08-15-2016, 09:01 PM | #41 |
I wanna be Dave Join Date: Mar 2013 Location: Minden
| Re: Just pulled the trigger on a Dragon
I'm going to call and check on my Jeep order I got RC4WD first generation Toyota axles with springs on a the GCM 4Ten chassis and willing to adapt it to the Dragon Jeep I got SCX10 axles and figured out away to mount leaf springs to the axles or I could four link them And I got a set of AR60 axles off my 2nd Wraith and could four link them Just need the Jeep to figure out my chassis setup and which axles I want to use I'm leaning towards 1.9'' wheels and tires I have to built a chassis or sub frame for the 1/6 scale Jeep Mutt and use a transfer case Doing the Dragon first might help me figure out the Jeep Mutt They both need chassis's and use transfer cases Last edited by kgb424; 08-15-2016 at 09:13 PM. |
08-15-2016, 09:15 PM | #42 |
Quarry Creeper Join Date: Aug 2013 Location: Graham, Washington
Mine showed up today! |
08-15-2016, 10:45 PM | #43 |
The waiting is really starting to suck now and starting to piss me off That people that have been waiting as long as me are getting their Jeeps And there not even returning my e-mails now and they are still taking pre-orders I could be waiting even longer and if I ask for a refund, I would have to wait for my refund and have to re-order some where else and wait again So Lucky you got yours But dam it your pictures did not post again I'm waiting to smell the box when I open mine WTF Bitter End now there is even more Of your pictures missing in you build now I looked to see if you posted your new Dragon And there is minus signs every where There is something XXXXXXX wrong with your camera or phone Cause if I mine are too big, it says in a window it will not post Mine have never done the minus sign So I have no idea what's going on with your pics The minus sign never happened to me The just don't post Your's act like there posting, Right ?? but your getting the minus sign Last edited by kgb424; 08-15-2016 at 11:16 PM. |
08-16-2016, 03:15 AM | #44 |
I can't sleep so I did some looking on line And I found this G-made Sawback replacement chassis that has a 11.3'' wheelbase I could stretch the chassis rails in the middle or shorten them in the middle Cause I'm going to be using a transfer case and I could modify the stock skid plate/motor/transmission mount It uses leaf springs not sure if there the same as the Tamiya leaf springs, or if their the same length or if the arc's are the same as the Tamiya springs The Sawback chassis is closer to a Jeep body then the Bruiser chassis is Plus the Sawback chassis's are available and a lot cheaper And I also found this Chassis steering servo mount, they make a couple different ones Not sure if it would work cause I want to use a motor forward plate Going to check out before I pull the trigger on a chassis Last edited by kgb424; 08-16-2016 at 03:30 AM. |
08-16-2016, 03:44 AM | #45 |
Does anybody know what the wheel base of a 1/6 Dragon Jeep is I'm talking about center of rear wheel well to center of the front fender Can some one please tell the wheel base of a 1/6 scale Dragon Jeep Cause I don't know how much longer I have got to wait for my Jeep I could already have the frame ordered and delivered and mods started By the time the Jeep is here I think I can stretch the wheel base from 11.3'' to what I need to get the right wheel base Last edited by kgb424; 08-16-2016 at 03:48 AM. |
08-16-2016, 07:20 PM | #46 |
Yeah baby Plastic-Models-Kits.com is now OakrigdeHobbies.com They changed their website and business It took a little while but They got my question and sent me a e-mail Saying the Ordering Manager called to check the status They should have them by the end of this week And my order will ship as soon as possible Cause I was going to call and check on my order Until they sent me a e-mail today Yeah baby I will be smelling the box soon For that new plastic Jeep smell Yeah Baby Last edited by kgb424; 08-16-2016 at 07:27 PM. |
08-17-2016, 01:11 PM | #47 |
I found this picture of the pedestal with the support legs and lock bar for the 50. Cal
08-17-2016, 06:52 PM | #48 | |
Newbie Join Date: Aug 2012 Location: Vancouver
| Re: Just pulled the trigger on a Dragon Quote:
I have a factory-built 1/16 Dragon Desert Raider; the base kit is the same for all the Dragon Jeep variants as far as I know. Have been saving it for some future build. The wheel base center front axle to center rear axle is 13 5/16 inches. Track front with stock tires and wheels is 8 3/8 inches, rear 8 1/2 inches. My Dragon ETO build which I posted hear a couple of years ago had the same dimensions before I modified it. Good Luck, Mati | |
08-17-2016, 07:32 PM | #49 |
Thank you MatiR So 13 5/16, is close to a Wraith wheel base, depending on the which rod ends you use Cause at one time my Wraith had 13 1/2 wheel base, I used the same links but changed out the rod ends and it shorted the wheelbase Can you tell what axles are you using, and are they four linked or are you using leaf springs I will have to try the SCX10 and AR60 and the RC4WD Toyota axles To see their widths with my 1.9'' Hutchinson beadlocks and my 1.9'' Voodoo KLR That I'm going to use Last edited by kgb424; 08-17-2016 at 07:38 PM. |
