01-01-2016, 07:09 PM | #21 |
I wanna be Dave Join Date: Mar 2013 Location: Minden
| Re: Look what Snata did not bring me
I got my steering wheel installed And I got 2 Nitrous bottles and a tool box I'm thinking about putting on the center console I also got 2 extra Wraith seats, but they look a little small for the Humvee I really like the 2 fuel cells, I've been keeping these for a while cause they are to big for my SCX10's or my Wraith builds Need to buy some OD Green or what green matches the Humvee and Some Flat White or what White matches and detail out the fuel cells Got Flat Black paint for the mounts on the fuel cells I got a bottle of the blue paint for the Nitrous bottle And some silver for the valve on the bottle and some gloss back for the mounts Going to use some clear so the bottles match each other Last edited by kgb424; 12-11-2018 at 01:51 AM. |
01-01-2016, 07:42 PM | #22 |
I'm going to mount the 2 Red fuel cells, I made behind the cab wall And sand the tops of 2 white fuel cells and paint the matching green and turn them into utility boxes And mount them on top of the wheels wells center by the spare so they like if use the spare your tools are in the utility boxes Last edited by kgb424; 12-11-2018 at 01:51 AM. |
01-02-2016, 01:16 PM | #23 |
I liked it when it was still the "Pope mobile" !? Lol vision's of the machine gunner standing in a cylindrical turret servo operated, firing 360* at will is the only gunner entertainment I'd wish to follow. those wraith seats look too small to be 1/6 scale. smaller driver figures will look like children IMO This is supposed to be a 1/6 scale build right ? |
01-02-2016, 01:44 PM | #24 |
Hey Taco if you check your messages you see I asked about material I found for a chassis And I asked you about a chassis I found at BPC chassis and its post in this thread Maybe you can't read and only look at the pictures They still sell Hook on Phonics Can you read this Last edited by kgb424; 01-02-2016 at 01:47 PM. |
01-02-2016, 05:35 PM | #25 |
Thought I responded to inquiry or questions but fo random thoughts... I have no reply if the BPC chassis is steel... I might go that route but bolt on aluminum chit.. is not my forte ask me clear/concise questions and I will reply. In other words... put a farking " ? " at the end of each inquiry. If I don't know wtf yer talking about... I won't respond Now hurry up and get this dang thing rolling already. ^ 'cuz you pressured me too Lol Last edited by TacoCrawler; 01-02-2016 at 05:41 PM. |
01-02-2016, 06:06 PM | #26 |
Ok Taco I found some 1/8'' by 1/2'' by 36'' or 1/8'' by 3/4'' by 36'' of flat steel stock that is weld able can I use this material to make a chassis ?? The reason I mentioned the Chassis from BPC is because it use a Wraith skid plate and is the Same length as a SCX10 chassis That why I asked if it could be cut in the middle and sections added to it to make it a 16'' wheel base chassis ?? Cause I know I can't weld it, so that why I was looking built chassis I thought maybe I could stretch one out ?? to fit my needs Cause I don't know how to build a chassis to save my ass And never used a mig welder and do not want a piece of chassis with shitty welds every where Last edited by kgb424; 01-02-2016 at 06:13 PM. |
01-02-2016, 06:29 PM | #27 | |
| Re: Look what Snata did not bring me Quote:
but quite frankly... it's not rocket science. Of course welding skillz help some. But realize this... I'm not a welder I'm a self taught welder so I can repair my 1:1 rig. I didn't buy a welder for the rc hobby stuff. I used 1/2" X 1/8" mild, weldable, flat bar. Kinda soft by itself (stand alone) but when it's all welded together (boxed chassis) It will hold up fine... Unless maybe ya drive it off a 50 ft cliff Or drive it like ya stole it !? best part... it's inexpensive. Now a hardened steel might be stronger... but it will cost more to purchase... and ya might need have better welding skillz. I contemplated starting with a steel chassis and cutting that up to fit my needs. But either I couldn't find one... or thought spending that much coin and cutting it up... Was not in my best interests. So I made my chassis using puzzle pieces and welded those into two rails. Then boxed those together... and IMO... is good enough for my use. Last edited by TacoCrawler; 01-02-2016 at 06:31 PM. | |
01-02-2016, 08:16 PM | #28 |
I'm stuck not sure what the plan of attach is not sure what areas of plastic underneath the body need to be dremel-ed out with a cut off wheel ?? Cause the Humvee body has part of the 1/2 '' hollow rail that looks like the Humvee frame The bottom skid plate piece has another part of the hollow rail If look at the one picture there is room above the rails to make shock loops/shock mounts and center the front axle in the wheel well The Wraith skid plate almost fits in side the hollow rails If the rails where trimmed off I could run the chassis where the rails where I would have to use the right spacing to get the rear shocks to fit inside the bed and close the wheel well cause to put the rear shocks in the wheel well I need a 1/2'' space and need a 1 1/2'' or longer screw for the bottom of the shock to mount on axle The screw would bend or the lower link and shock mount would break I will figure out the rear shocks I'm thinking about buying a SCX10 tranny I would not have trim as much plus it can be mirrored or flipped You can not due that with a Wraith cause of Dig setup and its a lot bigger then a SCX10 tranny It looks like part of the console and back wall of the cab and maybe part of the bed and part of seats Need to be trimmed out Do not want cut to much or make it look shitty I want clean cuts and for it to look good and look the right way Don't want to butcher and screw it up I still need help figuring out a chassis I 'm in over my head on this build and while admit it and need help Cause I had to have a Humvee A Willy's I could of used the Wraith skid plate and the plastic chassis and call it good But no I had to be different And screw my self once again Happy New Year Last edited by kgb424; 12-11-2018 at 01:51 AM. |
