Go Back   RCCrawler Forums > Scale Rigs General Tech > Large Scale Rigs
Thread: 1:6th New Bright Ford F-150
Old 11-09-2016, 01:58 PM   #1
Default 1:6th New Bright Ford F-150
I pretty much stumbled across this outside of my LHS:
They were about to throw it away. So, after running my mouth about how these things are worth money on the internets I was less $25 monies and the proud owner of this Ferd.
It made it's way into the basement to be photographed:
The only real damage to the truck is a chip out of the tail gate and a crack in the roof:
Once the initial evaluation was complete it was sized up to Twin Hammers for organ compatibility:
They seem like a close enough match:
Soon after the Hammer Twins had been dissected:
The Ferd fell for it's new suspension:
Which required a frame to be called into existence out of 3/4" tube steel:
I've read many informative threads on here about how to bend tube stock. Whether to heat first, pack with sand, bend cold, or what not. I attempted the cold bend method, bending a little at a time, and it worked out great. On a side note, I attempted to bend 5/16" round thin-wall stainless cold without sand and crushed it. Packed with sand it bent perfectly.
Here is the end result:
Now I'm satisfied with it's shape I'll cut it long ways to make two pieces of c-channel.
This is all I have for now, so stay tuned...
tcanin00 is offline   Reply With Quote
Old 11-09-2016, 08:26 PM   #2
Default Re: 1:6th New Bright Ford F-150
Looks Good!, I love stepsides
Mike Flea is offline   Reply With Quote
Old 11-10-2016, 05:10 AM   #3
After doing a search on here, I was surprised at how few of these that had been converted into crawlers.
Sent from my HTC Desire 626 using Tapatalk
Old 11-10-2016, 07:42 PM   #4
Ya , I spent an entire weekend when I first joined, looking through all the pages and threads in this section, and I think there may be only 1 or 2 of this style Ford, same with the Rangers and F-250's. Couple Avalanches. Bunch of Hummers. Most of the 1/6 builds are Jeeps, New Bright, Nylint, Hasbro (both early and late models, BIG difference between the 2, one is toyish, the later issue is more scale), 21st Century, Dragon, and a couple that are stamped steel.
Actually, went through the section again, and found a bunch of Raptors, a metal F-250, couple Escalades, half dozen or so CXT's, there's a lot, but the majority are Jeep builds.
Old 11-10-2016, 10:35 PM   #5
In 1:6 ?
All I'm finding is plastic 21st, Dragon, Hasbro heeps
link please
TacoCrawler is offline   Reply With Quote
Old 11-11-2016, 06:06 AM   #6
Beauty. I've got a 1/6 NB as well - very similar, but slightly different. Same body style, full interior, but no opening doors. Probably going to be my next project, though I'll be doing solid axles. I've been down the IFS road several times, and it's a fun challenge.
OSRC is offline   Reply With Quote
Old 11-11-2016, 08:18 PM   #7
Originally Posted by TacoCrawler View Post
In 1:6 ?
link please
Don't know how to do a link, 5 threads down from where your thread is, is "Buck's 1/6 all metal Willys Jeep".
Old 11-11-2016, 10:52 PM   #8
Yeah... I saw that thread.
Not alot of detail besides saying it was purchased on ebay.
No worries...
I PM'd the OP to see if anymore information can be obtained.
You can usually add a link...
by going to the resource page,
highlight the address bar > copy > paste
directly into your response here.
ie: Buck's 1/6th all metal Willys Jeep
Old 11-12-2016, 06:47 AM   #9
True, the majority of these are Jeeps in some form or another. Not necessarily a bad thing since I like the flat fender era.
Old 11-12-2016, 06:53 AM   #10
Thanks OSRC. Is yours a dark red Lightning SVT?
I considered doing solid axles since I have a set of Wraith axles I narrowed. Just don't want to cannabolize my Wraith. Plus, a real F-150 would have suffered from the IFS. Kind of like a challenge, too.
