09-12-2016, 06:21 PM | #101 |
I joined the Band! Join Date: May 2006 Location: Between a rock and a hard spot!
| Re: Just pulled the trigger on a Dragon
I will stick with my 100 dollar Harbor freight bench top bandsaw and T6 Aluminum to make my chassis. |
09-12-2016, 07:20 PM | #102 |
I wanna be Dave Join Date: Mar 2013 Location: Minden
Good luck with that Cause I made my chassis rails match the Dragon Chassis profile I made cardboard templates, one of each side for my lay out And there are a few raduis that you can not be, cut out on a band saw That's why, it would take me forever, to write the correct program for CNC Plasma cutter and still not sure, if the machine likes to do radius, I know the CNC Mill, will not do radius Cause of the raduis, and its a completely different software and programming from the CNC Mill, that I learned the basic's on and the G codes and M codes are different and do different things They were cut out, with a Plasma cutter freehand, cause I could not, do it on a band saw, the college sold the dinasour band saw they had And because of the radius's a band saw will not work, and my jigsaw is a pain in the ass cause, it has to be forced to cut the metal, and there no way it will cut a tight raduis either I thought about a scroll saw, cause my nieghbor has one, but they don't make metal blades, cause there not made to cut metal, let alone cut a radius in metal And this is with 1/8'' steel plate, any thing thicker is not going to happen either And it did not cost me anything except for 1/8'' plate and the die grinder and the Carbide bit The instructor tried to give me the plate, But I had already bought it before I went to college and asked for help The Welding Instructor, is one that suggested, I buy the Die Grinder and buy a quaility Carbide wrasp tip Like I said there not pretty, but there better, than cut out on my jigsaw Last edited by kgb424; 09-12-2016 at 07:51 PM. |
09-12-2016, 08:07 PM | #103 |
I just looked at Harbor Frieght, they have a 9'' and 14'' bandsaw They don't mention cutting metal with the bandsaws, but they do sell bimetal blades They have a band saw in Welding shop, but its for cutting big stock, and not made to make freehand cuts like Like the band saw I used in woodshop back in high school, you could make a bunch of different cuts with out problems but not in metal, it only makes straight cuts So the Plasma cutter was the easiest way to cut out my rails Last edited by kgb424; 09-12-2016 at 08:12 PM. |
09-12-2016, 08:47 PM | #104 |
Depending on the thickness of the metal, they will cut, but have to have a 24 or 28 tooth/inch blade, and if you prepare ahead of time you can cut out a set of frame rails, just need to drill some holes bigger than the width of the blade, so when you get to them, you have room to turn within the hole, to make your next straight cut.
09-12-2016, 09:16 PM | #105 |
I do not think you can cut a raduis no matter how many holes you drill it, Cause the 9'' and the 14'' bandsaw don't have much power, that's ok if working with wood but with metal, your forcing the blade, to make circular cuts, and if you, use too much pressure it binds and not enough pressure, it takes forever to cut I looked at 3/16'' aluminuim material and it was too exspensive to screw up, and too hard to clean up with out buying more tools and it had to be ordered, the steel is available in stock at a few places locally to me The 1/8' plate for 4 Jeep rails was $13.76, the 1/8'' plate for the 1/6 scale Humvee was $20.00 cause I made the rails twice The second set had rear shock loops and a better design and did them with a jigsaw and it took forever to them clean up and sqaure up and make matching The plasma cut rails, need cleaned up also, but nothing like the Humvee rails needed I got a die grinder and Carbide bit, should be easier than a 4'' grinder and hand files I tried to make the top of my chassis rails to match the top of Dragron chassis rails So the Dragon Jeep body fits right, not sure, if that going to happen once, the rails are cleaned up and made even Cause the rails for the Jeep Mutt are not as critial and the Dragon Jeep rails are I'm going to start cleaning the rail up maybe tommorrow, just been feeling shitty lately and not sleeping good or at all so its hard to stay focused on my attenion right now I'm taking the Welding Instructor word, that they can't be cut on a band saw He know what he is talking about. Spent most of his life doing custom fabricated and welding So I take him at his word Last edited by kgb424; 09-12-2016 at 11:22 PM. |
09-12-2016, 11:32 PM | #106 |
Since I did not pay to take the Welding class, but did buy my own material, I have limited access to the equipment Plus I have never used a plasma cutter, its been years. since I have used a cutting torch, it would be way too hot for 1/8'' plate So the Instructor had the TA cut the rails, cause not everybody gets too use the plamsa cutter at first I'm thinking about taking the practice class, so I can use the equipment and run some beads with the wire feed welders and not have to take the specific wire feed welding class And not be able to use the other equipment, cause you are suposed to be welding and practicing your beads and doing simple welding projects If you take the practice class there is no projects,no grades and you can use the equipment I only have the 2 1/6 scale frames to finish So I'm not sure, if I want to take the class Last edited by kgb424; 09-12-2016 at 11:44 PM. |
