01-15-2016, 07:38 PM | #101 |
| Re: Look what Snata did not bring me
Cutting an inch out of the middle of the window frame is the way to go, although you might be better off just making a new shorter frame out of styrene. And if you look at your post #77 you'll see that the door frame windows sit lower than the stock windshield, so if you take an inch out of the front windshield, you'll also have to take an inch out of the side windows as well, then you won't end up with that gap in the corners, capish? ( understand )
01-15-2016, 08:42 PM | #102 |
I wanna be Dave Join Date: Mar 2013 Location: Minden
If you look at the 2 pictures of the Black Humvee You will see the top of the doors stop before the pillars start The curve of the roof So I might get lucky and only need to trim a little off the top of the doors the front pillar is 1'' taller than the top of the doors Last edited by kgb424; 12-11-2018 at 01:50 AM. |
01-16-2016, 11:07 AM | #103 |
Sometimes when you can't sleep at night You just got fire up the chop shop and this is what happens I dropped 1'' out of the front windshield pillar and windshield, its not pretty but is even and square needs to glued or backed with styrene and filled and sanded I chopped an 1/8'' off the top of the doors, and I cut out a 3/8'' section of the doors out, any more the angles on the doors would not line up The doors lost about a 1/2'' in total, I might trim the doors a little more to drop the top of the doors and make it look a little more the Black Humvee Last edited by kgb424; 12-11-2018 at 01:50 AM. |
01-16-2016, 11:21 AM | #104 |
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
Did you delete your thread in the paint and body section? If you shorten the height of the window opening in the door you will most likely need to cut the top of the door and lengthen the top of the door to keep the angles correct. You might not like answers like this but you are trying to do a simple chop top and people are trying to help you.
01-16-2016, 11:24 AM | #105 |
That looks a lot better, kgb |
01-16-2016, 12:31 PM | #106 |
Its been dropped and chopped I'm going to order styrene and see if I can find some ABS glue, to re-attach the front pillar back in and the seats need glued in also I had to chop an 1/8'' of an inch out of the doors Too get the exact look I wanted now the top doors stop just as the curve of the roof begins now the middle loop is possible cause the chop is open 24hrs Last edited by kgb424; 12-11-2018 at 01:50 AM. |
01-16-2016, 12:49 PM | #107 |
rag top or hard top ? looking good... is it done yet ? |
01-18-2016, 12:07 AM | #108 |
I tried to start my lay out of the chassis rails And are having problems figuring out How to layout the front and rear shock loops on the plate Before I cut out my chassis rails So the shocks are straight up and down and my wheelbase is correct I mounted 2 rear SCX10 shock loops onto the top of the straight chassis rails I then mocked up the front axle and mounted the shocks to the shock loops At where I thought was the correct position but its not cause the shocks are not straight up and down And when they are straight up and down the axle looks to far forward and does not look right Now I'm not sure of where the shock loops go To draw them out in my chassis rails layout So there in the right position and the wheel base is correct Now its back to square one, cause I have no idea how to do this, layout and design is not my thing And none of this is easy for me Stuck now Last edited by kgb424; 01-18-2016 at 12:13 AM. |
01-18-2016, 01:11 AM | #109 |
Rock Crawler Join Date: Dec 2008 Location: Marengo, Ohio
Make the shock hoops separate from the chassis rails. Wont look as tidy but its an easy way to get them mounted exactly where they need to be.
