Go Back   RCCrawler Forums > Scale Rigs General Tech > Large Scale Rigs
Thread: question about 1/6 willys axle
Old 04-08-2018, 02:51 AM   #1
Default question about 1/6 willys axle
greeting from china! my hasbro arrived today! it is 2003 version, pretty a good deal which it comes with 4 tents.
I know many builder use wk ck axles but when I measured the width with yota ii axle it seems a bit ok just a little worry the turning angle is too small cos the inner fender looks quite close to the wheel.
so my question is if anyone using yota axles being successful?
thks in advance!
無標題 by Dennis Bao, 於 Flickr
denden is offline   Reply With Quote
Old 04-16-2018, 12:34 PM   #2
Default Re: question about 1/6 willys axle
I have a friend that is building one of these jeeps using the Yota axles. He's had to use a wide hex in order to keep the tires far enough away from the body so that it can steer. The wide hexes bring on their own set of issues to deal with.
Maybe a thinner ( skinny) tire might help you? I don't have any good answers for you but curious to see what you come up with.
BigSki is offline   Reply With Quote
Old 04-16-2018, 05:03 PM   #3
58_Willys's Avatar
I can't answer your question about the Yota axles, but wider axles is usually the best idea.
If your going to use something that is not close to the stock size, you should try wider offset wheels or wider axles. Using wheel wideners can add extra stress to axle ends, bearings, and steering components. I modified a couple of D44's for my CJ, and they look very scale and perfect width. You can check it out here.
58_Willys is offline   Reply With Quote
Old 04-23-2018, 09:54 AM   #4
thank you for all above answers. For not creating any unnecessary problem and uncertainty, I have ordered wk axles following all master's advise
Old 04-28-2018, 06:19 AM   #5
Yashua
CREEPERBOB's Avatar
Nice starter rig for your project. I have 2 of these Hasbro Jeeps and 1 trailer.
The Wraith width axles (centered diff in the rear) seem to fit the best, good luck.
CREEPERBOB is offline   Reply With Quote
Old 04-29-2018, 07:12 AM   #6
little update: so far just add on epoxy strengthening the chassis and 70% done on roll cage. pretty happy with the outcome of the cage for my 1st time
Diy steering wheel
iPhoneTapatalk
I kind of addicted to the s/s fabs
iPhoneTapatalk
iPhoneTapatalk
iPhoneTapatalk
Old 05-06-2018, 08:13 PM   #7
KMS
KMS's Avatar
Yes doing a good job for sure ,,Like the bearing in main shaft to steering wheel / servo hookup
KMS is offline   Reply With Quote
Old 05-13-2018, 02:32 AM   #8
iPhoneTapatalk
Driver roll mod
iPhoneTapatalk
Old 05-15-2018, 06:06 AM   #9
Moderator
JatoTheRipper's Avatar
Wow you're getting very detailed with this build. It's going to be so awesome when completed.
Nice metal work as well.
Good idea strengthening the frame with epoxy!
I will be watching this thread.
Old 05-16-2018, 08:39 AM   #10
Updated: diy soldered damper stay, leave it overnight strength test
iPhoneTapatalk
iPhoneTapatalk
Gearbox #1 chinese brand 2 speed #2 scx10
iPhoneTapatalk
iPhoneTapatalk
iPhoneTapatalk
Updated: I need to uplift the engine bay so that it wont hit the front axle for keeping the overall height not so high but ensuring a certain upward travel
iPhoneTapatalk
Old 05-19-2018, 11:55 AM   #11
Looking good so far, I assume it's just a mock up, but you are going to center the rear axle in the wheelwells
Mike Flea is offline   Reply With Quote
Old 05-22-2018, 07:04 PM   #12
Check into some of the other late Hasbro Jeep builds throughout this section, you don't have a lot of space to work with, but they made them work with stiffer suspension. It's looking good in the last photo, looks like the right ride height. PM BigSki, Bitter End, KMS, or Zoso, maybe they can give you some tips.
Old 05-22-2018, 08:10 PM   #13
ya, I will add few s/s tube under the engine bay and solder them, and might compress those tubes so the save more vertical space for axles and upper link , in the end, will post pics while finished.
yes stiffer damper might help but I like it more dynamic rolling movement (horizontal and linear)
battery I will place in rear bed so there will be enough space after motor raise up
Old 05-23-2018, 01:29 PM   #14
RCP CRAWLERS
ZoSo's Avatar
looking good ...don't worry about up travel ...it will be minimal...try to get as much articulation as you can in the front.
you can get a lot of drop out and articulation out of the rear....work on the rear ...
ZoSo is offline   Reply With Quote
Old 05-23-2018, 04:38 PM   #15
Thks zoso
iPhoneTapatalk
Old 05-29-2018, 03:41 AM   #16
Engine bay uplifting done. Plenty of room under now
iPhoneTapatalk
Old 05-29-2018, 08:26 AM   #17
Moderator
Looking good. Keep up the great work!
Old 06-01-2018, 10:04 AM   #18
iPhoneTapatalk
Old 06-02-2018, 11:14 AM   #19
Great progress !
Old 06-04-2018, 09:43 PM   #20
Update: new rear damper mount
iPhoneTapatalk
question about 1/6 willys axle - Similar Threads
Question about 1/6 Willys Jeep Synister_Intent Large Scale Rigs 4 06-30-2016 08:29 PM
inner axle question axialnut Axial SCX-10 3 10-08-2012 06:07 PM
axle question, Large scale heavy duty axle? summervillecrawler Axial Wraith 6 01-31-2012 01:38 PM
axle question for the 1:6 willys guru's out there... brandonwalsh420 Large Scale Rigs 3 01-27-2012 03:53 PM
