03-20-2007, 05:37 PM | #41 | |
Winner of the '07 RCC dumbass award! Join Date: Nov 2006 Location: Up on a Mountain, out in the Woods
Also, Here is a sneak peek into project "Super Steer." I wedged the Wheelchair in the Lazyboy and it was STILL able to turn. It ended up moving the entire truck to turn the front wheels! I am addicted to the power, but the speed is killin me. Its a vent motor for the dual climate zones on a 2001 grand cherokee I parted out. Still not sure on the plastic gears... stripped one out just to see and it took insane force before it did. I have a spare set but we will find out... The motor in it sucked at even 12 volts so I did a little somethin I learned messing with low gearing radio shack toys Two 645 motors. Check it out! http://video.google.com/videoplay?do...31007718116210 Last edited by WheelChair; 03-20-2007 at 06:28 PM. | |
03-20-2007, 09:16 PM | #42 |
RCC Addict Join Date: Apr 2006 Location: Brighton
'Bout time you posted up Still don't see the monster rod ends Have fun out in Moab, and no cliff divin' with the 'Chair:-P |
03-20-2007, 09:29 PM | #43 | |
Thanks DeaDShorT Almost have this output gear finished, then the links are next! I have to brushless-proof everything aswell, gonna be callin up holmes before jeep safari. I need that motor, no better place to test then moab! Last edited by WheelChair; 03-20-2007 at 09:32 PM. | |
03-20-2007, 10:08 PM | #44 |
Awesome!! Now your making your own gears? BADACID!!!! The super steer? Are u using the gear from the 645 that always strips on my 2.2? Good work man! |
03-21-2007, 10:38 AM | #45 | |
Screw those people who make shotty parts for mucho denaro!!! I didn't like how they built the slop back into the maxx gearing. I assembled the tranny, put some lucas oil stabilizer, sealed the case and ran it. Very nice operation! Here are the pics of the finnished unit! Forgot I sheered the pin on the inputgear before last comp. Repiinned it and now the hole in the shaft has wore so the gear is loose. So I am going to throw one of those in it before I put it back in the beast. The Super Steering uses the gear that I have not been able to strip. The second gear from the motor. (The one that strips that center one.) Now, for these 1/4" links... I'm going to have to call up and place an order with Holmes soon! I need a 3025 before moab! | |
03-23-2007, 04:48 PM | #46 |
| Output gear - E brake DONE!
666 stopped over and let me barrow his 3013-16 for testing! We put 14.4v to it and I was glad to see some speed out of it with a 22 tooth pinion, but I think the 3025 is the one for me. The 3013 was alot more powerful then the titan @ 14.4v but didn't have the low end grunt to crawl with the 22 tooth. We tried a 14 tooth pinion and it was alot better for crawling but the Wheel speed was gone. It was good to see the 985kv was not as slow as I had thought it would be. Since it is the same Kv rating of the 3025, noload wheel speed should be the same. Here are some pics of the ULTIMATE EMAXX TRANNY: The Patlas 400 |
03-24-2007, 11:22 AM | #47 |
I had to stop by and check and see this HANDMADE gear! And to see if my hyperion could break it! The tranny itself is a well thought out design. Now it is just about bomb proof! Everyone, including me, goes out and buys all the parts to make a crawler to fit them best, not this guy, he goes all out and BUILDS the sh!t himself! Sure it is maxx based but everything about this thing is handbuilt! Good job man!! |
03-24-2007, 12:10 PM | #48 |
The 'Chair has to be one of the coolest rigs I've seen, just something about the build it yourself attitude that Pat has. Pretty impressive I'm still waiting to see the finished monster links...I see the ends in those pictures |
03-24-2007, 01:01 PM | #49 |
Wheelchair's girlfriend says: "You guys have rendered him speechless!! That is AWESOME!" D I don't know what to say guys... Thank you for the compliments!! I just build it because I have to, You can not buy what I needed. |
03-24-2007, 04:39 PM | #50 | |
And thats why it's so damn cool This hobby wouldn't exist if guys like Pat didn't see a need, and set out to build their vision.... Props to D for supporting all this silly stuff, that deserves an honorable mention, TOO. ShorTy | |
03-24-2007, 11:05 PM | #51 |
Rock Crawler Join Date: Apr 2006 Location: Salem, Orcrc
DDDDAAAAMMMMNNNN!!!! i wish i had the time and monay to do something like this.
03-25-2007, 07:20 AM | #52 |
03-27-2007, 11:43 AM | #53 |
| Brushless gear ratio's
Found the Second gear ratio, did some figuring... When I tested 666's 3013-16, we first ran it with the 22 tooth at 105.14 Crawl ratio. Wheel speed was kick a$$ but the crawlability sucked. It was too much load for the 3013. Then we put a 14 tooth on, Running 165.22 crawlratio, and the wheel speed was gone but it crawled much better. I think I have the gearing figured for the 3025, but real world may prove otherwise. Also, The 'Chair got a new toy last night! |
03-27-2007, 04:28 PM | #54 |
That should be interesting...I'm not sure I could even guess what you made to lift that pig Hope the spools big enough to help with those 40 foot drops ShorTy |
03-27-2007, 06:21 PM | #55 |
Quarry Creeper Join Date: Jul 2006 Location: In a tree top with my chainsaw!!
| wheelchair winchin'
Dude that winch is friggin' strong. I watched it lift the 'chair straight up completely off the ground. and ask him about the speed control for his super steering. Good stuff. |
03-27-2007, 10:22 PM | #56 |
| Now I really need to see that Speed control on the steering...damn. Necessity is the mother of invention. |
03-28-2007, 12:19 AM | #57 |
03-30-2007, 01:32 AM | #58 |
| Nice Shots Last edited by JasonInAugusta; 07-19-2007 at 10:08 AM. |
03-31-2007, 05:41 PM | #59 |
| Hyperion 3025 Ordered up! :twis ted:: twisted::twist ed::t wisted: Just placed an order with Holmes, Next Comp.... ITS ON! |
03-31-2007, 06:17 PM | #60 |
Looking good, Buddy!! |
