Go Back   RCCrawler Forums > Scale Rigs General Tech > Large Scale Rigs
Thread: SwampDawgs Jeep build
Old 03-21-2016, 03:34 PM   #1
Default SwampDawgs Jeep build
I just won this on a bid on Ebay for 15.00 USD lol
Stoked to start this build already!
Parts list;
Using a wraith skid & scx10 rails AR60s axles
Axial hardened steel diff gears
VP lockers
Wraith transmission
(0.8mod) spur/pinion
Tekin 13.5t brushless sensored
MMP ESC
CC BEC
Servo from C1 Apache
Wildpeak tires 2.2
Wraith shocks 30w oil
MIP drive axles f/r
Axial alloy 4-links f/r
The rest will work itself out once i start in on this.
Sent from my LG-D852 using Tapatalk
SwampDawg is offline   Reply With Quote
Old 03-21-2016, 07:00 PM   #2
Default Re: SwampDawgs Jeep build
That's the same body I used for my build
Mike Flea is offline   Reply With Quote
Old 03-22-2016, 09:52 AM   #3
Itll probably be a week or more before it arrives?
Old 04-05-2016, 12:36 PM   #4
Right now it sits too high but thats only as i piece this together. When its physically mounted to the chassis i will tune suspension to match it where it looks like a normal height.
Just basic cuts and mocked up.
This just showed up at my doorstep. Damn is this thing big haha
Im not into spending heaps on this so ill use styrene later to tunnel the tranny and hide it.
Arrma Raider assault buggy
Old 04-06-2016, 02:22 AM   #5
Can somebody help me here....
How are you guys mounting this body to a chassis?
Seems only mounting point is up front on the flat portion & even that seems limited. With the firewall that hardly can be justified because it not actually part of the jeep, its a piece of plastic glued the body from Hasbro?
Old 04-06-2016, 10:05 AM   #6
Rear mount wasnt too bad... ?
The front one ..still not sure yet with that firewall not actually physically part of the body itself? In a roll over i think may snap this section out?
Still no front mount but got the suspension whereabouts i want.
Old 04-06-2016, 02:07 PM   #7
Body mounted but ill swap these fugly phillips 3mm later with hex hardware. I am seriously running out of stock doing all these projects haha
Start to the electrics...still need to mount the lipo somewhere & somehow under the hood.
Old 04-06-2016, 03:19 PM   #8
Battery tucked away...
Ill get this custom motor i made years ago in this jeep.
1st test run turned out pretty good. Some tweaks needed but overall i am satisfied.
Old 04-06-2016, 08:11 PM   #9
What I did to mount the chassis to the body is I used a couple of 1" x 1" L brackets on the rear ( post # 19), and flat 1" x 1" l brackets on the front, but I had to bend one side of the L bracket 90 degrees to connect between the chassis and the grill ( post # 40, you can see the side of it), "New Project (for me)"
Old 04-06-2016, 08:25 PM   #10
Another question is how do you guys keep the hood closed while driving?
If this took a bad roll i think it would destroy the hood?
Tia
Old 04-06-2016, 08:33 PM   #11
Your Jeep and mine are different than the later model Hasbro jeeps, that a lot of these guys have. Mine still has the tab on the front of the hood, that holds well, even in a rollover. That tab slides in to the center grill slot, if you still have it on yours. If not, you can use a couple small rare earth magnets, (Home Depot, Menards), glue to the underside of the hood, and use a couple small metal brackets attached to the grill. You may need to only use one though, those magnets are strong.
Old 04-07-2016, 01:20 PM   #12
Passenger floorboard fab'd
Still needs drivers side but i ran out of stock. Lol
So...some fun running...
Ran great and performed better then i anticipated but servo is too weak.
Old 04-07-2016, 06:42 PM   #13
When I first built my Jeep, I was running a Hi-Tec 645mg, and ran into the same issue, servo would bind up , or wouldn't turn the 2.2's when I needed it to, also the Jeep had gotten heavier with the addition of Joe and Barbie, and scale accessories. I'm now running a Savox SA-1231S, 444oz digital servo, around $60. No more steering issues, and no binding problems.
Old 04-07-2016, 06:49 PM   #14
I figured id need a 400+ oz servo.
Old 04-08-2016, 06:51 PM   #15
Definitely!
Old 04-08-2016, 07:05 PM   #16
I saw you had questioned about what kind of glue to use, on another thread. When I used styrene to make the new trans tunnel, boxed in the rear shock towers, and made a rear body panel, I used Testor's model cement. No problems, nothing coming apart, and I've taken some bad tumbles. CA would probably be better, but use a slow or medium setting CA, so you can move pieces around if you have to, before it sets.
I cut the side mounted spare mount (original plastic) off the side of mine, and tried using the Testor's to mount it on the rear of the body, but ended up tearing it off when the spare tire got caught on a rock...didn't damage or tear off the rear body panel, only the spare tire mount. Tried CA glue after that, and tore it off a second time!, LOL. Finally ended up making a steel wraparound rear bumper, with a vertical piece of metal for the spare mount.
Old 04-08-2016, 10:12 PM   #17
Managed to go buy more steel sheet and fab up the other floorboard.
Now to physically mount the floorboard to the jeep body. This will further secure it. Also allows for wires to be tucked under the seats without hanging below the chassis.
Old 04-09-2016, 01:00 PM   #18
Todays trials....lol
Knowing my servo is weak i take it out for some articulation runs. But...
Trying to tackle this task put the strain on the servo and burns it up and strips it. Haha
What a tank this jeep is. Lol i also have the wheels weighted. Off to the shop to buy a 400oz-tq servo
Also bracing my towers as the Apache C1 shocks i installed this morning tend to pull them outwards.
Old 04-09-2016, 04:56 PM   #19
Floors done...
Something for the figure to hold onto haha
Has to have a steering wheel. Lol its rough but not yet finished.
Old 04-09-2016, 07:17 PM   #20
Mine came without a steering wheel too, I cannibalized the steering wheel from a doorless 1/6 Avalanche, and the steering shaft was made from one of the original axles I cut off from the stock Jeep.
SwampDawgs Jeep build - Similar Threads
Jeep scaler build and comp micro crawler build droopmodmrc Losi Micro-Rock Crawler 1 12-25-2012 12:34 PM
SwampDawgs SCX10 build SwampDawg Axial SCX-10 41 09-28-2010 07:30 PM
another jeep tj build (and my first build thread) scorpion/king 2.2 Scale Rigs 5 12-18-2009 02:04 PM
swampdawgs jamesdezy Tires and Wheels 9 01-16-2006 07:26 PM
Foams in Swampdawgs. Zapper2003 Tires and Wheels 7 10-20-2005 11:46 AM
