I'm looking to see what axles to run. Without a set of AR60's in hand I'm trying to visualize how you attached it to your axle.
12-10-2017, 07:20 PM | #44 |
| Re: The i have a willys problem build. |
12-17-2017, 04:48 PM | #45 |
12-20-2017, 06:27 PM | #46 |
Ive started mocking up the 4 links. The rear is where im having problems. Ive decided to go to a 14 and a half wheel base to try to get the rear tires back as far as i can to compensate for the steel rollcage. To me it dosent look rite, any thoughts? or am i just driving my seilf crazy hahaha Thanks for looking. |
12-20-2017, 07:02 PM | #47 |
Pebble Pounder Join Date: Sep 2014 Location: Hamilton Montana
My honest opinion is to shorten the rear 1/2"-3/4. And you will still need to cut the rear wheel well openings. BTW I really like your build. And I have one of these Jeeps brand new in the box never been opened. Sent from my SM-G920V using Tapatalk |
12-20-2017, 07:13 PM | #48 |
Thanks Correll. After thinking about it ill try 1/2 in shorter. Also i was planning to cut the rear. I gotta remember to stop and take breaks, problem is to many ideas i want to try.
12-20-2017, 07:17 PM | #49 |
Your longer wheelbase will help your driveshaft angles also. On top of stability. I've noticed alot of the willys builds have steep driveshaft angles. Which isn't a huge deal in RC world, but still. Sent from my SM-G920V using Tapatalk |
12-20-2017, 07:59 PM | #50 |
Rock Crawler Join Date: Mar 2011 Location: USA
I personally like the tire by the wheel opening , I have brake line tube cages in mine and haven't felt I needed to lenghtin the wheel base , With the weight of these rigs shorter drive lines are stronger ..
12-24-2017, 01:16 PM | #51 |
12-31-2017, 11:27 AM | #52 |
01-28-2018, 07:26 PM | #53 |
01-30-2018, 10:44 PM | #54 |
01-30-2018, 11:25 PM | #55 |
02-04-2018, 02:28 PM | #56 |
02-04-2018, 05:51 PM | #57 |
The cut on the rear body came out nice, looks real good |
02-04-2018, 06:23 PM | #58 |
Thanks man. Im thinking about putting some trim molding on the cut edges to clean it up or get some thin wall hollow tubing and cut a slit down the middle. Kinda of like a rub rail.
05-26-2018, 12:05 PM | #59 |
As soon as i can get my friends help the 4 links will be done. I found this diy 4 link kit at my LHS. I think it will be plenty strong enough. Revo rod ends will work with the all thread it comes with but i think 8-32 all thread is a slightly better fit, ill use the M4 it comes with for now unless i have problems. Thanks for looking. |
08-13-2018, 06:53 PM | #60 |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
| Re: The i have a willys problem build. Yea, that looks real good cut that way. I've been thinking about cutting mine and adding 1/2"-3/4" of wheelbase, this might have made up my mind. That chassis looks stout! Well done there. If you get some big brushless power in there, gear it for some wheelspeed and leave the front axle unlocked, this rig will be so fun to drive. I 3-linked my front end (My build thread should be archived here somewhere) and got lucky. It hardly deflects at full travel and drives pretty good. But, like Bigski, I'm constantly repairing/replacing the upper link mount for the panhard bar. I've made 3 or 4 of them so far out of aluminum. The next one will be steel. For the high-speed low-drag rock racer style rig this looks like it's becoming, you might be better off keeping the 4-link in the front. Looking good so far! |
The i have a willys problem build. - Similar Threads | ||||
Willys build-V8 | truckbob | Large Scale Rigs | 27 | 02-12-2014 04:41 PM |
1/6 willys build | dfox | Large Scale Rigs | 5 | 11-20-2013 07:15 AM |
~53 Willys 2010 Comp Rig Build~ RC4WD MOA Worminator Build~ | 53 willys | General Crawlers | 108 | 11-28-2011 12:42 AM |
New Willys build...need some help/info | wildwilly4x4 | Large Scale Rigs | 20 | 07-04-2010 02:29 PM |
Willys Build Up!! | swamped2a | General Crawlers | 7 | 11-23-2005 10:51 AM |
