07-11-2015, 11:31 AM | #1 |
Pebble Pounder Join Date: Aug 2013 Location: San Jose
| My 1:6th Willys Jeep build (GI Joe)
Well, I figured I would start a thread on my build for these awesome rigs. My friend @Granite Bandit has inspired me to build one of these along with thanks to the pioneers @ZoSo, @BigSki, @Nomadpsd i am going to try to make this pic heavy and informative because it took me more researching and trying to get tips in building this baby. Plus the socalrc forums seem to be closed now, so it was harder to get info. Sent from my A0001 using Tapatalk Last edited by eunique; 07-12-2015 at 08:55 AM. |
07-11-2015, 12:58 PM | #2 |
| Re: My 1:6th Willys Jeep build (GI Joe) This is what I'm starting off with Some parts lucked out with a boxed package Sent from my A0001 using Tapatalk Last edited by eunique; 07-11-2015 at 09:42 PM. |
07-11-2015, 12:59 PM | #3 |
| Re: My 1:6th Willys Jeep build (GI Joe) |
07-11-2015, 01:06 PM | #4 |
07-11-2015, 01:15 PM | #5 |
| Re: My 1:6th Willys Jeep build (GI Joe) Testing out placement for AX10 transmission, although BigSki's post mentioned mirroring the transmission to help with torque twist. I'll see what I can do Sent from my A0001 using Tapatalk Last edited by eunique; 07-11-2015 at 01:24 PM. |
07-11-2015, 01:29 PM | #6 |
07-11-2015, 01:37 PM | #7 |
| Re: My 1:6th Willys Jeep build (GI Joe) Test fitting links took a while due to measuring, test fitting, readjusting, mounting... Tedious process. I used 8/32 all thread rods and Traxxas #5347 rod ends. Robinson Racing metal gears to upgrade the transmission Use the bearings from the stock plastic idler gear Swap the parts over to the metal gears Reinstall gears and put grease Also, I used 32 pitch spur and pinion for added strength Sent from my A0001 using Tapatalk Last edited by eunique; 07-11-2015 at 05:12 PM. |
07-11-2015, 05:19 PM | #8 |
Cut off and grind smooth front part of the frame, then cut off amd smooth out these nubs that stick out (with black stripes in the pic) Sent from my A0001 using Tapatalk Last edited by eunique; 07-26-2015 at 11:09 PM. |
07-11-2015, 08:30 PM | #9 |
I wanna be Dave Join Date: Sep 2009 Location: n. palm beach
Lookin' good. Keep it up and have fun building. I have a suggestion, mount the rear upper link mounts above the top of the chassis as much as you can. It will help with climbing. I know there's not a whole lot of room, but do what you can. |
07-11-2015, 08:30 PM | #10 |
07-11-2015, 08:41 PM | #11 |
| Re: My 1:6th Willys Jeep build (GI Joe) Here, I am mirroring the transmission. I used a 5mm + 2mm green aluminum spacers to take the place of the place of the spur gear back cover plate. Here is the mirrored transmission mocked up in place where it is going (Post #5 has pic of position of standard transmission how Axial has it preassembled) Sent from my A0001 using Tapatalk Last edited by eunique; 07-11-2015 at 08:43 PM. |
07-11-2015, 08:51 PM | #12 |
I had to hack some plastic forward of the transmission to clear the steering servo. I installed the servo in the engine bay to have as much clearance for flex as possible...equivalent to CMS (chassis mounted servo). Underneath Servo mounted and tie rod mocked up with panhard bar mocked up underneath. Sent from my A0001 using Tapatalk |
07-11-2015, 08:58 PM | #13 |
07-11-2015, 09:25 PM | #14 |
If you screwed the panhard to the axle, it may hinder the full movement of the steering to the left
07-11-2015, 09:46 PM | #15 |
@Mike Flea I did screw it into axle..and yes, it does hinder quite a bit. Any suggestions? I will be upgrading to XR mod. But TJRC Products is out of longer brass tubes until about a week from now. Sent from my A0001 using Tapatalk Last edited by eunique; 07-11-2015 at 09:55 PM. |
07-11-2015, 09:54 PM | #16 |
07-11-2015, 10:11 PM | #17 |
07-11-2015, 10:43 PM | #18 |
| Re: My 1:6th Willys Jeep build (GI Joe) Get a Panhard bar kit from RPP or Vanquish. You also want the panhard to be parallel to the drag link. There's a part that wraps around the axle, so the axle end of the panhard mounts above the axle. I don't use a panhard for my setup, so you may want to get better advice from guys that are using the scx10 axles, but I know for sure you don't want it screwed into the axle.
07-11-2015, 11:31 PM | #19 |
Great, thanks for the advice bro. I'll make it a 4 link front setup for now since I have the materials for it. I'll get a panhard on next placement order. Sent from my A0001 using Tapatalk |
07-12-2015, 08:48 AM | #20 |
Thanks brother Sent from my A0001 using Tapatalk |
My 1:6th Willys Jeep build (GI Joe) - Similar Threads | ||||
1/6 scale GI Joe Willys Jeep | Crevelinator | Large Scale Rigs | 7 | 09-24-2014 10:00 AM |
21st 1/4 Ton trucks JEEP Willys 1/6th scale build | DOCTORCUSTOM | Large Scale Rigs | 18 | 09-07-2012 01:09 AM |
