05-06-2016, 10:35 PM | #21 |
I wanna be Dave Join Date: Mar 2013 Location: Minden
| Re: My 6th Scale M151A2 Jeep Mutt
Here is a Jeep Build using A transfer case under the floor plan It gives me ideas cause I like how they Mounted leaf springs I could do that if the SCX10 axles were wide enough I also like the fact he mounted the orignal tires and rims by mounting Them on plastic 1.9'' rim so it really has a scale look Not sure if the tires would have any traction at all Would look killer though |
05-07-2016, 11:51 AM | #22 |
Thanks to jason1973 For hooking me up with a RC4WD R2 transmission and a 32 pitch pinion Now I'm looking for a small 1:1 transfer case I seen some come with a mounting plate Need to look Last edited by THX_138; 05-19-2016 at 08:15 AM. |
05-08-2016, 04:01 PM | #23 |
I got the Jeep Mutt Wheels mouted I took a pictures of them on my 6th scale Humvee I also mouted up the Humvee wheels |
05-09-2016, 09:31 PM | #24 |
Yeah Baby Look what I got for $20 bucks Its a 1:1 transfer case with mounting bracket I also got the tracking number for the R2 transmission And it should be here in 2 days Last edited by THX_138; 05-19-2016 at 08:17 AM. |
05-10-2016, 01:24 PM | #25 |
I ordered my rebuild kit for the R2 Looks like every you need to have new transmission |
05-11-2016, 11:16 PM | #26 |
Its a good thing I ordered a rebuild kit for the R2 I took it apart and cleaned it with some Simple Green and some Rubbing Alcohol And you can see the teeth are elongated on gears and worn I used a liitle Red And Tacky and hooked a motor up it too see if it smooth out any And there is a little vibration it might be the short shaft is bent enough at hight rpm you feel it It fits nicely in the space under the hood I used a piece of 2 faced tape to mock it up And the R2 fits better than the SCX10 tranny did cause it was cocked And not flat because the motor hits the fender wall that is tapered so it lifts one side of the transmission And I would have to make a mount some how The R2 sit flat and the output shaft is in line with the transfer case I'm going to have to make some spacers for in between the mounting plate And the transfer case to aline the drive shaft angles The transfer case and mounting bracket are on a slow boat from China And R2 kit is coming from RC4WD so who know when it will ship They have screwed me on shipping twice before Last edited by kgb424; 05-11-2016 at 11:38 PM. |
05-11-2016, 11:57 PM | #27 |
Going to order a couple different 32 tooth pitch pinions So if I understand this right The higher number of teeth on the pinion The slower the output shaft spins Correct ?? What size pinion would you select I have a couple 14 teeth pinions Not sure of what size pinion to buy Any suggestions ?? 8T = 30.4:1 9T = 27.0:1 10T = 24.3:1 11T = 22.1:1 12T = 20.3:1 13T = 18.7:1 14T = 17.4:1 15T = 16.2:1 16T = 15.2:1 17T = 14.3:1 18T = 13.5:1 19T = 12.8:1 20T = 12.2:1 Last edited by kgb424; 05-12-2016 at 12:12 AM. |
05-12-2016, 04:25 PM | #28 |
Hey Mike Flea Is this the build you were talking about The guy bought it used and they parted out a Wraith Not sure I like but it is a Jeep Mutt And there is some ideas there I private messaged the guy He has not posted in over a year Last edited by THX_138; 05-19-2016 at 08:21 AM. |
05-12-2016, 04:37 PM | #29 | ||
| Re: My 6th Scale M151A2 Jeep Mutt Quote:
But think that may be too slow for your like. so I might think the 16t might be nearer to your start point. Regardless... I would purchase 16t / 18t pinions to have more options. But realize I'm more about torque and slower crawl speeds. Not much difference is noticed when changing one tooth on a 48p pinion. Tho' two teeth difference is usually more noticeable. But honestly that may be different when running 32p gears. So maybe someone else will chime in regarding. But I'd use the 14t first and make note of your top speed and what speeds you wish to attain. Check the motor's temp as you increase the pinion's tooth count. 150* - 170* F... I would think should be the desired heat range. I don't know squat about that Tekin 35t motor as I use the HH TM 35t motors instead. But if the Tekin 35t is near similar in torque you should net near the same performance That the HH TM 35t would have. would be my guess. --------- Why does your center transmission have a forward/rearward input shaft ? Guess I'm not familar with that need. Again... I'm not familiar with the RC4WD R2's internal 32p gearing. Nor how that might have effect on pinion tooth selections. It's possible the increasing or decreasing one tooth on the pinion may have a more noticeable effect when using the R2. wish you good luck in your venture | ||
05-12-2016, 07:32 PM | #30 |
^ That's the one! Looks like he actually used 2 transmissions, one on the motor, and one as a transfer case. |
05-12-2016, 08:31 PM | #31 |
They guy said he was going to change out the second tranny for a transfer case But they have not posted any thing in long time I'm thinking of buying another Wraith skid plate and split it Down the middle and use the skid plate halves for my upper and lower link mounts There is no other Jeep Mutt builds out there too get ideas from So once again its comes down too me coming up with some thing Bad ass like I did with the Humvee My style of Humvee has not been built until I did mine I figured out the R2 and the transfer case Just need to figure out a chassis Maybe 2 subfames I'm open too suggestions Last edited by kgb424; 05-12-2016 at 08:44 PM. |
05-12-2016, 10:04 PM | #32 |
I think you've got the right idea, and are on a good track. You did very well with the Humvee, you'll figure out a similar chassis for this one!