01-02-2016, 10:50 PM | #29 |
I responded to your pm tho' I'm still not 100% in understanding of what you're wanting to do ? |
01-02-2016, 10:59 PM | #30 | |
anyone can weld, by gaining a little knowledge of the matter and practicing their new found skills and practicing techniques. Know your machine and how it works. And be sure it is working as it is supposed to. use gas (CO2/Argon 75/25%)... f the other non gas method If I can teach myself to weld... then anyone can learn to do it. practice makes for better | |
01-02-2016, 11:18 PM | #31 |
I cant not afford the bottle and the service, and there is no way to heat my shop enough too keep my hands and toes from going numb So I won't be working out there any time soon that's where the welder is and its too freaking cold for me and there is a breaker panel with 220 or 110 for welders I can not run the welder in the garage there are only a few outlets and there not rated for a welder the shop in back of property is rated I got a 100 gallon compressor to run air tools I could never run the compressor in my garage and it sucks and pisses me off I'm going to look for a new diamond cut off wheel for the my Dremel and cut out the hollow rails out and trim out some of the extra plastic So the chassis goes down the center of body And ditch the bottom plastic skid plate and make some sliders and close them in with some plate I need help figuring out a chassis Last edited by kgb424; 01-02-2016 at 11:29 PM. |
01-02-2016, 11:57 PM | #32 | |
just need to draw it out, to share with them, so they have understanding. oh... ^ and pony up for that service cost ! Lol Once you figure out how ya need the basic chassis configured... contact one of the vendor's here and start communicating with them !? | |
01-03-2016, 12:35 AM | #33 |
I found a metal cut off wheel its one of my old ones and its pretty dull and worn out Before I bought the quick change spindle and the quick change diamond blade which I can not find the diamond blade but found the spindle I got it trimmed out with the old one, it needs sanded and cleaned up And when I was trimming under the body the seats it came out So I don't know if that is good or bad cause its the back of the cab also I left the plastic chassis ends on and the trailer hook Cause I like how it looks Last edited by kgb424; 12-11-2018 at 01:51 AM. |
01-03-2016, 01:10 AM | #34 |
I just had a thought Would the body be too high too sit on top of the rear shock mounts on the chassis and make holes for body posts ?? I like how the SCX10 has body posts on the shock mounts Instead of cutting out areas and have the shocks go up thru the bed Then I would have to make different body mounts and different holes in the body for posts Last edited by kgb424; 01-03-2016 at 01:21 AM. |
01-03-2016, 02:05 AM | #35 |
Hey Taco I traced out the body of the Humvee on a piece of card board from the box it came in how do I figure out the shape of the chassis I need to look at your 1:6 build and read it and see if I figure it out If not you know I will questions and be bothering you again Last edited by kgb424; 12-11-2018 at 01:51 AM. |
01-03-2016, 02:08 AM | #36 |
| Re: Look what Snata did not bring me |
01-03-2016, 02:34 AM | #37 |
I have measured things cause I never lie figure that one out Like I said I need to need to look at your build and read it Its how I am it takes me a minute cause I don't do a lot of fabricating especially some thing that needs cut and welded and is multiple pieces and needs to be dead on and square and not eye balled So I need to put some thought into this and not make a piece of shit thank you did I wish you a happy new well hear you |
01-03-2016, 03:18 AM | #38 |
01-03-2016, 12:36 PM | #39 |
Go to Bitter Ends "Scrap Metal Build", he uses a contour gauge on the bottom of the body to get the shape for his frame. You can pick a contour gauge up at any of the local big box hardware stores for around $10
01-03-2016, 02:15 PM | #40 |
I can think of a better ways to spend $ 10 but whatever floats yer boat. I used a common tape measure and some basic math. Like I said prior... It's not rocket science. The rise and fall of my frame's rails were determined by using the measurements of the original Wraith tube chassis. Tho' I did not bend/narrow the frame rails (front/rear ends) The way the Wraiths tube frame is. It might be something one might do... to better the shock mounting positions. But that would likely be dictated by the body's fitment. And it will be difficult to get those bends precise/equal unless you create a jig that ensures they are welded/bent equally. The lengths of my wheel well arches are longer then need be. But my goal was to allow for wheel base adjustment. And to hide the vertical rise of the frame rail behind the body. And also to ensure that the link's would never contact the frame within their window of articulation... ever. Even if I increase the shock's length slightly and the wheel base changes... My chassis design has room for adjustment. As I stated before... the Wraith's chassis center skid is the starting point and will determine the frame's width at center (100mm). The skid dictates 100mm wide for the full chassis length unless yer gonna bend both ends inwards some. ^ Too much work and not necessary for my circumstance. Even tho' my chassis was built for this particular body... I'll hope I could adapt my chassis to other 1/6 scale bodies if I happen to find one that I like. ^ was in fact going to try to adapt the Nylint/Funrise Scorpion body to this chassis one day... But I'm not really in any hurry with that. I like how my TJ looks and how well it wheels. Even tho' I'm not a jeep fan per say |
Look what Snata did not bring me - Similar Threads | ||||
**Bring IT!!!! ** 4cRc2 G6 Fun Run ** BRING IT!!!! ** | Mudeater67 | New Mexico | 29 | 08-10-2014 09:21 AM |
Bring on the snow | blumaro | RC4WD Trail Finder 2 | 16 | 01-01-2014 09:26 PM |
Bring on number 3 !!!! | ScaleReady | Chit Chat | 9 | 08-19-2012 08:39 PM |
please bring a grill | BILLYGOAT | Colorado | 3 | 06-26-2009 05:33 PM |
bring it | COUIERIPER | Chit Chat | 42 | 01-19-2006 11:20 PM |
