04-12-2007, 11:39 AM | #21 |
Quarry Creeper Join Date: Oct 2004 Location: Cow crap flats
thanks guys!! i got the trans and t-case mounted now im just waiting on the drive shafts and i still have to mount the steering servo. jim |
04-13-2007, 09:19 PM | #22 |
I wanna be Dave Join Date: Apr 2005 Location: Eastern WA
I am buying the original skippy made TXT jeeper, I cant wait, ill send ya bodyless pics if you want :-)
04-14-2007, 07:02 AM | #23 |
04-14-2007, 05:39 PM | #24 |
Okay. Got any updates? |
04-15-2007, 04:16 PM | #25 |
first test runs are complete!! suspension setup works very well! no wobble no torque twist(might go to heavier springs once the front axle is pulling too.)70/30 droop setup with touring car springs. defiantly needs more weight on the axles, but all in all i am very pleased with things so far!! Jim Last edited by envious8420; 04-18-2007 at 08:06 PM. |
04-21-2007, 01:59 AM | #26 |
I wanna be Dave Join Date: Nov 2005 Location: Crawler practice!
04-21-2007, 09:03 PM | #27 |
04-22-2007, 08:35 AM | #28 |
Quarry Creeper Join Date: Jan 2006 Location: Atlanta GA
very nice, looks killer.
05-12-2007, 12:55 AM | #29 |
Newbie Join Date: May 2007 Location: louisville
thats cool. is that a nylint hard body you started out with.
05-12-2007, 08:31 PM | #30 |
yep
05-13-2007, 12:59 PM | #31 |
Pebble Pounder Join Date: Aug 2006 Location: in "Joisey"
AWESOME Job there!!! Love the look!!!! |
05-13-2007, 05:29 PM | #32 |
looks cool but mount that steer servo up on the chassis.
05-14-2007, 05:59 PM | #33 |
Lifetime Gold Baby! Join Date: Sep 2004 Location: GA
needs a scale engine up front and the rims don't suit it very well.. but I'm sure you have more plans for it. looks very good still |
05-14-2007, 08:33 PM | #34 | |
that leaves me with inner fenders only:-( going to try narrowed stockers with narrowed m2ks if they will fit. servo is going up onto the frame. this was just quicker for now. got my third drive shaft today, now as soon as that alu xxxnt diff gear gets here ill be able to test out the 4wd set up. ill also be replacing the txt trans with an e-maxx unit running into the xxxnt t-case (4.11:1) also got some of the cen resy shocks today. these are huge!! | |
06-03-2007, 08:35 AM | #35 |
added rear bumper and gas can mount, also added front stinger reinforcements and tcase mount/skidplate. mounted steering servo to the frame. as soon as my t case gear shows up and i get another revo shaft it will be a runner. |
06-03-2007, 07:25 PM | #36 |
I lost my vendor privileges Join Date: May 2006 Location: TOP OF THE HILL
great looking rig. like it with the army well kinda green.
06-03-2007, 07:54 PM | #37 |
Adilynsdad too! Join Date: May 2004 Location: G ville
I never thought I would like the look of a Nylint body but, dang you proved me wrong! This is cool as heck
06-17-2007, 05:02 PM | #38 |
finally got the alloy diff gear for the t case put it all together and drove it around for a few, until the t case started clicking again! the top shaft gear is steel the diff gear is alu. i left the plastic idler/brake hub in as a weak link. the only other thing i can do is put it all in a new case with new bearings to tighten it all up. i didnt realize the case was worn out??? ive broken them, just never wore one out before. if this doesnt do it, it will be time to find an alu case for it, or have one made. anyone have any other ideas? maybe a different t-case? one thats a little more stout. ok i pulled the t-case out and apart. just as i suspected its a tolerance issue, shaved the tops of the teeth off in 1 spot, the rest of the gear is brand new. so im thinking maybe a bent shaft too. pulled the bearings from the case too, super sloppy. so now i have a clue as to what happened in this instance. so some new bearings and the shafts and ill try, try again. |
06-30-2007, 03:48 AM | #39 |
an update please i like this build
07-01-2007, 09:04 AM | #40 |
