05-28-2016, 04:01 PM | #1 |
Rock Stacker Join Date: Sep 2015 Location: Kansas
| My 1:8 Scale Ford Raptor
So, I've been seeing all these people building large scale rigs from old newbright bodies and recently came across one at a garage sale. I figured I could scrounge up 30.00. It will be a slow build as I currently have no parts for it at all. I'd like to use a wraith or yeti but don't have the cash for even a roller on one of those. So, like I say, it'll be a slow build. I was able to get some .750 in tubing and bend it today. I think it'll work well. I'll post as I get parts and continue the build.... Sent from my iPhone using Tapatalk |
05-28-2016, 05:36 PM | #2 |
| Re: My 1:8 Scale Ford Raptor
So I'm wondering.... Should I cut the .5 tube in half for c-channel, or just do 2 tubes? Sent from my iPhone using Tapatalk |
05-28-2016, 06:34 PM | #3 |
Rock Crawler Join Date: Mar 2015 Location: "Crawling Heaven"
| Re: My 1:8 Scale Ford Raptor |
05-28-2016, 06:40 PM | #4 |
05-28-2016, 07:28 PM | #5 |
05-29-2016, 02:39 PM | #6 |
Rock Crawler Join Date: Aug 2011 Location: south shore Ma
C channel looks scale and is easier to make. Make sure to drill all the holes you need before you cut it. That way you know eveything lines up right. Sent from my ALCATEL ONE TOUCH Fierce using Tapatalk |
06-07-2016, 09:59 PM | #7 |
Ok, got the rails done. Decided to go c-channel. I think they came out pretty good. I like how it's looking so far. Time to start measuring things out for links and what not. Sent from my iPhone using Tapatalk |
06-09-2016, 08:17 AM | #8 |
I got the rails welded in place and ready to start with the skid, links, mounts and so on. It's feeling pretty solid so far. I hope it all turns out good. Sent from my iPhone using Tapatalk |
06-15-2016, 09:16 PM | #9 |
Its looking good so far! Keep the updates coming Sent from my ALCATEL ONE TOUCH Fierce using Tapatalk |
06-18-2016, 08:36 AM | #10 |
Well, I remade the rails because I wasn't happy with the front arch. It would have worked, but it look quite right to me.i have also dropped in a wraith skid plate and am now starting to work on the links. I haven't made links like this before, but when I saw the 1/4 alum rod at the hardware store, it looked like the right thing to do. Biggest pain is drilling and tapping the ends since I don't have a press/mill/lathe. It's all being done with a hand drill..... Sent from my iPhone using Tapatalk |
06-19-2016, 10:04 AM | #11 |
Got a little further last night and this morning. Now that I figured out how I'm making my links, I need my drive shafts to show up to start tying things together. The front upper links will be aluminum as well, as was just test fitting with some old plastic scx10 links. Sent from my iPhone using Tapatalk |
06-19-2016, 10:07 AM | #12 |
So, is this going to be more ultra4 or desert ish? 1.9 Ibex tuber |
06-19-2016, 12:50 PM | #13 |
| Re: My 1:8 Scale Ford Raptor I quite honestly don't even have a plan..... I'm just building as I go and trying different things along the way that I think will work. It's like a fun experiment. I really hope it turn out well though. I really hope I like the end result.
06-19-2016, 12:52 PM | #14 | |
| Re: My 1:8 Scale Ford Raptor Quote:
Right on, looks good! 1.9 Ibex tuber | |
06-19-2016, 03:11 PM | #15 |
Ok, super quick update. Last one for the day. Initial shock placement. I know the tires still look small.... I had a few friends offer up some different tires, but all were too big. Until next update! Sent from my iPhone using Tapatalk |
06-20-2016, 05:50 PM | #16 |
| Re: My 1:8 Scale Ford Raptor Sent from my iPhone using Tapatalk |
06-24-2016, 11:11 PM | #17 |
Looks good!! 1.9 Ibex tuber |
06-25-2016, 07:13 AM | #18 |
Threw the tires from my SCX10 II on and they look way better than anything else I have. I also found some steel driveshafts on eBay that fit the truck as well. Sent from my iPhone using Tapatalk |
06-28-2016, 01:43 PM | #19 |
Rock Stacker Join Date: Nov 2014 Location: On the internet, confused.
The new tires look way better! I found that around a 4.6 inch tall tire fits the wheel wells perfectly. |
07-18-2016, 09:56 PM | #20 |
Pebble Pounder Join Date: Dec 2014 Location: Oshawa
My Raptor was very simple to build. It works well. |
My 1:8 Scale Ford Raptor - Similar Threads | ||||
Proline True Scale Ford Raptor SVT F150 | Xporter | Non Crawler RC's | 1 | 02-14-2016 04:20 PM |
cc-01 Ford Raptor | canadian scx10 | Tamiya XC/CC01 | 8 | 03-17-2013 07:07 PM |
2.2 1:8 scale Ford Raptor | tommckay | 2.2 Scale Rigs | 15 | 01-23-2013 05:48 PM |
True Scale Ford F-150 Raptor SVT Clear Body | sb4pro | Axial SCX-10 | 10 | 11-25-2012 11:58 AM |
