Go Back   RCCrawler Forums > Scale Rigs General Tech > Large Scale Rigs
Thread: Weekend Warrior
Old 11-16-2020, 02:48 PM   #1
Default Weekend Warrior
I scored a cheap New Bright 1/6th scale Ford Raptor for $30 the other day.
I have always wanted one of these big bodies, and figured I would do a scale build. Element Ifs kit is on order, and I plan on picking up a SSD pro 44 rear axle so I have matching gear ratios. I cut some frame rails, giving myself 1/2 an inch on each end extra, so 27" long. Sitting on a 16.5" wheel base and 10.5" wide at the fenders. After tossing the body over the various axles I have I determined Scx10 axles were wide enough with 1/2" wideners and 2.2 wheels.I had a set of Axial Method 2.2" beadlocks. I stretched some 1.9 Pitbull Growlers over the 2.2" beadlocks giving me a 4.75" tall tire in the 5"wheel well openings.
Ride height will be low, I plan on building a truck that looks like a weekend warrior type.
https://images.app.goo.gl/mD6cGFiW2nmqFgcd7
lonleycreeper is offline   Reply With Quote
Old 11-16-2020, 02:56 PM   #2
Default Re: Weekend Warrior
Dude! This is awesome!
I have been looking for the New Bright 1/10ish scale 4 door body for my TRX4. Where did you get this body?
ScaleLifeNewbie is offline   Reply With Quote
Old 11-16-2020, 03:08 PM   #3
The body is a true 1/8th scale, and I found it @Walmart in the clearance section.
Old 11-16-2020, 03:11 PM   #4
Wow really? Great find!
Old 11-16-2020, 04:52 PM   #5
Nice score!
Mike Flea is offline   Reply With Quote
Old 11-16-2020, 05:37 PM   #6
Yes sir! I was ecstatic! only pushed 2 little kids out of the way.... Just kidding...
Originally Posted by Mike Flea View Post
Nice score!
Thank you... See above!
Proposed ride height and frame mocked in...
Old 11-16-2020, 05:40 PM   #7
That body is a almost direct bolt on to the yeti you just need longer links for the rear and a piece of 1/2" L angle up front
Can't wait for the run video
ferp420 is offline   Reply With Quote
Old 11-16-2020, 06:12 PM   #8
I am too excited for this!
Old 11-16-2020, 06:40 PM   #9
Intresting! To bad the Yeti is not being made anymore...
I did throw it over my Losi Baja Rey, and the track width is to wide for what I was going for. I would have to widen the fenders a bit with wider flares and then I would have a hard body version of my Baja Rey... Not ideal imo...
Not as excited as me!
Old 11-17-2020, 09:58 AM   #10
Nice! I just saw one of those at Walmart to, same price. They are pretty scale bodies, good for some minor bashing. I built one using a slash 2wd.
Gula is offline   Reply With Quote
Old 11-17-2020, 11:34 AM   #11
Man, I need to check Walmart more often lmao!
Old 11-17-2020, 04:47 PM   #12
Agreed, holes for 5mm led's in the headlights and tail lights, can probably stuff some 3mm led's in the markers. The light bar up top could take some 5mm led's as well. Only problem for me is the holes in the back of the cab are kind of large, where the have to plastic bed cage in it. And the windows are black.
My advantage is I work there, and just happened to pass by to see it...
In other news, I stripped the stickers, not vinyl, but paper stickers... peeled right off and left no residue, unlike my Bronco. I also got an axle under my trailer, I think it looks fitting...
Old 11-17-2020, 04:50 PM   #13
Sweet! Looks 100x better without those crazy stickers
Is your trailer made out of some sort of thin wood? Looks like 1/4” wood.
Old 11-17-2020, 05:38 PM   #14
Yo got it, 1/4" interior plywood.... I had several scraps left over from a project and decided I wanted a trailer..
Old 11-17-2020, 05:48 PM   #15
That’s pretty much what I did, except I used 1/2” interior plywood. I wanted to use 1/4”, but realistically I’m probably going to make a new one in a month or so lol. Do you have a thread for it?
Mine is just a boring box, I now wish I would’ve added some curves to it.
Old 11-17-2020, 07:17 PM   #16
Lovin that trailer lol definitely completes the weekend warrior look
Just needs some kayaks and some bicycle's
Old 11-17-2020, 07:53 PM   #17
I didn't want a boring box lol, and built it big enough to hold some beverages.... for the trail, you know... Insulated and all with 1/2" high density foam. It now has coil spring suspension with trailing arms...
only documentation I have of the trailer... Bubbles 3.0
Maybe a Dirt bike or two as well...
Old 11-17-2020, 08:48 PM   #18
Yes!
Old 11-18-2020, 03:33 PM   #19
Got the rear suspension sorted!
1.4" of wheel travel out back...
Aka 11.2" of scale travel.
Old 11-28-2020, 11:15 AM   #20
Parts finally came in, and assembled...
This is not the rear diff I will be using... Its geared too tall...
Peeking through th bed...
Next to the classic Honcho!... Note: Tires are the same height, 4.75"
Weekend Warrior - Similar Threads
Weekend Warrior lonleycreeper Axial SCX-10 90 09-15-2014 06:06 PM
Weekend Warrior bodean Scale Videos! 0 10-17-2013 02:50 PM
Weekend Warrior Jeep JK notagain 1.9 Scale Rigs 4 07-26-2010 08:11 PM
Weekend Warrior TJ Colby 1.9 Scale Rigs 16 06-08-2010 03:20 PM
weekend warrior yotesnake! octigonwallrus 1.9 Scale Rigs 6 05-16-2009 11:31 PM
