Go Back   RCCrawler Forums > Scale Rigs General Tech > Large Scale Rigs
Thread: A Very Yellow 1/6th Scumvee
Old 02-22-2017, 06:51 AM   #21
Default Re: A Very Yellow 1/6th Scumvee
Moar as promised. Made a 2 part skid plate for the front in order to clear the ring gear and attach the bottom of the steering bell cranks to:
Then cut something roughly similar in shape out of delrin:
Should be a little easier to drag over rocks. Here are a couple more angles:
Now to build some kind of protection for the diffs.
Sent from my HTC Desire 626 using Tapatalk
tcanin00 is offline   Reply With Quote
Old 02-22-2017, 03:29 PM   #22
Whats the wheelbase on that, it looks really long. Are the front and rear just bolted on the top? Seems like there would be alot of forces to yank them out of place.
Been thinking about doing something with a independent suspension build. I have a extra slash 4x4 sitting around.
Druxus is offline   Reply With Quote
Old 02-22-2017, 04:12 PM   #23
The wheel base is 16 7/8." Yes, the diffs are bolted to the top of the frame for now. I will tie them into the frame with solid 3/16" rod, just wanted to get the front skid plate figured out since it seemed like the hardest to fabricate.
Old 02-23-2017, 10:18 AM   #24
Last night's basement debauchery resulted in the makening of imaginary parts. First thing to do was replicate then front lower suspension hinge plate out of steel:
Kind of looks like two ghost faces on each end. Anyway, now I have something made of weldable material for this reason:
The rods will be welded to the new hinge plate, then welded to removable tabs on the frame:
Once situated, I'll weld in cross braces to attach another piece of delrin to.
Old 02-23-2017, 10:43 AM   #25
Man I can't wait to see the Scumvee traveling rough terrain. Hey, what ever happened to that wicked 6x6 Bullhead you built? And sorry I could get those cab measurements that you needed to you last year.
Sent from my SM-N900V using Tapatalk
Rickleo is offline   Reply With Quote
Old 02-23-2017, 12:36 PM   #26
Thanks Rickleo. The 6x6 has been taken apart to be made "better." In actuality, it's in pieces in box waiting for me to get back to working on it. I think I'm using the ESC for this turck. Nothing is safe, really.
Don't worry about the cab measurements. From what I could tell, a Bullhead is too far off from being close to a King Hauler. By the way, your TMNT 6x6 is off to a great start.
Old 02-23-2017, 06:41 PM   #27
LOL. I'm actually building a crew cab Chevy dually
Old 02-23-2017, 07:19 PM   #28
I saw the beginning of that, too. Looking good. I like the old Chevy trucks of that era. I'm thinking about doing a sixth scale CUCV truck to go with the Scumvee. We'll see what happens...
Old 02-23-2017, 07:29 PM   #29
That would be awesome. Are you painting the Scumvee in military colors or is the color scheme still in planning?
Old 02-23-2017, 07:56 PM   #30
No, I'm going to leave it as a civilian H1. The yellow suits it, and I've seen enough tan and camo ones in my time
Old 03-05-2017, 11:31 AM   #31
I've taken a short break on the Scumvee for now to work on other projects, like a '69 Camaro RS:
The TF 2 has made it onto the operating room during this build as well:
I've also made some changes to the first sixth scaler that sent me into the depths of depravity, but I'll post those in its thread.
Short story long, the Scumvee hasn't gone to the wayside like so many others.
A Very Yellow 1/6th Scumvee - Similar Threads
My yellow JK cooper_xl 1.5 Scale Rigs 33 11-27-2023 01:03 PM
Yellow JK MonsterAnt 1.9 Scale Rigs 24 02-20-2010 04:50 PM
2.2 Defender 90 Yellow Vtown Crawl 2.2 Scale Rigs 9 09-19-2009 07:04 PM
Yellow Ledbetter JasonInAugusta Chit Chat 28 12-11-2008 08:33 PM
