09-27-2016, 05:24 PM | #121 |
I wanna be Dave Join Date: Mar 2013 Location: Minden
| Re: Just pulled the trigger on a Dragon
I got one rear axle done and waiting for the axle housing to make the other rear axle, I got the tubes cut and ready to go I also got my front tubes cut and there long enoug so the bearing is at the end of the axle shaft and C-hub Still need to cut the front axle on the XR ones so there is a bearing at the end of the axle and c-hub Going too take my time or go up too the college and use the mill as a drill press and drill my tubes The holes needed for the c-hubs are no problem, it is the other holes that are closer to the differential That are a pain in the ass and walk on you, I'm using my cordless drill, a mill or drill press Would drill straight and clean holes and then I tap the one holes and finish the axles Last edited by kgb424; 09-27-2016 at 06:02 PM. |
09-29-2016, 04:25 PM | #122 |
That's it for me a few days I punctured my finger with a brand new out of the package, high speed hard metal bit in my finger Trying to drill the axle tubes was in Get Er Done mode and was rocking some tunes And stabbed my finger good, left bleed to clean its self out, put on a band aide and soldiered on And it swelled up over night went Urgent Care, they drained my finger, and it feels much better now and got some Antibiotics Bleeding and hurt, I finished the axle I was working on I got the 2 rear axles done and one front axle done The fronts axles are a pain in the ass It took me a little while to figure out to after I drilled one and tapped it, that it blew the holes out at the end of the axle tube for the screws for the C-hubs I used the bearing as a template to mark the axle tube and then move that distance back and close the the line, I drilled a 7/64'' pilot hole and tapped them with the 3 mm tap And when done right, there still is meat at the end of the tube and the screws secure the C-hubs and the and dog bones, go in far enough with no binding It took me awhile to figure that one of the Dog Bones was binding up the knuckles, I shaved the end of the tube and that was enough for the Dog Bone to go in far enough in the end of the axle and tube and C-hub, I fixed the binding problem, Got one more front axle to do, there a pain in the ass, I got it figured out now And still looking for reasonable priced axle shafts and universals For the XR Modded axles, going to wait until I got universals before I cut them for the bearing and the end of the axles and where the c-hubs hold the bearing in Last edited by kgb424; 09-29-2016 at 04:49 PM. |
10-02-2016, 10:12 AM | #123 |
Yeah Baby I finally fixed my Wraith AR60 axles, I've had a problem with the C-Hubs and rear lockouts coming loose Even after they were lock tided and new holes they would not work or stay tight I fixed them by cutting up the scrap pieces of 1/8'' pipe nipples, that I used for my SCX10 axles And made the pieces 3/4'' long, so the C-hubs and lock outs are now tight And will not fall out, cause they thread into the mini axle tubes I should of done this as, I was building my Wraith kits Cause the design of screwing into plastic, to lock the c-hubs and lockouts Is not going to work, and had problems from day one 3/4'' is long enough for one screw to secure the mini tubes And not have to drill and cut slots in the tubes for the shock and lower link mounts Cause I looked online at Wraith axle tubes, they all have a slot cut in the for shock and link mount screws And not sure, if I could duplicated the slots in 8 pieces, so I came up with something else, is stead of cutting slots As you can see, I missed the end of the mini axle tube, on one of the axles and you can see, the mini tubes stop short of shock and link mounts I will patch hole in the axle and there good to go, they were cleaned and re-greased, and like new Got 2 sets of AR60 axles, one set has universals, the other set has dog bones and axle shafts, so my mod works with both front axle setups Yeah Baby I'm like Wiley Coyote, Super Genius Last edited by kgb424; 10-02-2016 at 10:42 AM. |
10-07-2016, 06:50 PM | #124 |
I found enough screws and finished the last SCX10 axle I did 2 sets of normal SCX10 axles and one set of XR Modded axles Need to buy some axles for the XR axles I thinking of buying the Wraith long sides and cut the to fit I fixed both sets of AR60 axles, now the C-hubs and lockouts are tight Last edited by kgb424; 10-07-2016 at 06:55 PM. |
Just pulled the trigger on a Dragon - Similar Threads | ||||
Just pulled the trigger on a CC-01 | abailey21 | Tamiya XC/CC01 | 35 | 10-28-2012 09:43 PM |
Pulled the trigger | XJkid93 | Axial XR10 | 2 | 04-19-2012 03:30 AM |
pulled the trigger.. | 94smasher | Axial SCX-10 | 6 | 03-17-2012 03:59 PM |
pulled the trigger | 501 | Team Losi Comp Crawler | 14 | 12-27-2010 12:03 PM |
Pulled the trigger | smokediver | Axial AX-10 Scorpion | 18 | 03-07-2010 03:07 AM |
