Go Back   RCCrawler Forums > Scale Rigs General Tech > Large Scale Rigs
Thread: Projekt Yota MT
Old 03-28-2015, 05:40 AM   #1
Default Projekt Yota MT
After pulling numerous parts from the junkyard...lol
ive come up with somethin i think is interesting.
Scx10 c-frame chassis rails
Wraith skidplate - modified
Scx10 shock mounts
Wraith axles
Scx10 crossmembers - modified
Axial alloy upper/lower links
VP locked diffs 38/13t
Wraith alloy tranny with Dig (.08mod spur/pinion)
Custom toyota Tamiya shell using Wraith caging - modified
VP VVD CVDs
Strc knuckles
Strc truss
Clodbuster wheels with wheel widners
Nobby tires - unknown brand?
Still in the making **piics to follow**
SwampDawg is offline   Reply With Quote
Old 03-28-2015, 07:53 PM   #2
Default Re: Projekt Yota MT
heres the results so far...
still working on this rig but its comin along real nicely!!
i ended up somehow wrecking x1 nut for these clod wheels which pass through these clod wheel widners... anyone got some spares?? argh!!
Old 03-29-2015, 08:26 AM   #3
Small update:
Stayed up til 1am messing around with this rig...
Installed alloy axle to rearend.
electronics now operational.
programmed esc & bec.
Installed longer ballends onto shocks & serviced.
Drilled out wheel hubs and installed wheels.
removed decals for later bodywork and paint.
initial testing in garage proved things worked.
1st trial run later today...
Old 03-29-2015, 09:55 PM   #4
1st trial run went awesome this morning!!
Later I decided to pull the body off and splash some flat black paint on it.
Now I need to work on getting a Honcho cage for the rear of this beast!
Old 03-31-2015, 08:40 PM   #5
Ordered the honcho cage for this rig. Then i can mod it too fit but it wont be here for a good week.
more to come! ;)
Projekt Yota MT - Similar Threads
Projekt MonkeyNutz Wraith: SwampDawg 2.2 Scale Rigs 25 06-08-2013 09:42 PM
Projekt CC1-R SwampDawg 2.2 Scale Rigs 0 05-30-2013 01:43 AM
Projekt Summit retrofive Traxxas Crawlers 5 03-25-2012 02:37 PM
Finland Projekt CC-01 Wrangler FinHedgehog Tamiya XC/CC01 6 06-30-2011 09:14 PM
Projekt Viper looneybin General Crawlers 6 10-30-2006 09:13 PM