Old 11-12-2016, 07:17 AM   #11
Black with a tan interior, just like yours. I believe it had Haley Davidson stickers on it, I don't remember. I'll get a pic up one of these days.
Old 11-12-2016, 07:21 AM   #12
I remembered seeing crew cab Harley Davidson versions, so I would like to see yours. Do you have a build thread on it?
Old 11-12-2016, 07:22 AM   #13
Thinking of stickers, what are you guys using to remove them?
Old 11-12-2016, 11:58 AM   #14
I'd just peel the stickers off
and use some Goo Gone to remove any remaing residual.
Old 11-12-2016, 01:25 PM   #15
Thanks TacoCrawler. Someone recommended I try that. I peeled one sticker off and it left all of the adhesive behind
Old 11-12-2016, 07:35 PM   #16
Goo Gone or WD-40 works too. If you're going to re-paint the body, wash with Dawn, and scuff the body and you're good-to-go
Old 11-27-2016, 11:13 AM   #17
First off, the suggestion to use Goo Gone worked well to remove the adhesive. However, I thought I would expedite the process by using a plastic clay-working knife to help peel the stickers and adhesive. Not the best idea. I'm not sure if the plastic was a little weakened from the Goo Gone or if I was a little too aggressive, but I knicked the surface of the hood. Not a total loss, just a word to the wise.
Anyway, I have been making progress on the new frame. First thing to do was to make a bracket to attach the Hammer Twins IFS:
Then I cut a section of square tube down to make an angled piece and welded it to the first bracket:
Then cut it down a bit and drilled some misaligned holes in it:
Now a cross member is taking shape:
I plan on making a bracket to attach the front of the IFS, just wanted to get the first mounting point sorted out. Plus for an added aggravation, or bonus, I flipped the a-arms and hubs around to opposite sides so the steering linkage will attach from the front.
Here is the frame mock up:
Proposed 16" wheel base:
Now to finalize it's location with a paint pen:
On a side note, I've decided to run Proline B.F. Goodrich KR2 tires. What is with the amount of foam they are stuffing in the tires? They are distorted and no longer round:
Old 11-27-2016, 01:46 PM   #18
I've used goo gone to remove decal glue residual from abs, styrene and poly carbonite plastics
I never had any issue with softening those materials using goo gone.
Now I can't speak for WD40 or other petroleum based sprays...
But it is more likely you were overzealous with that clay knife.
So the "word to the wise" should be...
Don't use a clay knife to peel a sticker off
Old 11-27-2016, 03:20 PM   #19
Good point, taco crawler.
Old 12-02-2016, 09:45 AM   #20
As to be expected of anything I do, it takes forever to see any progress. At least that's what I tell my better half, not that she wants to hear it or anything. Metric and standard excuses aside, some progress has been made.
The first thing is to show the offending clay working knife:
And the damage it inflicted. I had to move the camera around to see the nicks in the plastic, so nothing drastic:
Don't try this at home. Luckily I stopped before doing any series damage.
Speaking of which, I managed to get the frame welded up:
Albeit MIG wire and slag, but none the less a frame:
Nothing a little patience and a lot of time can't deal with:
Mockery time.
Nearly 2" of travel before the camber link hits the frame:
Right here:
I might shorten it and make a bracket on the outside of the frame, just worried about suspension geometry getting whacky.
Without steering linkage it has 51* of steering angle:
Mandatory body-on shot:
Would like to lower the ride height a bit. I'll have to open up the wheel wells to prevent tire rub anyway so I'll worry about that later.
And to end where we started, I peeled off more stickers and only used a rag to remove the adhesive:
It looks so much better without the stickers.
1:6th New Bright Ford F-150 - Similar Threads
Ford F-150 1:6 Volk98 Large Scale Rigs 6 04-06-2015 06:09 PM
New Bright F-150 SteveHyphenOh Axial SCX-10 4 12-14-2013 12:19 PM
ford f-150 honchoscaler 1.9 Scale Rigs 12 01-13-2012 09:41 PM
