05-22-2016, 02:31 AM | #41 |
I wanna be Dave Join Date: Mar 2013 Location: Minden
| Re: My 6th Scale M151A2 Jeep Mutt
I got my Wraith chassis painted OD Green And I got my Spawn body and I like it I need to cut the front of the body For the metal bumper/stinger and for the lights |
05-22-2016, 09:52 PM | #42 |
yeah baby For $2.20 it was miss marked I bought this 16'' x 6'' foundation vent Too get a 14 1/2'' x 6'' 1/8'' mesh piece Enough to make a new grill for the spawn body And I could also make a new bed cover For the Wraith not sure its pretty flexible It might not work for a bed cover but will work for a grill |
05-22-2016, 10:59 PM | #43 |
Yeah baby Its a good thing I buy extra R/C stuff I have four of these 2 are a little bigger than the other 2 Going to use the 4WD emblem part of them And put one of the bigger ones on the grill, The other bigger one on the tailgate And the smaller ones on each quarter panel My Wraith is going to look badass and one of kind Cause I can't leave shit alone Last edited by kgb424; 05-22-2016 at 11:12 PM. |
05-23-2016, 01:00 AM | #44 |
Or I could do something Completely different And use a Yoter grill and narrow it Then cut out the sections in the grill and back it with screen and a 4WD emblem Not sure how to attach the Yoter grill to the Spawn body I still think the screen grill would be easier Just not as custom |
05-24-2016, 11:34 PM | #45 |
I kept it simple but did some customizing I have done very little Lexan work Used peices of Lexan from the half roof To fill in the knotches where the bars from stock brush gaurd goes thru the body Cause if not there would be a strip of the body missing It will need to have 2 new slots cuts for the metal brush gaurd I like how it came out for never doing this kind of customizing Going to look good with the 4WD emblem centered in the grill Last edited by kgb424; 05-25-2016 at 12:47 AM. |
05-25-2016, 05:10 PM | #46 |
That turned out real nice, that screen fits the bill |
05-25-2016, 10:52 PM | #47 |
It looks like the front is missing something I tried to keep the headlight part of the stickers But they got tore up when I cut out the grill section I need to look for some headlight or turn signals It needs something I didn't want the lights in body So I can make a battery forward mount And take the body off and on to change batteries Last edited by kgb424; 05-25-2016 at 10:55 PM. |
05-26-2016, 08:05 PM | #48 |
Is it possible to mount the lights on or in the bumper/stinger?
05-26-2016, 09:23 PM | #49 |
No the four lights will not fit on bumper/stinger 2 of the headlights mount where they are supposed too Then the other 2 lights mount in between the bars Thats why I added the mesh for the lights So they would not be in the body And hid behind the screen |
05-26-2016, 09:46 PM | #50 |
I misunderstood, I see what you did now, mounted the lights to the frame inside, behind the grill. You're just looking for something to put on the outside, to look like a light. How about Shoo-Goo-ing some clear lenses (part # AX80086) to the outside of the grill, in front of where the lights are mounted behind the grill? |
05-26-2016, 10:06 PM | #51 |
I see what your saying Mike I was talking about the body Where the corner of the body and where the grill starts There really is not alot of room Thats what I meant it looked like it was missing something I looked thru some of my Axial sticker sheets And there is not alot of sticker options that small And nothing really looks right I think once I cut the grill so the body drops over the metal bumper/stinger And glue on the 4wd emblem on the grill It is what is If you look at the pictures I had to lose the headlight stickers Cause there was not enough left to look right Last edited by kgb424; 05-26-2016 at 10:11 PM. |
05-27-2016, 07:59 PM | #52 |
Now I see. Do you have any leftover stickers from other builds?, or maybe a piece of reflective tape, that can be cut up. Bicycle shops usually sell thin stick-on reflector strips in amber or red for under a buck.
05-27-2016, 08:16 PM | #53 |
The only stickers I found on the sheets was the Axial symbols or more brand stickers like on the quarter panels and nothing looks right I need to look for a scale hood ornament or some bull horns or something cool Last edited by kgb424; 05-27-2016 at 08:18 PM. |
05-29-2016, 08:33 PM | #54 |
I really like how the Wraith is Coming along I made a bed cover and roof piece out the screen mesh And I had to make a second grill cause the lights stick out passed the frame I was able to fix it and looks good I also got the Hutchinson bead locks painted They look good with black hardware Not sure if the paint is going to stick and not scratch off I used a Scotch bright pad and some etching primer And then the top coat of Deep Forest Green Then I shot some flat clear of the top coat The rims look good and are a lighter shade Of the same color as the frame I could paint up the RPG And attach to mesh wall behind the seats It would look bad ass Last edited by kgb424; 05-29-2016 at 08:37 PM. |
05-29-2016, 08:43 PM | #55 |
I ordered a 100 2 mm x 8 mm socket cap screws for the Hutchinson beadlocks and a set of 1.9'' Voodoo KLR's With C.I. Wild Deuce single stage foams Cause the KLR's work with the Hutchinson's And should be easier to mount than Pro-line TSL XL Swampers Pro-lines don't work with a lot of rims and the Hutchinson's are one The RC4WD inner rings for Prolines work with RC4WD and some other beadlocks There just not made specificity for the Hutchinson's When I tried to mount Prolines on the Hutchinsons using the RC4WD inner rings I just could not get the bead evenly and made the tire wobble cause of the high and low spots Cause even with the special inner rings I had to fight them and the wobble was bad enough to not want to run them I hoping the KLR's are easier Last edited by kgb424; 05-30-2016 at 11:53 AM. |
05-30-2016, 11:46 AM | #56 |
That mesh makes a nice bed, good place for the rocket launcher |
06-02-2016, 08:28 PM | #57 |
I got my C.I. Foams and the 8 mm screws The Voodoo KLR's should be here Saturday I also bought a roll of this 4'' x 25 ft 1/8'' Mesh got an idea in my head Going to check it out |
06-06-2016, 01:12 AM | #58 |
I got my 1.9'' Voodoo KLR's The wheel and tire combo is Damn Sexy and were easy to mount a 1000 times easier to mount Then the XL Swampers They need ventilated I'm going to buy a leather punch I also got my Traxxas Battery hold down posts with clips Going to use them as body mounts And Shoe Goo and Drywall tape The body post holes Last edited by kgb424; 06-06-2016 at 01:36 AM. |
06-06-2016, 01:22 AM | #59 |
I ordered a second Wraith battery tray And put one in the rear with some mesh Going to mount the ESC on the stock holder velcro-ed to the mesh it should look good with the bed mesh over the tray I then took the second Wraith battery tray and used my Dremel to trim it And shaved the radio box a little too be able Too make a battery forward mount and be able too squeeze in a big 2S Lipo Going to look for a couple smaller 3S Lipos that fit better I also made a bottom bracket to help hold the battery tray Last edited by kgb424; 06-06-2016 at 01:37 AM. |
06-06-2016, 04:31 PM | #60 |
I also got a second Wraith skid plate That I might split into 2 pieces for the links on the Jeep Mutt still need to figure a chassis or something |
My 6th Scale M151A2 Jeep Mutt - Similar Threads | ||||
Mutt - ClassiCutCustoms | Dreufic | Videos! | 6 | 03-11-2015 04:55 PM |
the mutt | lifted_xj | Axial AX-10 Scorpion | 6 | 01-03-2011 01:51 PM |
my mutt! | krono7s | General Crawlers | 5 | 10-06-2010 06:22 PM |
The 1/6 MUTT | Flying Dutchman | Large Scale Rigs | 24 | 05-10-2010 02:35 PM |
