06-07-2015, 06:12 PM | #101 |
| Re: AWIP, 1/6 Willy's Jeep. "Special Ops" |
06-07-2015, 06:32 PM | #102 |
I wanna be Dave Join Date: Sep 2009 Location: n. palm beach
That's kinda the plan, just no vice grips. I'll post up my jig after diner. |
06-07-2015, 08:04 PM | #103 |
Here we go, Stock length screw In the jig. After sanding. Side by comparison of the two screws. |
06-07-2015, 08:30 PM | #104 |
The screw is now .5 mm shorter. |
06-08-2015, 09:10 AM | #105 |
I forgot to post the weights of each of the housing. RC4WD: SSD: More progress soon. Last edited by stelerzman; 06-09-2015 at 05:32 PM. |
06-08-2015, 04:30 PM | #106 |
I must say, this axle is SEXY. It's all assembled and installed. Just a little fine tuning of the lower links to get it all squared up. |
06-08-2015, 07:00 PM | #107 |
Looks real good John, definitely better with a centered pumpkin |
06-09-2015, 03:56 PM | #108 |
The transfer case has been relocated, I moved it back a 1/4" and over a 1/4". I was shocked how much it improved the drive line geometry. I'm working on the front upper links and reworking the motor/ trans configuration. Last edited by stelerzman; 06-09-2015 at 05:33 PM. |
06-09-2015, 05:29 PM | #109 |
06-09-2015, 08:42 PM | #110 |
New upper links are done for the front end. I'll get the motor/trans redone in the morning. |
06-10-2015, 09:10 AM | #111 |
Links are in. I had to bend them because I made them too long. Oh well, it worked out. Gave more clearance for the front drive shaft. |
06-10-2015, 09:25 AM | #112 |
Need some help: I can't figure out how to shift the axle to the left about an1/8". As far as I can tell all links are the same length and all the spacers are equal length. The front axle is off set to the right side. Thanks for any ideas. |
06-10-2015, 09:46 AM | #113 |
Nobody Join Date: Sep 2008 Location: Maine
The link on the left in post #110 sure looks longer.
06-10-2015, 10:21 AM | #114 |
I see what your saying, but that is because of the angle I had to take the picture. They are equal length.
06-10-2015, 01:09 PM | #115 |
Thank you Greenz. |
06-10-2015, 01:14 PM | #116 |
I got the motor/trans in. Workin' on installing the electronic. |
06-10-2015, 04:01 PM | #117 |
All wired up. |
06-10-2015, 08:22 PM | #118 |
| Re: AWIP, 1/6 Willy's Jeep. "Special Ops" Judging by the photo in post 111, the axle and links look square to the frame, but is the frame square to the body? You might need to kick the front of the chassis over 1/8 to center it on the body.
06-11-2015, 12:10 PM | #119 |
Thanks for the help guy's. I tracked down the alignment issue. It was the upper link mount that I made, it was off center by 1/8". I also noticed that the servo mount was lifting the frontend. So I moved it to the axle. I'm not happy about it, but at least it will be more solid and I'll get more of the servo power to the knuckles. |
06-13-2015, 10:11 PM | #120 |
I've had a few issues with gearing and have it sorted out. It seams I had it over geared to the point I smoked another motor while testing. At least that's behind me. I do have a few spur and pinion gears coming to fine tune with. As of right now I have a 6.0 ratio in it via a 9/54 combo. I did a short, 5-8 min. run in the yard earlier today and the motor didn't pass 100*. That's much lower then before. I should get a few pics up tomorrow while I test things out. |
AWIP, 1/6 Willy's Jeep. "Special Ops" - Similar Threads | ||||
Hungary "quick" 1963 Willy's Jeep truck | Senior Latya | 1.9 Scale Rigs | 27 | 10-17-2012 03:47 PM |
Operation Black Ops: "Behind Enemy Lines" Part 2 Axial Jeep Unlimited Rubicon JK | LetsGoMuddin | Scale Videos! | 0 | 06-02-2012 11:28 AM |
Operation Black Ops: "Behind Enemy Lines" Part 1 Axial Jeep Unlimited Rubicon JK | LetsGoMuddin | Scale Videos! | 2 | 06-02-2012 11:27 AM |
