11-17-2016, 06:45 PM | #81 |
I wanna be Dave Join Date: Mar 2013 Location: Minden
| re: It just got real
no I will be painting them light blue like a Nitrous Bottle Will look for 8 oz and 12 oz C02 cartridges to make welding tanks that are orange and green And use some red and green wires for a hose and make a torch out of something And put it in the trailers |
11-17-2016, 10:00 PM | #82 |
Taco I have tried to make my posting easier to read, even for you by using simple words and Haiku's, and try to keep it simple, cause I get it, you don't like reading I guess you need to review your hooked on Phonics audio tapes and hook on Phonics books and take some of your Arthritis and Glaucoma medication Or take some of your cure all elixir and hair of the dog and enjoy a good read, others like my honesty and sense of humor some don't, but oh well, people are entitled to do there own thing, and we all know I'm doing my own, and in my own little world, and I'm the King and its good to be the King yours is pissing on my parade, that's ok right back at you Last edited by kgb424; 11-17-2016 at 10:07 PM. |
11-20-2016, 08:52 PM | #83 |
| re: It just got real |
11-20-2016, 10:48 PM | #84 |
Nope some people, just will never get it and right back at you |
11-22-2016, 01:22 PM | #85 |
^ I'm more interested in what you've actually accomplished... Not what you might be contemplating in your wishful thinking or imagination |
11-23-2016, 07:43 PM | #86 |
I got the trailers trimmed out and filed flush with plastic frame, I ended up trimming to much on the big trailer and opened up 2 holes in the bed that are on the bottom The little trailer has 3 holes, the way its made, so it should be a easy patch with some Styrene on both trailers Last edited by kgb424; 12-11-2018 at 01:16 AM. |
11-23-2016, 07:52 PM | #87 |
I got the Hasbro Jeep Chassis trimmed out and sanded and will need to add epoxy and some square stock But not sure how to cut the front of the Chassis So I can use still use the front bumper and so it looks right I need to look at other builds and see where the cut there frames and how is the front bumper trimmed and mounted Last edited by kgb424; 12-11-2018 at 01:16 AM. |
11-27-2016, 06:03 PM | #88 |
I trimmed the front of the chassis rails, so the they look right and trimmed off the 2 posts under the body I also trimmed out the hole for the the drive shaft, its bigger than it needed to be, now I see why people use the T1 Disturber Transfer cases I trimmed the back of the front bumper and added a groove, so when I fill it in with 2 part epoxy, it will add strength Last edited by kgb424; 12-11-2018 at 01:16 AM. |
11-27-2016, 07:10 PM | #89 |
This is a T1 Disrupter style, transfer case, I found not sure, they have 2 different output gear ratios I'm leaning towards the 2:1:8 ratio one,over the the other one that seems to be different from seller to seller So I need to check it out, cause one of these T1 Transfer cases would also work for the Jeep Mutt Last edited by kgb424; 12-11-2018 at 01:16 AM. |
11-30-2016, 01:58 AM | #90 |
Ok I pulled the trigger on a T1 Disrupter transfer case like in the pictures above I also bought these G-Made/Junfac wheel wideners with a +11mm offset Cause there cheaper than doing the XR Mod, Cause I made my own tubes for stock with SCX10 axles The SCX10 axles, I XR Modded for the 1/6th scale Jeep Mutt are to wide for the 1/6th scale Hasbro Jeep And the +11mm offset wheel wideners are wide enough to work the stock SCX10 axles Last edited by kgb424; 12-11-2018 at 01:16 AM. |
11-30-2016, 10:08 AM | #91 | |
| re: It just got real Quote:
11-30-2016, 04:41 PM | #92 |
I'm adding more scale detail, I found a shovel and axe for Willy's Jeep Need painted with silver and black to look like the are scratches to give that used look There not the original ones but close enough for replacements Last edited by kgb424; 12-11-2018 at 01:16 AM. |
11-30-2016, 10:20 PM | #93 |
I just found a 1/6th scale Hasbro Willy's gas can, its one of the Desert Willy's ones, its tan but can paint OD Green The sellers pictures are tiny Last edited by kgb424; 12-11-2018 at 01:16 AM. |
11-30-2016, 11:18 PM | #94 |
I worked on the Jeep Mutt, I looked online at Jeep Mutts and the gas can sits on top of bumper mount, not like the Hasbro's or Dragon's they have a tray/mount So I used my Dremel to sand the lip on the bottom of the gas can and the backside of lip on the bumper mount So that the gas can stay in place, but still needs glued in place or 2 face taped or Velcro-ed I want to make it a three handle gas can, before I mount it, cause it has one handle in the middle, It was the only gas can I could find at the time Last edited by kgb424; 12-11-2018 at 01:16 AM. |
12-01-2016, 01:39 AM | #95 |
Yeah Baby Check this out, I made 2 more handles out of scrap Styrene It's hard to round the strips beaning that small, but there getting closer to rounded With them sanded a little more and filled in a little and painted The gas can will look good Last edited by kgb424; 12-11-2018 at 01:16 AM. |
12-04-2016, 11:00 PM | #96 |
Not going to buy it, but it would make a sick R/C If you could find some heavy duty tracks And figure out how to make the tracks work right I seen pictures of a Volvo tp21 That is pretty sick too Last edited by kgb424; 12-11-2018 at 01:16 AM. |
12-06-2016, 10:13 PM | #97 |
Yeah Baby I sanded and filed the steering column and drilled out the steering wheel So the cast steering wheel fits tight I think the wheel, will look better Flat Black, than O.D. Green And like how the nut on the steering column Comes up thru the wheel like the original Hasbro wheel does Looks good to me Last edited by kgb424; 12-11-2018 at 01:15 AM. |
12-06-2016, 11:21 PM | #98 |
Yeah Baby The cast wheels are 2 1/8'' inches in diameter And is the same size as the steering wheel for the Jeep Mutt So a 2 1/8'' wheel is the right size to look scale enough Going to use the second wheel in the Humvee, cause the extra Wraith wheel, I used is not the right size or scale Need to see if there is some of plastic rod, the right diameter, I can use from plastic parts tree's from my Dragon Kit To make a new steering column for the Humvee Last edited by kgb424; 12-11-2018 at 01:15 AM. |
12-07-2016, 02:15 AM | #99 |
That worked great I found a piece of plastic rod that I made a steering column for the Humvee Not sure how far, I want it to come out of the dash board Its not glued in place yet Last edited by kgb424; 12-11-2018 at 01:15 AM. |
12-07-2016, 10:58 AM | #100 |
Quarry Creeper Join Date: Jan 2013 Location: Athens
That steering wheel looks nice.
It just got real - Similar Threads | ||||
Give me real reviews, from real owners, exceed mad torque 6x6 | Misfit650 | Multi Axle Rigs | 10 | 12-29-2015 11:47 PM |
Is this for real? | caymin last | Chit Chat | 3 | 12-19-2014 08:15 AM |
Is this real? | jason | Chit Chat | 18 | 12-22-2010 11:54 AM |
