01-11-2017, 08:07 PM | #181 |
I wanna be Dave Join Date: Mar 2013 Location: Minden
| Re: It just got real
I went out in the shop and both of the big roll up doors are leaking too The big shop doors are 12 and half feet wide and are the small panels I called the company that built the shop and left a message So I hope they can give me information about the doors Cause I can't find a manufactures tag or any stickers When they deliver the track fro my garage, I will ask about the shop doors If I'm lucky I only have to replace the seal, cause the seal is in the center of the bottom of the door It should not be that expensive, now that I know, I can buy it locally and by the foot And need another 25' feet of seal Last edited by kgb424; 12-11-2018 at 01:12 AM. |
01-12-2017, 10:22 AM | #182 |
No track today cause of the ****ing snow, I hate ****ing snow and more ****ing snow coming, so I don't know when I will get my track now |
01-12-2017, 06:06 PM | #183 |
Anybody here familiar with the Canadian mail service TNT I have never heard of them, are they new ?? cause they lost my multimedia speakers for my computer some where between Ontario Canada and New York City The Canadain mail service says it in the US some where USPS service has no record or can find it in the system So its lost and they have no ****ing clue Same with my packages from China there ****ing lost And nobody knows shit **** the Chinese, I'm ready and willing too shove ****ing Wonton's up all there asses Done with China If we go to war with China Sign me up Lock and load Ready to Rock N Roll Just like when I joined the Navy See Bee's I wanted Combat, and was ready to kick some ass And ****ing fired up again I believe in Nuking there asses until they glow And uses their asses for runway lights Last edited by kgb424; 01-12-2017 at 06:17 PM. |
01-13-2017, 12:20 PM | #184 |
I got 2 pieces of 16 ft long track and seal for $60 bucks I got too cut one of them at 9 feet, It snowed last night and its colder than shit today So I might wait until it warms up The seal for the shop doors, the guy has to order a roll and figure how much to charge me For 2 12 and half ft pieces, I'm going to wait a little while until the weather gets better and get second person Before I do the shop doors |
01-13-2017, 02:54 PM | #185 |
Yeah baby I used vise grips to hold the track in place until I could screw it off And was able to slide the track under the roller plates and then screwed thru the plates and track It went pretty easy by myself, the shop doors are going to be a pain in the ass Cause you need 2 people to remove the old seal and install the new seal And got them done in time cause its warming up and there is run off hitting the drive way Cause the snow is melting 2 doors done, 2 more to go Last edited by kgb424; 12-11-2018 at 01:12 AM. |
01-14-2017, 04:33 PM | #186 |
I got my slipper clutch set, and had to 2 problems that I noticed assembling the transmission I used the stock plastic case for mock up, it spins nicely and is smooth But had 2 simple to fix problems, and got another solid transmission 1. I had to file then sand the output drive shafts, so that Axial WB8 and Mips drive shafts slide easily off on the shafts They would not go on and needed to shaved down a little to fit correctly 2. The second problem is the threaded area on the drive gear Shaft is shorter than the Axial version drive gear shaft, So You can't fit the 2 washers, that go on each side of the clutch spring and you need a thin nut even without the washers Too correct that problem, I ordered the Axial version of gear shaft, so I can use the washers and a the right nut Still waiting for the alumium transmission case Last edited by kgb424; 01-14-2017 at 04:46 PM. |
01-19-2017, 03:16 PM | #187 |
And now for something completely different I bought this Tamiya TA-01 and going to make a rally car or a Pre-Runner Truck out of it Or just run it in the Walmart parking lot cause they, were resurfaced recently and are asking to be ripped on The Tamiya's TA-01's and TA-02 are similiar platforms and hoping parts are interchangeable With the extra brushless motor and esc for my Axial EXO, this thing will rip I might buy some drifting tires and wheels once I get used to it And do some drifting baby Last edited by kgb424; 12-11-2018 at 01:12 AM. |
01-19-2017, 06:42 PM | #188 |
Shit happens I got right drive gear shaft today and installed it I lost both of the AX30162 they are the pins, that go into the drive gear shaft and hold the drive gear and inner slipper plate on the shaft On the SCX10 transmission I'm building for my 1/6th scales They came with the clutch kit, I don't think, they were not the right pins, cause the fell out way to easy The Axial pins seem to stay in place better and don't fall out as much cause they are thicker Last edited by kgb424; 01-19-2017 at 06:47 PM. |
01-19-2017, 08:53 PM | #189 |
I love old shit like this R/C From my online research the body was released in 1993 that makes its 24 years old and was on a different R/C The Chassis is TA02 from Stadium Racer Series which was the Chevy S-10 or the Ford F150 or the Toyota Pre-Runner They were released in 1994/1995, so that makes the chassis 22 years old Just shows these things are bad ass |
01-19-2017, 09:15 PM | #190 |
Got some Bling Bling I found these in parts stock pile Now I got a reason to use them, they need glued They might hook up or they might slide around under power Last edited by kgb424; 12-11-2018 at 01:11 AM. |
It just got real - Similar Threads | ||||
Give me real reviews, from real owners, exceed mad torque 6x6 | Misfit650 | Multi Axle Rigs | 10 | 12-29-2015 11:47 PM |
Is this for real? | caymin last | Chit Chat | 3 | 12-19-2014 08:15 AM |
Is this real? | jason | Chit Chat | 18 | 12-22-2010 11:54 AM |
