08-11-2007, 03:36 PM | #41 |
Pebble Pounder Join Date: Aug 2005 Location: San Francisco
THOSE ARE BEEEEFFFFYYY. nice
08-17-2007, 09:26 PM | #42 |
Pebble Pounder Join Date: Jun 2007 Location: Tyler, Texas
Wow those rod ends are awesome but man are they huge! Let us know how they work out for ya. Definetly interested if they hold up well. I had a similar idea as far as links and rod ends go and was thinking of using 1/4in solid steel links then drilling and tapping them out but not sure how easy it would be and then there's the weight issue of them. Looking forward to seeing your progress. Keep up the good work |
08-19-2007, 09:20 PM | #43 | |
I wanna be Dave Join Date: Feb 2006 Location: Campbell, CA 4 hrs 2Rubicon !
the thermo plastic rod ends are like 225 ftlbs rated, and they are so light you can't tell you are holding them if your eyes are closed I'm looking for a Good reliable tranny hopefully 2 speed. Cause people are saying the RC4wd tranny 2speed is "set for destruction if I use it on my super and a Brushless motor . So far no luck, I may building my own Darn Tranny ! Using a MIP tranns with 44 Spur to a ****er box in a GD600 to a drive shaft to a reduction unit to the Motor | |
08-20-2007, 10:32 AM | #44 | |
RCC Addict Join Date: May 2006 Location: Aroostook county
08-20-2007, 11:25 AM | #45 |
Quote" emaxx tranyy" Yea but it's so freakin Big ! Got a Great Idea :-P I may do this setup and build a shifting case to use a Servo to engage the GD600 , basically engage a 2nd Reduction Unit This tranny size is very small and the shape is very simaliar to the Real Thing It also has BRASS Gears ! Don't see them breakin LOL the belly of the tranns (out put shafts) will sit on pan along with all the motor etc. ALSO this tranny allows the front wheels to turn even if the Rear wheels get stuck and stop, and Visa Versa. Unlike most trannys the slipper Slips and NO power goes to any Wheels 1st Gear reduction unit is a 4:1. it came from my rc 4x4 truck puller :-P I don't know what the GD600 is though? But together that would be insane CrawL What do you think ? Last edited by toy4crawlin; 08-21-2007 at 12:44 PM. |
08-31-2007, 04:37 PM | #46 |
More parts arrived Wahhooo Mamba max from Crawler Store, wow this ESC is Sweet ! BM16 Brushless From RCP rod ends 1/4 .035 wall Stainless Tube for Chassis from Mc caster Fuel Cell Box to Hold ESC Electronics store Voltage reg, back order Holmes Hobbies Voltage Reg for Radio and small bec from Dimension engineering new DX6 battery 2500 battery from Cheapbatterypacks.com Parma 1/10 scale model V8 motor Brings this months total over $300. ooops Found this Awesome little box that looks just like a fuel cell (texture) and still fit a Fan inside gonna dress it up, make the wires look like High pressure lines Box is 2 1/4 square by about 1" tall Where can I get a Fuel cell inlet Sticker anybody? Last edited by toy4crawlin; 08-31-2007 at 07:25 PM. |
08-31-2007, 04:44 PM | #47 | |
You could gut out those Spinny spinners RC trucks at Toy r us and use the sounds system out of those | |
09-03-2007, 10:28 AM | #48 |
Rock Crawler Join Date: Dec 2005 Location: Connellsville PA."fayettenam" lol
| clap ya hands
that is just sinister. good job man! |
09-03-2007, 11:09 AM | #49 |
Pebble Pounder Join Date: Apr 2007 Location: Dupage County
This build makes me feel hot and steamy.
09-03-2007, 12:59 PM | #50 |
wow this is my 2nd or 3rd time in the maxx forum since i joined, but this thing is worth watching! holy **** man!
09-03-2007, 08:18 PM | #51 |
Rock Stacker Join Date: May 2007 Location: 615
that is going to be one nice rig!!!
09-14-2007, 01:46 PM | #52 |
Some work last night Mocked up a Top Tube frame for the New Super I did a quick upgrade to my rear servo High pressure line STYLE :-P I used Tamiya color, Anodize from my LHS 3/16 Aluminum tube then tamiya anodize , used that on the servo end Braiding is from HSC halted.com for the 1/8 Braided tubing .50 cents a foot Servo plug end is just shrink tubing I might cover the braiding in Clear shrink tube to simulate the new 1:1 brake line. I still have my first maxx , So that's what the pictures are Last edited by toy4crawlin; 09-14-2007 at 02:00 PM. |
09-16-2007, 11:20 PM | #53 |
Narrowing wheels and adding hex bolt beadlocks ball bearings inside for weight Last edited by toy4crawlin; 08-08-2008 at 02:43 PM. |
09-22-2007, 11:44 AM | #54 |
Rock Stacker Join Date: Sep 2007 Location: Wherever Uncle Sam tells me
| Look into the T/E Maxx Jaws sticker sheet. It's fuel door sticker looks kind of like a fuel cell filler and it gives you a couple choices too. It's worth a look I think.
09-22-2007, 12:37 PM | #55 |
RCC Addict Join Date: May 2006 Location: Roseville
Very cool rig man, I really like it. I cannot wait to see the finished product.
09-24-2007, 06:09 PM | #56 |
thanks Trikster little progress here, have all my 4-40, 6-32, 8-32, 10-32 and so on HEX Head screws to keep the bolts Scale looking Still Undecided on Tranny, the RC4wd tranny in the way of the seat and Not feeling good on strength quicky mock up |
09-29-2007, 02:40 PM | #57 |
Newbie Join Date: Sep 2006 Location: Bremerton
I don't know if you ever came up with a way of attaching the axle tube to the diff but I wash thinking of doing the same thing but never got around to building it. This was my idea, use 2 large washers and weld the axle tubes to them. Then sandwich the diff between the washers with bolts or large machine screws. this would allow you to get the diffs apart if needed and you could rotate the diff to get that perfect pinion angle |
09-29-2007, 11:07 PM | #58 | |
For my New Super I like different/ innovative and (Clean) so I have not finalized on it yet. still using my custom maxx as a practice template as I continue to research, find parts and work on the Design. thanks FinishLine Rc Hooked me UP! Real Delrin Links I was thinkin of using Stainless but I'm worried about weight, besides the Chassis will 1/4 stainless and there will be so much detail that the Delrin should look good Last edited by toy4crawlin; 09-29-2007 at 11:20 PM. | |
10-12-2007, 09:22 PM | #59 |
Rock Crawler Join Date: Sep 2004 Location: South Orange County
i love the braided wiring get working on this build i wanna see it as a roller buy this weekend |
10-14-2007, 10:00 PM | #60 |
Newbie Join Date: Oct 2007 Location: lodi
i love this bild good job
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/large-scale-rigs/66983-project-full-throttle-super-comp-crawler-mp3-stereo.html | ||||
Emaxx-Revo-Losi 1/5 AWD On-Road racer - Page 2 - RC-Monster Forums | This thread | Refback | 03-01-2013 04:11 PM | |
Toyota vs Jeep discussion? - Pirate4x4.Com : 4x4 and Off-Road Forum | This thread | Refback | 02-27-2013 05:55 AM |
