Go Back   RCCrawler Forums > Scale Rigs General Tech > Large Scale Rigs
Thread: Aluminum framed Willys build
Old 01-03-2016, 09:44 PM   #1
Default Aluminum framed Willys build
I quit racing and producing on road CF parts 5 years ago. Before I quit, I picked up a GI Joe Willys and planned to build a crawler. The body has sat in the garage since. It's time to build it. This is what I'm starting with.
This first thing I did was cut off the front body extensions that hang down to meet the stock chassis.
I mounted the body in my mill and milled the area flat to accomodate the new frame.
The new frame is designed to snug up to the body and raise the front of the frame to just under the grill.
DPowell is offline   Reply With Quote
Old 01-04-2016, 06:12 AM   #2
Default Re: Aluminum framed Willys build
I got in a hurry to post a picture of the frame and didn't provide any real details...
The frame is machined from 3/8" flat bar and because of its length (17 7/8"), the left and right rails are two piece. The rails are joined together in the center using a half lap joint. I need to cut the screw bosses off the bottom of the body and then I'll post a picture of the body fit.
Doug
Old 01-04-2016, 01:40 PM   #3
Looking good man, I just started my willys but don't have the fancy equipment you do lol.
ScalerLover is offline   Reply With Quote
Old 01-04-2016, 06:10 PM   #4
Mike Flea's Avatar
Looks interesting, , have you looked at any of the other late model Hasbro builds?
Mike Flea is offline   Reply With Quote
Old 01-04-2016, 06:29 PM   #5
Yeah, I've looked and looked some more. There are some great builds out there.
Old 01-05-2016, 12:46 PM   #6
Here is the body fit to the frame. Now, it's back to body work and time to build a tubing bender.
Old 11-03-2019, 07:21 PM   #7
This GI Joe Willys body and frame are now for sale on Ebay. Take a look if interested.
https://www.ebay.com/itm/254410286603
Aluminum framed Willys build - Similar Threads
Willys build-V8 truckbob Large Scale Rigs 27 02-12-2014 04:41 PM
1/6 willys build dfox Large Scale Rigs 5 11-20-2013 07:15 AM
~53 Willys 2010 Comp Rig Build~ RC4WD MOA Worminator Build~ 53 willys General Crawlers 108 11-28-2011 12:42 AM
Another Diaz Framed Build..... xxkalladorxx 2.2 Scale Rigs 6 02-17-2007 01:52 PM
Willys Build Up!! swamped2a General Crawlers 7 11-23-2005 10:51 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
