![]() | #1 |
Quarry Creeper Join Date: Dec 2009 Location: Fairbanks, AK
For those who have built one AND used an RC4WD Disruptor, which one did you use? .75:1 or 2.18:1. If you used a .75:1, what motor did you use? I'm running a HH Puller Pro Stubby 1800kv with a Castle Mamba X (sensor wire being used). Stock Wraith axles, .75:1 Disruptor and a stock SCX10 transmission. It's got 32p 57/11 gearing. When I try to crawl over anything larger than 2", the motor won't turn. Is that .75:1 disruptor just too much for this heavy of a rig? Suggestions accepted. |
![]() | #2 |
I wanna be Dave ![]() Join Date: Apr 2013 Location: Streamwood, IL
Check out the sticky from Zoso, right above your thread, there's also a link to RCP Crawlers, looks like he sells the 2.18:1
![]() | #3 |
Thanks Mike. Unfortunately no one has had one in stock in a few years. RC4WD quit making them quite a while ago. I'm not sure how I ended up with this .75:1, but I did. I was hoping I could use the .75:1. I took it apart to see if I could swap the gears. But not only are the gears machined into the shafts, the case isn't big enough to swap them. |
![]() | #4 |
.75 to 1 would be a over drive more speed less torque 2.18 would be underdrive makes more torque and less speed |
Gi Joe Willys 2.0 | PNWRC | Large Scale Rigs | 10 | 02-28-2021 08:35 AM |
My 1:1 GI Joe Willys | svaras | 1:1 Full Size Vehicles | 2 | 11-10-2014 07:50 PM |
Gi Joe Willys in HD | ZoSo | Videos! | 11 | 11-02-2010 04:41 AM |
