![]() | #1 |
Pebble Pounder Join Date: Dec 2014 Location: Oshawa
I picked up a new bright body for next to nothing and i wanted to make a scale tow rig out of it for my trailer and 1/10 crawler. I'm doing a very simple build with alum rails and some stock axle wraith parts. I might upgrade the parts later on down the road but 1st i just want it running. Stock wraith axles Transmission and skid plate As well as links and some hard wear. Some mock up of the axles and links. Rear links are 8inch top 7 inch lower ![]() Not sure if i will use 1.9 rc4wd wheels or not yet but there good for mock up ![]() As for mounting the body i will use body posts under the body and make some brackets. Still working on ride height and were to mount the shocks. But i have wheel base right. Its 17in WB ![]() But like i said i'm making this as a tow rig. This is how it looks with trailer and crawler behind it. ![]() |
![]() | #2 |
Quarry Creeper Join Date: Nov 2013 Location: California
Nice truck!
![]() | #3 |
Rock Crawler Join Date: Oct 2013 Location: The Netherlands
Looks cool. Verstuurd vanaf mijn G708 Oc met Tapatalk |
![]() | #4 |
I have made some headway on the susp. Front was easy as its all wraith. But rear i wanted to do something that would look cool. Thank you Hot Racing, I found out that the Yeti XL arms are almost spot on, So now its a Wraith/Yeti style susp. ![]() ![]() I will have more flex then i need so limit straps and bump stops will be needed. I do have shocks in it now but there just to hold it together, When its finished and at full weight i will have to see what to use then. ![]() |
![]() | #5 |
I wanna be Dave ![]() Join Date: Apr 2013 Location: Streamwood, IL
That worked out good! ![]() |
![]() | #6 |
Yes it did. After i have it running and work out the bugs i will build a nice custom frame for it. Main goal is to have it running fast
![]() | #7 |
Sure seems like the frame you have for it now works well
![]() | #8 |
I haven't updated this in a bit. Thats all my own fault. Just to busy and forget to,,,, Anyway The Raptor works better then i expected and everyone that has seen it so far on trials thinks its a neat truck and there surprised at how well it works for a big truck with tinny tires. ![]() It is water proof ![]() Works well in snow with some chains ![]() ![]() |
![]() | #9 |
I wanna be Dave Join Date: Sep 2006 Location: SoCal
| ![]() ...looks like a fun set up ![]() ...looking at the picture above ^ it looks as if the wheel base could be extended slightly. Mostly in the rear... but maybe a smidgen up front as well. Is there a video of it running !? hard to tell if it wheels as good as you would claim. Looks like the rear susp. would ride more softly... whereas the fronts, not so much. but I'll guess you tuned the susp. accordingly. why did you choose the progressive / rear shock mounting ? Or are both the front and rear progressive and the pictures are not reflective ? What's the over-all length of that raptor body ? I need a trailer too... but that one costs way too much !! and it still needs some work IMO. Looks good tho' ![]() Last edited by TacoCrawler; 12-30-2015 at 03:26 PM. |
![]() | #10 |
In that pic there were no axles in it., I was looking at size mostly and how it would work with trailer and crawler scale wise, But it works very well now and i have a few vids already. https://youtu.be/mkdmhc1r2j0 https://youtu.be/a3bsC0I805g |
![]() | #11 |
wow love those action shots - especially the up close shot of the doors and the snow flyin'! ![]() |
![]() | #12 |
Thanks I Always try to get good shots. Most are to late or fuzzy but odd time i get a good one. ![]() ![]() ![]() |
![]() | #13 | |
| ![]() Quote:
Not really supportive off road wheeling IMO Yes I realize I can turn it down and play my own. and I did. But I was really hoping to hear yer rig running with minimal noise interference. | |
![]() | #14 |
I dont do alot of vids speaker in back of the truck like that. Most of my vids i add music or let sounds of the run stay.
![]() | #15 | |
| ![]() Quote:
especially when filming using slow mo/60fps or the like. But other then that ^ I prefer to hear the natural sounds. And if I chose to need more entertainment, would play background music that is of my genre. was still entertaining to view sooo... I'll thank you for sharing it ![]() | |
![]() | #16 |
Thats cool Taco. I'm just having fun with this truck. So far it seems to do everything i want very well. Now working on rear bumper for it, ![]() ![]() Last edited by SirChirpAlot; 01-02-2016 at 09:47 PM. |
![]() | #17 |
Had a little time to work on Raptor. Rear bumper is mostly finished and mounted. Kinda looks like crap till i clean it up but welding in the cold with flux core sucks. Still need to make tow hitch as well as 2 brackets for shackles to mount to. Mesh cargo net and some kind of roll bar will finish out the back of it ![]() ![]() |
![]() | #18 |
Once you grind off the slag, and paint it , the bumper should look fine. Definitely needs a rollbar of some sort, maybe a rack like cmbscx10 did on his F350 HD build
![]() | #19 |
After i clean it up it will look better till i start bashing it off some rocks, I still need to make hitch for it and shackle points, Pondering a 3rd bar that will go under the body. I did pick up a few more New Bright bodys. 1 red and 1 gray so i now have extra's in case i damage one. I do like red one and will use this one for scale vids. ![]() Last edited by SirChirpAlot; 01-07-2016 at 08:54 AM. |
![]() | #20 |
Where are you finding the bodies? I like that big beefy front bumper ![]() |
New Bright Ford F150 1/12 scale found at the store today.... | aqwik69 | General Scale Talk | 3 | 04-07-2013 12:56 PM |
2.2 1/6 New bright f150 | Lonewolf | 2.2 Scale Rigs | 79 | 05-18-2010 07:13 PM |