08-17-2016, 08:16 PM | #50 |
Hi Kgb424: Here is a link to my old thread which has the information about axles, etc. Dragon 1/4 Ton 4x4 Truck ETO 1944 MatiR |
08-17-2016, 08:42 PM | #51 |
MatiR You are using a version of the OG Tamiya axles that are four linked, with a chassis mounted servo I have a set of RC4WD first generation Toyota axles with the Tamiya leaf springs And was hoping my Toyota axles are the same width as yours Cause I want to make a spring setup or four link and use SCX10 or Ar60's axles Last edited by kgb424; 08-17-2016 at 08:46 PM. |
08-17-2016, 09:50 PM | #52 |
Hi Kgb424: I used the RC Channel TAMIYA F-350. Toyota Hilux Wide Metal Axle kit - with hex to hex width of 210 mm A.TAMIYA F-350. Toyota Hilux Wide Metal Axle kit, Rc Channel - The Worlds of Rc Car Parts |
08-17-2016, 10:37 PM | #53 |
There nice axles but not spending $230 to $250 on axles 210 MM is about 8 1/4'' wide So when I get my Dragon I will mock it up with the different axles and beadlocks To see which combo puts the wheel in the fender wells And not too close to chassis or stick passed the wheel wells I think it comes down to personnel preference on which axles people use Cause I have seen 1/6TH scale Jeep builds with AR60's and SCX10's axles and Second generation Toyota axles And what ever axles they decided to use Need to check it out What kinda of glue due you use for the body and kit assembly Last edited by kgb424; 08-17-2016 at 10:44 PM. |
08-18-2016, 09:43 AM | #54 |
| Re: Just pulled the trigger on a Dragon Hi Kgb424: I used Tamiya Extra Thin cement https://www.tamiyausa.com/items/pain...n-cement-87038 for most parts and Tamiya regular thicker liquid for large areas. These have always worked well for me, especially the extra thin as you can apply it with a fine brush (included in the cap) and just let it wick in between parts by capillary action giving very neat and clean joints. In addition, bonding is almost instantaneous but, of course, full strength needs some extra time. However, as the kit material is just regular styrene plastic used in normal model kits (not Lexan like the usual RC bodies) , any manufacturer's plastic glue will work. M. |
08-18-2016, 10:41 AM | #55 |
I have some Plastruct Bondene and not impressed with it I also have some Tenax 7 it works better but still not the best The only glue I found that work great every time is Super Glue I also found lightly sanding both pieces before bonding Make a stronger joint The extra thin Tamiya cement Is like Insta-Cure Cyanoacrylate or super glue correct ?? I will have to look at a Hobby Shop Last edited by kgb424; 08-18-2016 at 10:48 AM. |
08-18-2016, 11:02 AM | #56 |
Tamiya extra thin cement is a typical solvent cement which bonds by essentially melting one piece to another. Super glue is cyanoacrylate based but do not use it to bond plastic in general. It is, however, useful for attaching small bits, especially not plastic, here and there. Plastruct cement is also solvent and should work but now that you mention it, I seem to recall years ago trying it and not being satisfied. I think that the Plastruct line of plastic shapes and sheets are slightly differ from typical styrene and perhaps the formula is geared toward them - not sure about that though. I have never been let down by the Tamiya extra thin and regular consistency cements. |
08-18-2016, 01:53 PM | #57 |
I bought 2 of these Tamiya Extra Thin Cements I want try it on some of part trees from the kit And see how it bonds and see how long the set up time is Before I start the gluing the Jeep kit together Last edited by kgb424; 08-18-2016 at 01:59 PM. |
08-18-2016, 04:23 PM | #58 |
**** with me I cancel your order Monday I got e-mail saying that they would not receive them until the end of this week Now today I get a e-mail saying they got limited number and there already shipped out and I not getting one right now I will have to wait until they get more **** em and **** that I canceled my order and I used Pay Pal so I should be good If they try to screw out of my refund I got there Ass **** em in the neck Last edited by kgb424; 08-18-2016 at 04:29 PM. |
08-18-2016, 04:32 PM | #59 |
I called Cotsworld and got one of the 3 they had left It cost me a little more But I got one and it should ship tomorrow Just waiting for the e-mail with tracking I should of went with them from the beginning Live and ****ing learn I going to get a refund and a Jeep Goosfraba I'm good now And avoided the anger sharks swimming in head Last edited by kgb424; 08-18-2016 at 04:38 PM. |
08-18-2016, 07:24 PM | #60 |
Pebble Pounder Join Date: Oct 2014 Location: Santa Barbara
Just got a tracking number from OAKRIDGE HOBBIES. Mine is on the way and should have it on the 24th. I know I ordered it a few weeks before you did. Sent from my 831C using Tapatalk |
Just pulled the trigger on a Dragon - Similar Threads | ||||
Just pulled the trigger on a CC-01 | abailey21 | Tamiya XC/CC01 | 35 | 10-28-2012 09:43 PM |
Pulled the trigger | XJkid93 | Axial XR10 | 2 | 04-19-2012 03:30 AM |
pulled the trigger.. | 94smasher | Axial SCX-10 | 6 | 03-17-2012 03:59 PM |
pulled the trigger | 501 | Team Losi Comp Crawler | 14 | 12-27-2010 12:03 PM |
Pulled the trigger | smokediver | Axial AX-10 Scorpion | 18 | 03-07-2010 03:07 AM |