01-18-2016, 06:50 PM | #110 |
It cost me more for the 16 Traxxas Revo rod ends the #3547 the ones that 8/32 all thread into I bought 2 36'' pieces of 8/32 all thread some 8/32 nuts to un-booger the threads after cutting I went to Napa the only place that sells brake line in 5ft pieces and it would of cost me over $30, just for the 1/4 brake line So when browsing thru Lowes, I discovered the plastic tubing in the Drip line area It is 1/4'' Poly Tubing, it comes in different colors, I got the black and I almost bought the Dark Green tubing, I saw they have brown, light grey, maybe red The tubing slides over the all thread easily and does not look that bad I got 50 feet of it for less then $5.00 for the roll I made one link to see what they will look like I like it, they are going to look dam good for home made links Taking a break on the chassis while waiting for my rod ends CKRC was out of stock of the Rod Ends, so I ordered some and checked out there new store Its pretty nice setup, they got a lot more room and a lot of new stuff they are now selling Last edited by kgb424; 12-11-2018 at 01:50 AM. |
01-18-2016, 07:28 PM | #111 |
Looking good kgb |
01-18-2016, 09:39 PM | #112 |
kgb do you think that plastic tubing is going to strengthen the all-thread enough to keep it from bending ? Especially since you told me slowww sucks. And hauling butt is the only way you'll roll I've seen links made with metal tubing slid over the all-thread and I can see how that increases the all-thread's strength. But I really don't see plastic tubing increasing strength or really being very grind durable. You probably saved a buck today... but you'll likely be spending more again later. good luck with yer budget chit !? Lol |
01-18-2016, 10:03 PM | #113 |
At Napa they only had 2 sizes of brake line the first one is smaller on the inside then 8-32 and it would not fit, I tried to shove it there The next size they carry is 1/4'' and it is just like the tubing, the 8-32 all thread slides in easily There is a little play or gap between the all thread and tubing, and the same with the brake line They had 51'' pieces and 30'' inch pieces of brake line and other lengths with fittings on both ends They don't sell plain brake line, the kind you use a flanging tool, too make your own brake lines I need to make my links and then see how many feet I need Last edited by kgb424; 01-18-2016 at 10:07 PM. |
01-18-2016, 10:08 PM | #114 |
Help me build my chassis Taco so I can get it rolling |
01-19-2016, 06:17 PM | #115 |
Give him a hand Dell, This looks like a kick-ass build, and you seem to be the only one he'll trust!
01-19-2016, 09:46 PM | #116 |
Its on now for almost $11.00 and the same Revo rod ends I ordered Bought a 10-24 tap and drill bit combo and 2 pieces of 10-24 all thread 36'' long and a package of 10-24 nuts Once I get the links to length I will then look for some tubing of some sort 10-24 uses 1/4 tubing and there is very little gap in between Cause they won't bend that easy So and have a nice day Last edited by kgb424; 01-19-2016 at 09:53 PM. |
01-19-2016, 10:12 PM | #117 |
Your right I do trust Dell He gifted me 2 custom made front bumpers with skid plates For my SCX10's and they are very nice work And Dell has been straight up and no bullshit and we been giving each other shit since then I'm asshole straight up won't deny it Dell tolerates me too a point then I get the Last edited by kgb424; 01-19-2016 at 10:19 PM. |
01-19-2016, 10:55 PM | #118 |
| Re: Look what Snata did not bring me |
01-19-2016, 11:39 PM | #119 |
See exactly what I'm talking about I contacted venders on here a few times and my money is no good no still don't even get the no thank you or interest in your products nothing, Cause GCM makes a 21'' inch leaf spring chassis, and have contacted at least 3 times and again nothing asking them what wheel base is achievable And if a 16 1/4'' wheel is possible with their chassis And no reply's and the same for the other venders I contacted The only venders to reply back where Holmes Hobbies, R2J, And Duuuuuude The first 2 were when I first got on here, and Duuuuude was recently and the same day, I asked a question he replied the rest of them don't even bother Last edited by kgb424; 01-19-2016 at 11:53 PM. |
01-20-2016, 12:01 AM | #120 |
| Re: Look what Snata did not bring me what you talkin' 'bout Willis ? the Vendors here don't want your money !? really ?! cash up front ? never heard of a capitalist turning down money ? hmmm who'd you inquire with ? I'd vouch for your easy nature/honesty of doing business with. but, hand holding... I'm not so good at ------ because you edited yer gibberish -------- You're probably inquiring with the wrong vendors rccrawlers > vendors > vendors market > chassis and suspension read thru those threads and inquire with the vendors whom build frame rails /or custom chassis's. gotta be someone there that likes money !? Last edited by TacoCrawler; 01-20-2016 at 12:33 AM. |
Look what Snata did not bring me - Similar Threads | ||||
**Bring IT!!!! ** 4cRc2 G6 Fun Run ** BRING IT!!!! ** | Mudeater67 | New Mexico | 29 | 08-10-2014 09:21 AM |
Bring on the snow | blumaro | RC4WD Trail Finder 2 | 16 | 01-01-2014 09:26 PM |
Bring on number 3 !!!! | ScaleReady | Chit Chat | 9 | 08-19-2012 08:39 PM |
please bring a grill | BILLYGOAT | Colorado | 3 | 06-26-2009 05:33 PM |
bring it | COUIERIPER | Chit Chat | 42 | 01-19-2006 11:20 PM |