09-13-2016, 12:07 PM | #107 |
Quarry Creeper Join Date: Jan 2013 Location: Athens
It is going to be a heavy Jeep in the end. Im using 5mm steel chassis rails and the willys with the dragon body weighs at 14,7 pounds 6.7 kg. Reason I used the 5mm steel plate was I needed 3mm holes with thread on the chasis rails to mount the body exactly the same way as the original dragon chassis. Not that it cant be mounted with other ways like angle plate etc.. As for the grinder you have I just think you will need a bigger conventional grinder the ones that use a disk. By the way I like your builds. |
09-13-2016, 08:24 PM | #108 |
The instructor suggested the Die Grinder He also suggested I buy one of those 360 grit wheel for my 4'' grinder I'm going to Home Deopt and look, I got 4'' grinding wheels But not the thin flexable sanding disk I'm glad at least one person on here likes my builds Ok maybe 2 or 3 but not 4 that's pushing it |
09-13-2016, 09:34 PM | #109 |
I bought 2 of these 4 1/2'' Flap disks in 36 and 60 grit for $10 at Wally World Home Depot has the 4 1/2'' thin flexable sanding disks, in different grits But you need the rubber backing pad, for the sanding disks to work, I didn't want to spend the money Cause the Flap disks drops on the spindle like a grinding disk , no pad needed I know Home Depot has the disks and the pad if needed I'm going use the die grinder and flap disks and see how they work And get the rails cleaned up and squared up and even Last edited by kgb424; 09-13-2016 at 09:40 PM. |
09-13-2016, 11:20 PM | #110 |
| Re: Just pulled the trigger on a Dragon |
09-14-2016, 12:51 AM | #111 |
I also want to make some motor forward plates similiar to the one in the picture But instead of aluminium that is drilled and tapped, cause I don't have a drill press to do it right, I'm going to use some of my scrap 1/8'' plate And use the plate I got, as a template to make the the holes for the transmission and motor and slots for the gear mesh, and drill lighting holes and cut some areas out And make some tabs, then bend the tabs, so I can bolt the bottom of the motorplate to the chassis, cause if I tack it, I won't be able too take it part then need to figure how to mount the top or middle of the motor plate, and the shocks and need to make shock loops or mounts And weld the shock loops or mounts to the chassis rails but be able to tie the shocks and chassis and motor plate together but still be able to take it apart Its not all figured out, but I'm going in the right direction Last edited by kgb424; 09-14-2016 at 02:03 AM. |
09-15-2016, 03:04 AM | #112 |
Look what I found in my parts stash I got my stock Wraith c-hubs and knuckles and lock outs Not paying $45 to $50 axle, for tubes or $100 for 2 axles looking for cheaper tubes to widen my SCX10 axles I also found my SCX10 transmission halves And some old output shafts, that don't have holes for the pins |
09-16-2016, 01:01 AM | #113 |
Any body here, know how to make your own long or wide Axle tubes Cause I want to do the XR mod, but not paying $45 to $50 dollars per axle I can go up the college and ask, if I can use the lathe and use a mill as drill press I'm thinking with the right size end mill, I can cut the bearing races at the end of tubes They just won't be splined like the ones you can buy Need to look online and see if I can find some dimensions And look for material |
09-16-2016, 09:56 PM | #114 |
Yeah Baby Looky what I got for free, no bullshit, there are still some decent people out there in the World When I was at Home Depot, there was Vender there from Dewalt in the tool area And I got to bullshitting with the Vendor about why I wanted a 3mm tap and the correct bit Too put some 3mm screws in the axle tubes too secure them They don't carry just a 3mm tap and bit, but they carry the 4 mm tap and bit So he handed me this 17 piece Metric Tap and Die Kit, right off the rack And said take it, cause they didn't care the tap and bit, I needed and the Kits are $30 I scored, just happened to be at the right place at the right time And can bullshit my ass off Love free stuff Yeah Baby Last edited by kgb424; 09-16-2016 at 09:59 PM. |
09-16-2016, 10:11 PM | #115 |
Yeah baby I figured out my own version of an XR Mod And I going to use 1/8'' pipe for my axle tubes I found some pipe fittings, the 3/8 nut acts like a lock rings too keep the axle housing closed tightly together And the other fitting screws on the 1/8'' pipe on one end then the C-hubs and rear lockouts thread on the the fitting on the other side The axles are now 10'' wide thread to thread and 11'' wide with wheels and tires Going to drill and tap screws to secure the axle tubes and C-hubs and lockouts Last edited by kgb424; 09-16-2016 at 10:33 PM. |
09-16-2016, 10:25 PM | #116 |
