11-01-2015, 09:01 PM | #1 |
Rock Crawler Join Date: Mar 2013 Location: columbus
| 1/6th Jesse James Silverado SS This is my first 1/6th hard body build. I lucked up and found one of the 6th scale monstersto build. So what i did was remove all the toy grade electronics and everything from the bed. I then proceeded to clean the body of all the details, dirt and grime. I then applied three coats of plasti dip to the body. I then place the order for all the parts that I think I will need. List of parts i will be using. 1 Castle Creations 2200kv Mamba Monster system. 2 Castle creations CC BEC. 3 Savox Sa1238sg. 4 Gcm 1:1 transfer case. 5 Spektrum Sr 410 receiver. 6 Robinson racing performance idler gear. 7 Robinson racing steel lower diff gear. 8 Robinson racing super spur. 9 Mip drive shafts. 10 Axial universal set 11 K Money rc wraith steering linkage. 12 Axial 2.2 Walker Evans beadlock wheels. 13 Proline 2.2 super swampers. 14 Ssd Dimond center rear axle. 15 Ssd Diamond front right axle. 16 Ssd servo mount. 17 crawler innovations deuces wild closed cell foams. Last edited by greengoblin; 11-14-2015 at 01:29 PM. |
11-02-2015, 06:02 PM | #2 |
| Re: 1/6th Jesse James Silverado SS I'm in the process of building the chassis right now. I will post photos of the frame as i build it. |
11-02-2015, 06:29 PM | #3 |
cool project look forward to seeing what you build for a frame !? going to be a scale frame ? Steel material or ? Flat, round or what ? weld or bolt together frame ? entertain me... so's I can ignore my own project momentarily looking forward to some pictures |
11-02-2015, 07:39 PM | #4 |
Looks like it'll be a fun build! Get back to work, Taco! |
11-02-2015, 08:17 PM | #5 |
| Re: 1/6th Jesse James Silverado SS |
11-03-2015, 08:01 AM | #6 |
| Re: 1/6th Jesse James Silverado SS I just placed my order for my axles last night. Now the wait is on. |
11-03-2015, 08:08 AM | #7 | |
| Re: 1/6th Jesse James Silverado SS Quote:
The frame will bee 1/4 x 1/4 solid squar stock or 1/2 x 1/2 Square stock. I would like to be able to use the floor pan. Make it bolt into the frame that way it has the appearance of the bottom the truck. Doing this will also let me retain the inner fenders from the stock floor pan. | |
11-04-2015, 11:40 PM | #8 |
| Re: 1/6th Jesse James Silverado SS Some of the parts came in today Ssb axle Gcm 1:1 transfer case Last edited by greengoblin; 11-04-2015 at 11:44 PM. |
11-06-2015, 06:31 PM | #9 |
| Re: 1/6th Jesse James Silverado SS The parts are multiplying |
11-06-2015, 07:20 PM | #10 |
^like rabbits?
11-08-2015, 08:24 PM | #11 |
| Re: 1/6th Jesse James Silverado SS More goodies. I will have one more shipment by Friday and then its frame time. I may have went overboard. |
11-08-2015, 08:31 PM | #12 |
As long as the wife doesn't look through your posts on here, you're fine, if she does, you better have a good way to make it up to her |
11-08-2015, 08:33 PM | #13 |
| Re: 1/6th Jesse James Silverado SS lol whats that wife word u speak of Last edited by greengoblin; 11-08-2015 at 08:35 PM. |
11-08-2015, 08:58 PM | #14 |
Newbie Join Date: Sep 2015 Location: Lisbon, CT
This thing is going to be hard to tame with the MMM2 combo no? Mine tends to cog at low speed being un-sensored in my 1/8 MT4. Unless you're looking for a solid axle missile Like the SSD axles, definitely look solid. |
11-08-2015, 10:22 PM | #15 |
| Re: 1/6th Jesse James Silverado SS The MM2 is just to get it running. It will get a 1/8th brushless sensored setup before too long. Last edited by greengoblin; 11-09-2015 at 01:25 PM. |
11-09-2015, 07:02 PM | #16 |
11-10-2015, 09:38 PM | #17 |
| Re: 1/6th Jesse James Silverado SS I think the post ofice hates me. They're telling me it's going to be next Monday for the other parts. But i got this for yal |
11-11-2015, 05:37 PM | #18 |
| Re: 1/6th Jesse James Silverado SS I put in some wrench time on my day off. Its coming together slowly |
11-11-2015, 05:47 PM | #19 |
Nice compilation of axle parts there Have I mentioned I really like those SSD axles |
11-11-2015, 05:51 PM | #20 |
| Re: 1/6th Jesse James Silverado SS Thanks man. I forgot to order hexe's. |
