04-24-2015, 08:59 PM | #1 |
I wanna be Dave Join Date: Sep 2009 Location: n. palm beach
| AWIP, 1/6 Willy's Jeep. "Special Ops"
Hey all, I have a 1/6th Willy's Jeep made by Hasbro, '02. My plan is to transform it into an "Era specific" Recon" rig. I've got some work done, but not all of it is set in stone. I'll get some pic's posted this weekend. Please post up any vavaluable and important info I may need to build this COOL ASS rig. Thank you, John. Last edited by stelerzman; 04-24-2015 at 09:59 PM. |
04-25-2015, 07:22 PM | #2 |
| Re: AWIP, 1/6 Willy's Jeep. "Special Ops"
Looking forward to the build! |
04-26-2015, 09:44 AM | #3 |
Thanks Mike. This should be interesting, because I've read A LOT of build threads on these rigs. Here's a few pic's |
04-26-2015, 10:26 AM | #4 |
Did you weld up your own chassis design? I'd like to see some pics of just the chassis, it looks sturdy, and with the way the links are bolted up in the front, almost looks like a modified wishbone like you'd see on a street rod. Looks interesting. |
04-26-2015, 10:51 AM | #5 |
The chassis is SCX10 that's been modified. I'll post some pic's soon.
04-26-2015, 10:55 AM | #6 |
I originally build the chassis for this build. ***"JACKAL"***, The ulitmate FoFF build. Unfortunately, I had to abandon it because there's no longer a place to run it😢 |
04-26-2015, 07:24 PM | #7 |
I looked through that entire thread^, and it was a very interesting build, especially the frame |
04-26-2015, 08:19 PM | #8 |
Thanks, I looked through it also for some decent chassis pic's, but couldn't find anything useful. I'll get some soon. I just mocked up a SS tierod. It inly took 3 attempts. I hate wasting material. |
04-27-2015, 05:04 AM | #9 |
Rock Crawler Join Date: Aug 2012 Location: Port St Lucie
Please post more pics Giantzman!
04-27-2015, 06:32 AM | #10 |
| Re: AWIP, 1/6 Willy's Jeep. "Special Ops" I'll have some up soon. |
04-27-2015, 08:41 AM | #11 |
Updates. Last pic is mockup, I will make a stronger mount for the links. |
04-27-2015, 06:18 PM | #12 |
I got the hood hinge done. Not too happy with the results. Any suggestions? Thanks. |
04-27-2015, 07:10 PM | #13 |
How are they attached? Glued or are you going to use screws and nuts?, maybe move them a little more out from center? Check some of the other later model builds?
04-27-2015, 09:10 PM | #14 |
There bolted in at the moment. I think I need a better hinge, these are odd. 1" along the pivot and 3/4" across. I can barely open the hood 90` |
04-27-2015, 10:12 PM | #15 |
Hey Mike, here are some close up pic's of the he altered chassis. The original design was to mimic a 1:1 jeep suspension. 4 link with a panhard front and 4 link with tracking bar on the rear. Now it's only 4 link rear and 3 link front. |
04-27-2015, 10:24 PM | #16 |
Here's the tierod that I made up. I used SS tubing and 3mm X 20mm long set screws with Traxxas rodends. Last edited by stelerzman; 04-27-2015 at 10:28 PM. |
04-28-2015, 04:55 AM | #17 |
Looking good buddy! keep up the good work!
04-28-2015, 12:48 PM | #18 |
Workin' on the roll cage. Just gettin' started. |
04-28-2015, 05:36 PM | #19 |
Gettin' closer. whataya think???????????????????? Any thoughts or comments? ? |
04-28-2015, 06:55 PM | #20 |
The tube for your cage looks a bit thin. I used 1/4" brake line for mine, and it doesn't even weigh a pound, and that was after brazing and adding threaded ends to where it bolts through the body. Or is that just a wire form you're using? On the hinges, they look like they're mounted right, with the hinge on the outside, you should get a better opening, maybe try some different hinges, I don't know. I really like they chassis, I'm interested on how the front suspension works, the rear looks fine. Last edited by Mike Flea; 04-28-2015 at 07:00 PM. |
AWIP, 1/6 Willy's Jeep. "Special Ops" - Similar Threads | ||||
Hungary "quick" 1963 Willy's Jeep truck | Senior Latya | 1.9 Scale Rigs | 27 | 10-17-2012 03:47 PM |
Operation Black Ops: "Behind Enemy Lines" Part 2 Axial Jeep Unlimited Rubicon JK | LetsGoMuddin | Scale Videos! | 0 | 06-02-2012 11:28 AM |
Operation Black Ops: "Behind Enemy Lines" Part 1 Axial Jeep Unlimited Rubicon JK | LetsGoMuddin | Scale Videos! | 2 | 06-02-2012 11:27 AM |
