08-20-2007, 12:11 PM | #1 |
I wanna be Dave Join Date: Feb 2006 Location: Campbell, CA 4 hrs 2Rubicon !
| attention Shafties, tranny setup and gear Ratio Any of you ( Pro's or Comp guys, or bashers prefer to have the trans setup so that if let's say one of the rear wheels becomes stuck and cannot turn but the motor still turns the Front Wheels ? Or Do you like the Slipper to Slip entirely so if any of the 4 wheels cannot turn all power is lost and slips into the slipper, thus saving from breaking axles? I'm thinking the first way is best. also where is info to figure out gear ratio's ? and what ratios are best? thanks |
08-20-2007, 03:46 PM | #2 |
Wow not very busy here.... guess I will delete this tonight With center diff you only loose front or rear drive Not both at the same time , isn't that better.. |
08-20-2007, 03:54 PM | #3 |
I wanna be Dave Join Date: Mar 2005 Location: Hiding from Goodall
Wow you are impatient If you had wanted opinions on power transfer for shafties you should have asked in General Crawlers and not the scale forums. |
08-20-2007, 03:58 PM | #4 |
No need for two posts with the same question. Please see the other thread if you want to reply. attention Shafties, tranny setup |
