Go Back   RCCrawler Forums > Scale Rigs General Tech > Large Scale Rigs
Thread: 1:8 /1:6 AX10 '66 F100 & Willys Jeep Crawler build.
Old 01-16-2018, 12:00 PM   #1
Default 1:8 /1:6 AX10 '66 F100 & Willys Jeep Crawler build.
Hey everyone so thought I'd post my build here on the Large Scale Rigs as well as the AX10 section.
I got my AX10 a few months ago and loved it tho could use lots of improvement. It ran great but needed to be more stable. So I widened it 40mm and am going to lengthen the wheel base shortly. I got a Proline 66 F100 Short Course body which is fitting great so far.. I built a Lexan top Chassis to mount the body and change the battery location to play with the weight but quickly found the Lexan was too rigid and brittle... my new plan is to rebuild it with a different material or start over and build some SCX10 style frame rails to bolt to the side of the AX10 Chassis. But just an idea till I make a prototype...
Anyways here's pics of my progress so far!!!
Sent from my SAMSUNG-SM-G930A using Tapatalk
TwistedcaB is offline   Reply With Quote
Old 01-16-2018, 12:25 PM   #2
Default Re: 1:8 AX10 '66 F100 Crawler build.
Also heres a few of the back up large scale Willys body. 1:6 I believe... I want to make both bodies fit as the Willys is a lil more sturdy so will use it in the bigger rocks. Tho the F100 will be Exo Caged when done
1:8 /1:6 AX10 '66 F100 & Willys Jeep Crawler build. - Similar Threads
Another TSAB build,'66 F100 62PYRO 1.9 Scale Rigs 127 12-16-2019 06:37 PM
AX10 1:8 scale F100 Crawler with custom 1:8 SCX style Chassis TwistedcaB Axial AX-10 Scorpion 21 06-25-2018 08:06 PM
'56 F100 build arnesto Axial SCX-10 12 07-01-2016 08:53 AM
'66 Ford F100 Wroncho Build joe122 1.9 Scale Rigs 42 06-01-2015 08:28 PM
First crawler AX10 scorpion build Joker33132 Axial AX-10 Scorpion 31 05-19-2014 12:31 PM