I needed wider axles for the Jeep Mutt, cause Stock SCX10 are not wide enough They might be too wide for the Dragon Jeep, need to check the axle widths once the chassis are fourlinked Going to do one set of axles for now, and then the second set maybe I'm still looking for front and rear axles, It might be cheaper to buy Wraith axles and cut them to length And use the front stock dog bone and coupler, and not buy the universal front shafts Which are too exspensive too me, when the dog bone and cup Works fine until they break And cut the one fitting so the dog bone has a bearing like the AR60's due before the c-hubs go on There is still alot work to do, but I got axles figured out Now I need to figure out the axles Last edited by kgb424; 09-16-2016 at 10:44 PM. |
09-19-2016, 02:23 AM | #117 |
Yeah Baby I got one set axles almost done, I need to cut off a little from the front axle, on each side for the bearing, the front Universal rides in at the end of axle and c-hub Need to make new steering linkages, cause I put the steering linkage from my Wraith, and used shorter rod ends, the link needs to be shortened or shorter rods to center the axle shafts, right now there cocked and not straight So I'm thinking a simple curved link, with out the extra bends would work and a short link from the servo to the steering knuckle Made out of allthread and brake line or maybe a cheap one off the net, I might find something, will look Need more 3mm X 6mm button head screws to start the other set of axles and secure the axle tubes Will need the longer Wraith axles and universals Unless some one, is kind enough to loan me a set of XR rear axles and front universal For mock up purposes only and will return them unused Just want to check the axle lenght Cause the Wraith long axle is 160 mm long, they will need cut down Just want check my options before pulling the trigger on axles Last edited by kgb424; 09-19-2016 at 02:54 AM. |
09-20-2016, 01:55 AM | #118 |
Wow Who knew that Home Depot online,sold packs of 25 stainless steel button head screws that are 3 mm-0.5 X 8 MM for $7.50 with free shipping, cause its being shipped to the store 5 miles from my house I have been buying my metric hardware locally at Ace Hardware and Home Dept and Lowe's, you have to buy it by the piece, its great if you need small amounts, and Ace carry's a lot of cool shit For bulk, I buy from MC Masters-Carr and now Home Depot online 8 mm is way to long, I have been trying to keep the screws short enough, so that the screws come thru the axle tubes a tiny bit, and the axles won't hit them So I will have to cut them down and 25 is perfect amount cause there is 12 screws per axle I don't mind the extra work of cutting the screws down Its makes the axles custom Last edited by kgb424; 09-20-2016 at 02:05 AM. |
09-22-2016, 06:14 PM | #119 |
I screwed up 1 rear axle housing, cause I cut the flange down that SCX10 locks outs secure too and trimmed out the bearing race for the tubes , thinking I was going to make 2 sets of XR modded axles I got too screwing around and its looks like for Dragon Jeep the XR modded axles, would be too wide and wheels would stick out too far and only a little of the tire Would actually be in the wheel well, I can always try wheel wideners or different wheels with a different offset , if the stock SCX10 axles are not wide enough I going to make some normal length SCX10 axle tubes, that fit between the bearing race and the differential Not the the XR lenght ones that extend passed the housing, like the XR modded axles, I made do Going too put tubes in all 3 sets of axles, just waiting on the 3 mm screws, I ordered The waiting sucks Guess I could start cleaning up the chassis rails Last edited by kgb424; 09-22-2016 at 06:23 PM. |
09-25-2016, 05:36 PM | #120 |
Yeah Baby I figured it out, how to fix my Honcho with AR60 axles, the upper links were binding on the driveshafts,which where MIPS for a 12.3'' wheelbase Honcho I used Axial Wild Bore drive shafts instead and was thinking about making or buying Link Risers, then I came up with this I don't need no stinking, Link Risers, I made 2 rods, using a 1/8'' rod and 3 mm die and cut my own threads Then pushed the 1/8'' rod thru some small 3 mm links, that were drilled with a 1/8'' drill bit, were filed with a small round needle file, so they slide freely onto the 1/8'' rod And slide my spacers and drilled ball ends in place and tightened the nuts on the threaded rod and tightened the skid plate, the frame had to be spread open to get my upper link mounts in place I like how it came out, cause now the driveshafts spin freely and no longer bind, and it was simple fix, once I figured out a plan Like the angle of front and rear axle, there clocked a little and the shafts are behind the links so the should be alright Just had to be smarter than your average Dumb-ass, and wait for it Last edited by kgb424; 09-25-2016 at 05:54 PM. |
Just pulled the trigger on a Dragon - Similar Threads | ||||
Just pulled the trigger on a CC-01 | abailey21 | Tamiya XC/CC01 | 35 | 10-28-2012 09:43 PM |
Pulled the trigger | XJkid93 | Axial XR10 | 2 | 04-19-2012 03:30 AM |
pulled the trigger.. | 94smasher | Axial SCX-10 | 6 | 03-17-2012 03:59 PM |
pulled the trigger | 501 | Team Losi Comp Crawler | 14 | 12-27-2010 12:03 PM |
Pulled the trigger | smokediver | Axial AX-10 Scorpion | 18 | 03-07-2010 03:07 AM |