05-13-2016, 12:44 AM | #33 |
Does anybody know do you need hardened pinion gears To use with a R2 transmission ?? I ask cause I found this 8 tooth 32 pitch that says its specially for the R2 transmission I looked on the RC4WD web site the harden 8 tooth 32 pitch pinion is discontuined So what pinions are you supposed too use Cause my 14 tooth 32 pitch pinions are hardened like the 8 tooth one There normal pinions in the second picture What do you think ?? Last edited by kgb424; 05-13-2016 at 01:46 AM. |
05-13-2016, 07:43 PM | #34 |
alrighty then I got my R2 rebuild kit today This thing now spins like butter It was the gears and the short shaft Going to have to take it apart and clean it one more time I used a little Red and Tacky #2 and then cleaned it and then tried some Green Water Proof Marine grease And it flung both of greases off over the inside of the transmission I'm going to use this Tiger Drive Dry Ice Race Lube I have been using it on the Mips drive shafts on my SCX10's And the Dry Ice leaves a film there is nothing to fling off I will have to give it a try Last edited by kgb424; 05-13-2016 at 07:52 PM. |
05-15-2016, 08:28 PM | #35 |
Yeah Baby I'm liking my Wraith with SCX10 axles And 1.9'' tires and wheels I tried my Pitbull Rock Beasts and they are not tall enough I then tried my XL Super Swampers and they are just right and I like the height When I had the AR60 axles on my Wraiths I had 2 that I parted out I was using the curved Axial rods ends and don't know what the wheel base was But with the SCX10 axles the wheelbase was 14'' using the curved rod ends so with the AR60' axles the wheel was 14 1/4'' to 14 1/2'' is my guess I changed out the rods end to the short ones in the picture on the right they are alot shorter They came from extra part trees that I forgot where they were stashed And it shorten the wheelbase to 12 7/8'' and looks better shortened I got a body coming its going to be different I put the Mutt wheels on and did a flex shot Last edited by kgb424; 05-15-2016 at 08:39 PM. |
05-16-2016, 11:55 PM | #36 |
I got the transfer case And I opened it up Too check it out and they put very little grease it So I added some more Red N Tacky |
05-18-2016, 10:35 PM | #37 |
I'm missing a 30mm post that connects the servo and steering knuckle It is in the mail and should be here soon Otherwise my front axle for my 1.9'' Wraith Is ready to go I'm working on some 1.9'' wheels for the Jeep Mutt and the Humvee Need to figure out some tires and foams |
05-19-2016, 05:07 PM | #38 |
I'm so freaking pissed off The guy that I ordered my body for the Wraith Paid for 2 or 3 day delivery its coming from Texas It went to Las Vegas and left on time put instead of coming to my town It goes 500 plus miles east ends up in Ely Nevada I looked it up Ely NV is 89301 Where I live is Minden NV it is 89423 How does it end up in the town 500 miles in the wrong direction So why bother paying for 2 or 3 day service when it won't be on time I bought it thru E-bay using Pay Pal Just like the 100 plus purchases before My address is current and valid and verified But there is that one that goes to the wrong XXXXXXX place What really pissed me off is I checked the tracking and it said it was miss shipped Then I check back later and they changed to it left Ely and it is on the way My mail person has been here and gone so its not coming today Again why pay for 2 or 3 day delivery when they don't give shit if its ever delivered Cause I called the 1-800 number and my local post office and asked why did it go Ely and got bullshit or no answer and put back on hold It just shows they could give a XXXX less Update the assholes sent it back to Las Vegas which is 1,800 miles from me cause 500 miles to the east was not good enough So now I have no XXXXXXX idea where my body is cause it left Vegas again Why in the XXXX did go to Vegas in the first place I'm 1,800 miles from there They can't figure out xxxxxxx zip codes Wtf is going on Where is my xxxxxxxx package Last edited by kgb424; 05-20-2016 at 01:43 AM. |
05-19-2016, 05:16 PM | #39 |
I got my posts and they are the wrong length They were too short but I was able Too make it work and get the axle centered |
05-20-2016, 08:04 PM | #40 |
I mixed my own OD Green It could be a little darker Maybe it will darken once it dries I like the shade it came out I'm going to let it dry and cure And then maybe shoot some flat clear Over the chassis too help seal the paint I'm hoping the post office will stop Screwing around cause my body left Vegas for the second time And probaly won't get it till next week Monday the 23rd is birthday So at least I get some thing too unwrap If it even shows up Last edited by kgb424; 05-20-2016 at 08:15 PM. |
My 6th Scale M151A2 Jeep Mutt - Similar Threads | ||||
Mutt - ClassiCutCustoms | Dreufic | Videos! | 6 | 03-11-2015 04:55 PM |
the mutt | lifted_xj | Axial AX-10 Scorpion | 6 | 01-03-2011 01:51 PM |
my mutt! | krono7s | General Crawlers | 5 | 10-06-2010 06:22 PM |
The 1/6 MUTT | Flying Dutchman | Large Scale Rigs | 24 | 05-10-2010 02:35 PM |
