07-25-2015, 09:06 PM | #201 |
| Re: AWIP, 1/6 Willy's Jeep. "Special Ops"
I vote for 1, smack-dab in the middle, from underneath, attached with 3-M tape, painted the same color as the hood |
07-25-2015, 10:07 PM | #202 |
1 will be easier... 2 will vent more I'd do neither above or below. I'd go with flush... and add a backing plate on the underside. fill the seams on top... sand smooth... primer... paint X2 on the E6000 I used that on my sc-10 axle to secure slider rings to the center chunk(s) I've beat on them severely in the rocks... and they are still holding great. |
07-26-2015, 11:56 AM | #203 |
I wanna be Dave Join Date: Sep 2009 Location: n. palm beach
Thanks guy's. A lot of great ideas. I will add a fan to the grill to push air in and the luvers will pull air out. I want to make a air diverter to aim it down towards the motor from the grill, then use the hood vent to pull out the hot air |
07-26-2015, 02:17 PM | #204 |
Progress report: Fan is mounted to the luvers, with a small spacer between the two for more air flow. |
07-26-2015, 05:53 PM | #205 | |
I almost post this in the archive and maybe I already stated here... !? :dunno: - :recollect: Quote:
the rim can eventually cut/abrade the tire's sidewall. Tire flex is helpful... but too much is not great IMO weight an issue ? maybe needs denser inserts ? | |
07-26-2015, 07:00 PM | #206 |
John, if you mount the fan to the louvres, will it clear the motor, trans and esc under the hood? I think if you mount it to the radiator/grill, it'll suck the air in through the front and vent out through the louvres on top.
07-26-2015, 08:01 PM | #207 |
I am very curious on the outcome but have a noob question. A few other builds don't mention heat issues so is the heat related to the small enclosed motor compartment or ?? Having to vent a compartment that is say 4" square wouldn't take much. It almost seems like a small fire is under the hood. A few holes in the bottom pan and the already square holes that are on the hood will maybe make a big enough difference to not put the louvers in. I am just rambling at this point.
07-26-2015, 08:27 PM | #208 | ||
| Re: AWIP, 1/6 Willy's Jeep. "Special Ops" Quote:
My grill is completely uncut, so now air flow there either. The only air that is available is from the bottom of the engine bay. Again, not much there. So, my plan is to incorporate 2 mini fans, pusher & puller. The grill fan wil have to be diverted down a bit as to cool the motor and the hoid fan wil pull out as mush heat as possible. I'm going to mount the luvers to the oitside if the hood, for that upgrade look. Concidering it's not a factory option. Should work very well, in theory. I'll lyk. | ||
07-26-2015, 08:31 PM | #209 | |
07-26-2015, 08:54 PM | #210 |
Here are some reference pic's. I have about 3/4" from the inside of the hood to the esc, which should be enough for the fan @ 5/8". So a little wiggle room. |
07-26-2015, 09:34 PM | #211 |
get a water jacket, from an rc boat, wrap that motor with it install a holding tank, and wee pump now plumb that thru a radiator mounted at the grill then install yer fan behind the radiator. now yer S C A L E C O O L jk |
07-26-2015, 09:58 PM | #212 | |
07-27-2015, 06:37 AM | #213 | |
07-27-2015, 08:33 AM | #214 |
RCC Addict Join Date: Apr 2015 Location: New Brunswick,Canada
looking at your build is cool and seem like a lot of work.i wondering how rare are these bodies.I have one sitting in the shelf and like to try what your doing but i hate to cut up the body...i only seen 2 on ebay both are from 2002 and 2003 mines 2003 with canvas top.I also tried a search on here but no luck... Like i type in " Show off your hasbro jeep willys"maybe start a new thread to see how many of us has this body...sorry for the stupid question... |
07-27-2015, 11:57 AM | #215 | |
I think it's totally doable if that's ^ of no concern. I'm sure you've googled that plenty https://traxxas.com/forums/showthrea...r-cooled-slash Liquid-cooling system for RC cars and helicopters | |
07-27-2015, 01:13 PM | #216 |
And i thought you were kidding.I didn't bother reading the whole thread picture tell a thousand words.But Does it work and "WHY".Just put a fan.lol
07-27-2015, 08:20 PM | #217 | |
Al I can say is, timing is critical. I searched for 3 1/2 weeks for the body I have now. Sometimes you won't see one for a while, then "bamm" 5 will pop up. Keep looking for another as a back up, something will show up for you. Last edited by stelerzman; 07-27-2015 at 08:28 PM. | |
07-27-2015, 08:23 PM | #218 | |
I posted earlier that I fried a hugh $$$. Motor because of high temps. This is a precaution to save money on motors and esc's. Just like you personal vehicle, you wouldn't run it without coolant and water in the radiator. Would you??? Last edited by stelerzman; 07-27-2015 at 08:32 PM. | |
07-27-2015, 08:41 PM | #219 | |
Even with my motor being tucked up under the body, I have no heat issues. The battery, (nimh), gets a bit warm, but nothing else. Last edited by Mike Flea; 07-27-2015 at 08:45 PM. | |
07-28-2015, 06:43 AM | #220 |
Damn there pricy. Just searched for them, and I was shocked.
AWIP, 1/6 Willy's Jeep. "Special Ops" - Similar Threads | ||||
Hungary "quick" 1963 Willy's Jeep truck | Senior Latya | 1.9 Scale Rigs | 27 | 10-17-2012 03:47 PM |
Operation Black Ops: "Behind Enemy Lines" Part 2 Axial Jeep Unlimited Rubicon JK | LetsGoMuddin | Scale Videos! | 0 | 06-02-2012 11:28 AM |
Operation Black Ops: "Behind Enemy Lines" Part 1 Axial Jeep Unlimited Rubicon JK | LetsGoMuddin | Scale Videos! | 2 | 06-02-2012 11:27 AM |
